Question about Sony PlayStation Portable (PSP) Console
PSP 6 pin gen 2 cable not working on tv?
Got 5 rca jacks and only 3 ports on the tv?
Can't get color and says to play in progressive. Can't even see color on tv through psp on a movie. Need help in Iraq?
  • wrenchben122 Aug 30, 2008
    The issue here is that the component AV cable has 5 jacks, 2 certainly for audio left & right. The other 3 rca jacks all won't go into the remaining single jack on the video port of TV? Only getting black and white when playing movie and or trying to play game?
    Sergeant:
    Champion:
  • 236 Answers
You have the wrong cable. the cable you have is for HDTV's only.
by the ports on the TV, you have a standard TV.
The cable's colors are Red, Blue, Green, Red, and White. If you have a HDTV or these ports on the back of the TV, connect them like in the picture.
from what you said, it seems like your TV's port colors are Yellow, Red and White. If you only have these ports on the back (Yellow, red, white), you need this cable:
Posted on Aug 30, 2008
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
Tip
Play psp games on tv via composite/component av cable
you will need to have:
1.a psp slim with custom firmware 3.80 or 3.90.
2.composite/component av cable.
3.installer plugin file FUSA that can be sourced in the internet e.g. qj.net.
4.memory stick pro duo with 2 gigabytes capacity.
steps:
1.source the FUSA installer file.
2.once sourced,extract it to your pc desktop using 'winrar'.
3.connect pc to psp via usb.
4.upon extraction,copy or drag all four files (prx and txt) to the 'seplugins' folder on the memory stick (ms0:/seplugins/).
5.if you don't have the 'seplugins' folder on the root of the memory stick,create it.
6.exit usb connection and completely turn off psp,then turn it back on while pressing the 'R' button to go to recovery menu.
7.on recovery menu,choose and click plugins,set the FUSA plugin to 'enable',then exit recovery menu.
8.you can also activate the plugin on the FUSA menu itself,and this is better recommended.
9.connect now psp to crt tv using component av cable.
10.load a game and after loading it,just right before clicking the 'start' button to begin play,exactly at this point,simultaneously press on the volume - and + buttons to bring out the FUSA menu.
11.after a few seconds,the FUSA menu will appear on the psp screen,change the settings accordingly,exit FUSA menu and start the game to play it on your tv.
*many games or emulators will work but not all as the FUSA file is still in its beta stage,you need to figure out which one will work or not through trial and error.use caution,this guide works but no guarantees.
*used a 2 gb memory stick pro duo as 4 gb didn't work.
*used on an interlace only tv and not progressive or crt/non-flat/lcd/plastma/hdtv's.
thanks.
on May 05, 2008 | Sony PlayStation Portable (PSP) Console
My Wii U wont work on my RCA TV!
U will need to get another av ..connecter...the color cords you said..there rca jacks..then it will work
Jul 29, 2014 | Nintendo Wii Video Game Consoles & Games
I have a yamaha speaker yst-m7 but with no hookups I need all the wire
Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum 3.5 mm. stereo mini jack x 2.
3.5 Stereo mini plug cable.
RCA Pin plug cable.
3.5mm stereo mini jack x 2.
3.5 stereo mini plug cable
RCA Pin plug cable
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
May 20, 2011 | Yamaha YST-M7 Computer Speakers
How do I connect a camera to my pavilion n5430?
Follow these steps :
Identify the ports you have on your computer and video camera. Typically there will be a small door or flap at the rear or near the bottom that covers the ports. You computer may have ports in the front as well as the rear. You video camera may have more than one of these ports and may not have all of them.
Find the i.LINK port. i.LINK is
version of IEEE-1394 standard (aka) Firewire. It is commonly found on DV (Digital Video) varieties of camcorders. You may find the smaller 4 pin connector on your camera if it is a compact video camera. Typically the larger 6 pin variety is found on computers and larger camcorders. i.LINK transfers both video and audio. For more information click on "How i.LINK Works" in the Resources section.
Find the USB port. USB (Universal Serial Bus) is another connector like i.LINK for transferring digital video and audio. Typically a mini USB connector such as the "Mini-A" will be found on your camcorder than large flat "Type A" connector typically found on computers.
Locate the S-Video jack. The S-Video jack is a round 4 pin analog connector. S-Video is for only video transmission. You will need to connect the red and white audio RCA jacks or use a phono port to transfer the audio to your computer.
5
Find RCA Audio/Video Jacks. These round single pin ports usually are found in a set of three of different colors. Yellow is video, red is for right audio, and white is for left audio. On some Handycam's, there may be a mini-plug that is an all in one Audio/Video jack that you plug in a special cable (as seen in the photo) that connects your camera to standard yellow, red, and white RCA jacks on your computer.
6
Choose a matching pair of ports you have on both your computer and your camcorder.
7
Turn both your computer and camcorder off.
8
Connect your computer and camcorder with the appropriate cable. Turn on both your camcorder and your computer.
Nov 20, 2010 | Computers & Internet
Wiring a TPH553 Surface Mounted Jack by RCA.
TPH553 T568A T568BPin 1 - BL White/Green White/Orange Pin 2 - OR Green Orange Pin 3 - BK White/Orange White/Green Pin 4 - RD Blue Blue Pin 5 - GR White/Blue White/Blue Pin 6 - YL Orange Green Pin 7 - BR White/Brown White/Brown Pin 8 - WH Brown Brown
REF: wikipedia
Feb 17, 2010 | Computers & Internet
Connecting my TV and DVD player to a digital set top box
There are 4 different types of cables and they have to do with the quality and resolution of what they carry.
1) Coaxial or an RCA to RCA, 'Yellow colored connectors' - Composite video - Lowest quality of video you can get. Mostly what people hook up from their VCR's. '240 to 480 lines of interlaced resolution.
2) S-VHS cable - 4 pins - Carry Chroma 'Color' over the one set of two pins and Luminance 'B&W' signal over the other 2 pins. This is a higher resolution than the Composite video cable - 480 to 512 'still interlaced resolution' or ' i ' .
3) Component cables - RCA ends but there are 3 of them. Red colored 'for the Red video signal', Green colored connector 'for the Green video signal with Vertical sync laid on top of it,' and then Blue colored 'for the 'yep you guessed it' the Blue video signal with the horizontal carrier laid on top of the signal'.
This is the higher resolution of 720 ' i ' interlaced or even when selected by your piece of output equipment up to 1080p 'Progressive' resolution if your equipment can output this highest resolution.
4) HDMI - is a cable that not only carries the component but does it digitally along with audio and an ID bit that the Transmitting equipment 'STB' in this case should communicate with your 32" LCD HD-TV so that it will put out the maximum signal 'probably 1080P' that your TV will handle.
I would try to obtain an HDMI cable and use this to connect your STB to your LCD for the best connection between your two units.
Blessings,
A/V Media Guy
Nov 22, 2009 | Televison & Video
Digital or not????
You can get the owner's manual at;
http://www.bottomlinelcds.com/manuals/PLTV-32CM-owners-manual.pdf
You need a converter box.
Specifications
General
Dimensions
33.07"W × 25.83"H × 9.09"D
Weight 45.54lbs
Panel Type Active Matrix TFT LCD
Screen Size 32" widescreen (16:9)
Color Range 24 bits (16.7 million colors)
Max. Resolution 1366 × 768
Pixel Pitch 0.51075mm (H) × 0.51075mm (V)
Sync Range Horizontal: 30–80kHz
Vertical: 50–85Hz
Contrast Ratio 800:1
Brightness 500 cd/m2
Viewing Angle Vertical: +/–85°
Horizontal: +/–85°
Response Time 16ms typical
Inputs 2 × progressive scan component video (RCA)
3 × composite video (RCA)
1 × S-Video
6 × stereo audio (RCA)
1 × SVGA (15-pin D-Sub)
1 × stereo audio line in, 0 dBV nominal (1/8" TRS)
Outputs 1 x composite video (RCA)
1 × stereo audio (RCA)
1 × subwoofer (RCA)
1 × headphone (1/8" TRS)
Video Formats Supported SDTV: 480i
EDTV: 480p
HDTV: 720p, 1080i
TV Tuner NTSC-M, CATV, 181 channels
TV Audio Mono, Stereo, SAP
Parental Controls V-Chip (TV PG, MPAA)
Picture-In-Picture PIP, PBP
Closed Captioning CC1–4, TEXT1–4
Speakers 2 × 10W
Plug and Play Compliance VESA DDC1, DDC2B
Power Supply 100–240VAC, 50–60Hz
Power Consumption Operation: 232W
Standby: <3W
Storage Temperature 0 to 60°C
Operating Temperature 5 to 35°C
Apr 08, 2009 | Protron PLTV-32 Television
Psp connection to the TV
The cables you speak of is called component cables. They only go into color coded connection in the back of your tv. The best way is to look behind your television and more than likely there should be rows of either three or five connection and or markings saying RCA or Component connection. What your looking for is component.
Just to give you some info:
The cables you own will play vids, music, and games. But in order for the games to work you must have a HD TV.
If you see RCA jacks for your psp 2000 (slim) or 3000 (lite) than the only things will work is vids, & music (on any TV so long there is a RCA connection doesn't have to be HD).
Hope that helps.
Jan 23, 2009 | Sony PlayStation Portable (PSP) Console
I cannot get my psp slim, lite to play on my tv.
Connect the psp side to the bottom right. Connect the tv side to the corresponding input colors. Your tv needs to have progressive scan and the right inputs.
Dec 25, 2008 | Sony PlayStation Portable (PSP) Slim...
Sony PlayStation Portable (PSP) Console Logo
91 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
