Question about RCA D52W19 52" Rear Projection Television
3 blinking lights after replacing CP150, CP110, Flyback, CL031, and (2) 10 Watt 1.5ohm 5% resisters.
I have replaced all of the parts above but still only get the power light blinking three times. I know the CP110 and CP150 were bad because they had a domed top. Also upon replacing the flyback there is no longer a clicking sound from the TV. I doubt the CL031 and the 10 Watt 1.5ohm 5% resisters were bad but replaced them anyway. Everything else looks ok. What else could I try? Thanks.
  • 1 more comment
  • modeuce Aug 30, 2008
    I forgot one other thing. I have also already replaced the HOT.
  • modeuce Sep 05, 2008
    I got the problem figured out. The three capacitors that needed replaced were cp110 cp150 and cp114.
  • chrisnkaliss Feb 17, 2009
    How do you replace them?? I cant even figure out how to get it out??
  • RCA Master
  • 5,138 Answers
Your right on these sets you have to replace all 3 capacitors 2200uf 16v and two 220uf 35v.
Posted on Sep 24, 2008
  • ladywinn
    ladywinn Feb 19, 2009
    Do you still need help let me know?
Where is the horizontal output transistor exactly?
So Far You've Done Very Good, The Horiz Output Is Located Very Near Or On The Flyblack Panel, It 's Usually A Rectangular Transistor Mounted To A Very Large Silver Like Heat Sink ..It Does Sound Like It's Shorted, But If Not,Check The Focus Divider Or Hv Tripler..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Fell asleep with my rca projection tv on woke up to no picture But sound. I turned the tv off and unplugged and now when I turn it on I can here it powered up but no picture or sound. The power button...
Look for bad capaciotrs on the deflection board cp150 2200uf 16v use 25v(,cp114,cp120) bothe 220uf 35v,cp110 220uf 200v. Deflection board is the bottom lefthand side board that has FBT flyback Transfomer on it also resolder all the Pinns on the FBT.
Dec 04, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
Everything I read says if My GE Hdtv light is blinking 3 times and then going off it is the flyback. I just put a new one in. I took the board out and found CP 150 was domed real bad. Could this be the...
YES! THATS ONE OF THEM THERE IS 2 MORE IN SAME AREA THAT ALSO NEED TO BE REPLACED There is 3 capacitors 2200uf 16 v and two 220uf 35v they are Green with gold writing on them cp120 cp110? cp114,? cp150 Replace any capacitor that is puffed up on top.
Jul 17, 2009 | RCA HD52W59 HDTV Projection Television
Model d52w19 rca projection tv,will not turn on.the green power light blinks three times,but nothing happens.
Thats the eroor for the flyback and CP150 needing replacement you can get the flyback # 259296 and the CP150 at the following link and they give free step by step instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Mar 06, 2009 | RCA D52W19 52" Rear Projection Television
Rca HD52W59YX36
Thats the error for a bad flyback You will need to replace the flyback #259296 and also CP150 you can get replacement flyback and cp150 at the following link and they provide free installation instructions with pictures so you can easially do the repair yourself.
Feb 01, 2009 | RCA HD52W59 HDTV Projection Television
The power light blinks 3 times and never comes on
you need to replace the flyback 259296 and CP150 you van get both parts with free instalation instructions at the following link.
Nov 22, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch projection
I found that CP150 was bad. When looking at it, it is located on the left side board, on the right side of that board in the middle of a C shaped heat sink. When looking at the capacitor it was easy to tell that something was wrong because the top was puffed up. I replaced it with a new one (16 Volt, 2200uF) and it was working again. The part cost less than 5 bucks an took about 10 minutes to replace
Jul 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
URGENT: My RCA D52W26 Big-Screen TV won't turn on...AGAIN!
These TVs are RCA biggest mistake ,all most all of these models are shutting down accoding to information you just sneeze and they shut down, Id say try soldering around flyback transformer solder all pins.also they have trouble with ribbon connectors as well as the ribbions.
Apr 22, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
673 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
