Question about Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Bake element burned out on my Jenn-Air SVE47100 Slide-In Electric Kitchen .I replaced it but oven does not heat ,when i turn oven on and check each terminal of bake element (and broil element)from ground i get 120 vac but when i check acrross the leads i get 0 shouldnt i get 220 vac? i get 19 ohms on bake element an 15 on broil element when no leads are attached
  • jcoffman333 Jul 26, 2011
    Perfect ! it was the high limit switch,Thank you for your help
  • Jenn-Air Master
  • 842 Answers
HI,
You should have 120 to the element when not in bake mode, while in bake mode you should have 220 - 240 volt. Sounds like you lost a relay to send the additional power to the element, or you have a High Limit thermostat which could be open. This is a safety device to protect the unit from over heating, this only goes if temperatures increase higher the safety levels, normally set about 200 degrees or so along the air flow channels. I would trace from the elements to the clock and find the missing source of current.
I hope this helps
Be safe with electricity......
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Jul 26, 2011
Testimonial: "Perfect! it was the high limit thermostat.Thank You for your help"
SOURCE:
Jenn air mod. # sve47100 oven not heating
when you checked the elements for continuity did you remove at least one of the wires off of it,if not it will check good.if the elements are good,unplug it,pull it out and remove the back wall so you can get at the wires,plug it back in and make sure you're getting 240 volts to the bake element and 120 volts to the broil,if you have 240 volts coming to the machine at the plug and you don't have 240 at the bake element check for broken wire,if wires are good you have a bad clock assy. the relay on the computer board is bad and you'll have to change out the clock assy. unfortunitly you can't get this clock anymore but you can send it out to have it rebuilt,go here and get info,hope this helps
http://www.repairclinic.com/PartDetail/Oven-Control-Board/71002331/695629
Dec 12, 2012 | Jenn-Air SVE47100 Slide-In Electric...
My oven doesn't bake properly. Everything takes extra long to cook and even when I give it extra time the food usually isn't baked all the way through.
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Aug 11, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Heating element burned out (literally!)
No you are fine...just replace the element, they will fry like that sometimes...
Check out this tip that I wrote about this problem...
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Apr 29, 2010 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Oven Won't Heat
are you still getting power to the oven? breaker ok? there may also be a fusible link somewhere on the circuit
Nov 21, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Baking element replaced but still won't heat
you may have triped half your 220v breaker. (you should have shut it off when reparieng wire or it would have been live and zaped you) Or something in line with the wire that shorted blew out like a fuse in the range.
My Jenn-Air SVE47100 slide in electric range does
Obviously it does not work fine. The thermostat sensor or the stat itself could be an issue. Can you see the sensor 'bulb'? Clean it with oven degreaser and steelwool. What is the temp in the oven with a 'oven thermometer'? Is this consistent with the oven readout?
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Sep 24, 2009 | Jenn-Air SVE47100 Slide-In Electric...
My Jenn air SVD48600P heating element dose not heat
Hi. I believe this info. may assist you in getting your bake and broil up and running:
When your heating element burns out, you have to replace it because they are not repairable. If, when the heating element burns out, the infinite switch that controls it also fails, you have to replace it too.
May 31, 2009 | Jenn-Air SVE47100 Slide-In Electric...
Bottom element burned out, replaced with a new one
there does appear to be a high limit thermostat located on back wall, diagram not really clear where but would be wired inline with the bake element . if thats blown there would ne no bake/ probably no broil either
Mar 06, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Bake oven element blew
Could be the oven selector switch or the thermostat that failed form thhe element shorting out. You will have to have a ohm meter to check these
Dec 15, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-Air SVE47100 Slide-In Electric Kitchen Range Logo
414 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Thomas F. Schneider
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
