Question about Solis Crema SL-70 Espresso Machine
Steamer/frother in-op First off, Javadoc.com referred me. Steamer section doesn't work properly. the symptoms are: On cold start pump will deliver water at a steady stream through the wand. However, if the steamer heat is turned on and that section is brought up to temp there is nothing through the steam tube but all of that steam is diverted over to the portafilter side and the pressure is relieved, dramatically, through the portafilter. I have tried reaming the tube with flex wire and also decalcifying the system, a futile exercise because the local water is mineral free. But anyway I did go through the drill. The machine is 8 months old and gets limited daily use. Any help would be appreciated. Thanks ~Bob
  • 1,089 Answers
Hi
I think you steam knob is out of adjustment. This valve the the knob turns opens a needle, so when you close the knob it is just allowing the needle to seat. If you turn the knob harder you move the valve away from the needle, so when you try to steam everything has expanded and the valve does not touch the needle, and it won't open.
To fix.
The top comes off by removing the screw on the top back where the water tank locks in. Once the screw is removed the put both hands on the side of the machine near the top and with your 2 index fingers, push the top forward. This will push the top of the face plate forward and release the top.
Once the top is off hang it over the back for know.
You will need a #2 Allen wrench. Rotate the knob all the way counter clockwise. You will notice that there is a cam that rotates with the knob. On the back side of the cam you will find a hole. Inside that hole is a #2 Allen screw. Loosen the screw and then without moving the cam rotate the know all the way counter clockwise, then tighten the Allen screw. This is how you adjust the Solis SL machines steam valve.
To reassemble.
The top of the face plate locks into the bottom of the front part of the top, so when you put it back together slip bottom of the face plate into the machine, then put the top on the face plate so the front of both is flush whit each other. Then push down and back on the top and it will lock in. then put the screw back in and your done.
Posted on May 31, 2009
The washer is stuck locked. When turned on it shows OP where the minutes are!! PLEASE HELP !!
Don’t force the lid open and break the lid locks.
Here is the Service Manual and parts look up;
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
Use this procedure for releasing the washer top from the base;
Un plug the 120VAC power cord to the washer.
To raise the top of the machine. Insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
This will get the clothes out.
With the washer top raised gently push to Left and Right lid lock latches to outside of the lid the unlock position.
You can now lower the washer top to the base.
Do you want to DIY the OP error code?
The OP error code could be caused by a Lid Magnet out of position. To do a quick check with the lid open power up the washer. Do you have the OP error code showing? If so take a large magnet and place it over the grey left lid bumper and see if the OP error code will clear the LED display. A Pic for reference;
If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
e830e40.jpg If that doesn’t clear the OP error code we would need to do deeper troubleshooting. Are you up for that? Let me know……Rich
Apr 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
The frother on my cafe roma has stopped working. I removed the wand but where the steam comes out is stopped up. how do i fix this
The "frother" is probably blocked. Remove it and see if you can blow through it. If not, you can try cleaning it with a paper clip. If that won't work, place the metal frother tube in a pot of water with a bit of ammonia or vinegar in it. Heat the water to boiling, then let it simmer awhile. After it cools, try using the paper clip again. You should clean the steamer attachment after each use:
2. Remove the froth enhancer and rinse under warm tap water. 3. Wipe the steam wand with a damp cloth. 4. Briefly set the Selector Control to the ‘STEAM’ position to clear any remaining milk from the steam wand.
Oct 30, 2009 | Breville ESP8XL Espresso Machine
I purchased a second hand Saeco Royal Professional coffee machine and the frother does not work. When I press the button all I hear is a pumping sound but no suction what so ever. Also when I use the...
try inserting the frother in hot water its probably block and for our water everytime you whant steam open vale boiler start to boil water let the water drip into the tray wait untill steam come out pierre
Jan 10, 2009 | Saeco Odea Giro Plus Coffee Maker
Steam frother
1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for the machine for an hour. 4. Remove sheath from the steamer. 5. Place tip of steamer into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through steamer.
Optional: Before starting the process, unbend a paperclip or metal hook (for hanging holiday ornaments) and use it to clear the steamer orifice.
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Jun 19, 2008 | Krups Allegro FND111 Espresso & Coffee...
Steamer and milk frother not working
This sounds like one of several problems:
1. Does any indicator light come on? If there is one and it doesn't you either have a bad thermostat (size of a dime/1/4 inch thick) black item with two wires attached to the chamber or a bad heater. Check both with an ohm meter...Resistance of any kind across the terminals means okay.
2. Could be the switch. Same kind of test.
3. If you've got a steam leak, deal with that...new cap or valve.
Make sure all wire fasters are clean and bright. If screwed down, make sure they are tight. Cycle each connector off and on to clean them.
Remember: always work on your unit with it unplugged. You may need torx screwdrivers to open this unit. Any hardware store will have sets of these items.
Jun 15, 2008 | Coffee Makers & Espresso Machines
No steam comes to milk frother
Try this: 1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for about an hour. 4. Remove sheath from the frother and clean the metal tip. 5. Place tip of frother into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through frother. 7. You'll know the frother is clear when the water in the mug begins to churn rapidly (and perhaps loudly).
Optional: Before starting the process, unbend a paperclip or thin metal hook (the kind used for hanging holiday ornaments) and use it to clear the steamer orifice.
To keep frother clear: Follow recommended descaling schedule in user manual
Jun 05, 2008 | Krups Allegro FND111 Espresso & Coffee...
Steamer
Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
Apr 23, 2008 | DeLonghi EC140 Espresso Machine
Milk frother /steamer not working
if you could remove the pipe put the pipe in a solution to remove the calcium in thr pipe dry calcium is like concrete dip it and use a piece of wire to clean cheers
Jan 18, 2008 | Solis Crema SL-70 Espresso Machine
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Solis Crema SL-70 Espresso Machine Logo
100 people viewed this question
Top Solis Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
AZBen
AZBen
gbob59
Are you a Solis Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
