Question about HP LaserJet 1020 Printer
Printing 8.5 x 5.5 copies continuously
I have 1/2 sheets I want to add something to. I've tried changing all kinds of settings to get the sheets to print continuously. Instead, one will print and then the printer waits as if it believes there is an 8.5 x 11 piece of paper it's printing.
Can you help me?
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
I don't know what size that is??? the closest you can probably get is setting it to Envelope size.
Posted on Sep 04, 2008
Fuzzy horizontal lines printing every 1 1/8"
Sounds like you've already diagnosed the problem.
Oct 11, 2012 | Tektronix PHASER 6180 All-In-One Laser...
Hp inkjet printing solid black page
Hi Robert, if you're trying to copy something that you've placed on the glass without closing the cover of the copier, there's too much back light (coming from behind the item to be copied) and therefore the resulting page will be black. The only light should come from within the copier itself.
If the item you're copying is bulky and will not allow the cover to close, try taking an 8-1/2 x 11 inch piece of paper and cutting out only enough of the page to allow your item (to be copied) to sit flat on the glass while covering the remaining exposed glass with the paper.
I hope this helps, good luck.
Jul 16, 2012 | HP Office Equipment & Supplies
I have an HP Laserjet 2840 and the print is off: printing from pc it prints 1 inch too low cutting off the bottom of the page. Copying from flatbed is about 1 inch off also. Copying from the feeder try it...
Fig 1:Remove the spring cut 3-4 curls & fix it back, do the same way other side also to give more tension to tray1, technic behind this alteration when solenoid leaver released, tray 1 add more force to rotate paper pick up roller assmly quickly. Add a little bit of grease to the surface see Fig2. Remove solenoid clean it fix it back Fig3
. Clean & grind surface of registration rollers to hold paper properly. Clean paper registration sensor.
Oct 10, 2011 | HP LaserJet 2840 All-In-One Printer
How to install paper in oki microline 320 turbo printer
Paper Loading
Rear Feed, Continuous Forms
Use the rear-feed path for printing on single-thickness,
continuous-form paper.
Use the single-sheet path (top feed) for graphics or charts.
! If you have paper in the paper path, be sure to remove it
before installing rear-feed paper.
1 Lock Lever
2 Upper Tractor Cover
3 Pins
4 Lower Tractor Cover
1 Move the paper lever to the position marked "REAR."
2 Grasp the tabs lift off the paper separator.
3 Pull up on the lock levers and open the tractor covers.
Then, move the right tractor to fit the width of the paper.
4 Place the first two holes in the paper over the tractor pins
on either side. Close the tractor covers.
5 Move the left tractor to align the edge of the paper with
the appropriate reference mark (1). Then, push back the
lock lever.
6 Adjust the position of the right tractor to center the holes
in the paper on the pins. Then, push back the right lock
7 Install the paper separator. Place the wire guide (1) on the
pull-up roller assembly (2).
8 Press FF/LOAD. The paper feeds into the printer.
! The factory default setting for the Top of Form (where
the printing should begin) is one inch down from the top
of the page. To change the setting, see "Using Your
Printer, Top of Form (TOF)."
Top Feed (Single Sheets)
Use the single-sheet path for letterhead stationery, memos,
and individual envelopes.
! If you have continuous-form paper in the path, press
PARK to remove it before loading single sheets.
1 Make sure the printer is on and deselected (SEL light off).
2 Place the paper lever in the position marked "TOP."
3 Open the carriage cover. Raise the paper separator to the
single-sheet position.
4 Make sure the wire feed guide (1) is secured in the sheet
5 Adjust the paper feed guides (1) for the width of the paper.
Place a sheet of paper in the separator. The paper will feed
into the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
Jan 04, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Printer is double printing on sheets for labels, why, what do I do?
Dear change your print settings it is easy and perfect solution. Take a printer properties and then go on paper settings where mentione print copies 2 change with 1 and then save settings, automatically your problem will be solved.
Good Luck
Nov 17, 2009 | Dell 3100cn Laser Printer
When I send a 2 page 11 x 17 job to the printer. It prints the first page and then comes up with an error light that asks for >> Load ppr, Bypass or Form Feed 11 x 8 1/2 Plain Recycled  << When I...
Jun 22, 2017 | Ricoh Aficio AP610N Laser Printer
My printer (HP 6310) started printing two pages per sheet in Landscape mode and shrinking it down. There must be a setting or something but I can't find it
The HP All-In-One printers have a PREFERENCES/PROPERTIES option called "Pages Per Sheet" that controls this behavior. If it was changed by someone, you can set the default by right-clicking on the printer from the PRINTERS window and selecting PROPERTIES. Then click on PRINTING PROPERTIES from the GENERAL tab and set "Pages Per Sheet" to 1.
If this helps, I would appreciate the feedback.
Dec 02, 2008 | HP Officejet 6310 All-In-One InkJet...
Canon MP730 not feeding properly.
The machine had never given trouble before, only this time when a new person was using it. So, figuring they may have refilled the paper tray incorrectly, I took out the paper guides at the back and kept hand feeding one sheet at a time. After each jam up I had to reset everything but after about 7-8 tries "something" cleared and now it works fine.
Regards BB
May 22, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Brother MFC6800 not printing
To answer more effectively - how is the printer connected to the iMac? Is it a USB connection, a printer cable, is the MFC 6800 connected to a print server, an AirPor, etc? A second question I have is if you are trying any kind of tricky printing such as manualduplex printing.
Also, a shot in the dark...Is the Auto Reduction set to on or off? To check:
1. Press MENU/SET, 2 (Fax), 1 (Setup Receive), then 4 (Auto Reduction).
2. Press the up or down navigation key (keys located above and below the
MENU/SET key) until the display shows "Reduction: ON?".
3. Press MENU/SET.
4. Press STOP/EXIT.
Another item to keep in mind:
You can use three sizes of paper for printing your faxes and
copies---letter, legal and A4. When you change the size of paper you ha
ve loaded in the Brother machine, you need to change the setting for the paper size so your Brother machine can fit the incoming
fax on the page. To set the Paper Size:
1. Press MENU/SET, 1 (General Setup), then 1 (Paper Size).
2. Press the up or down navigation key to select LETTER, LEGAL, or A4.
3. Press MENU/SET.
4. Press STOP/EXIT.
Nov 20, 2007 | Brother MFC 6800 All-In-One Laser Printer
HP PSP 2355
the only thing that can be done is to go to your printers and faxes folder and looking for your HP printer icon, right click on it and select uninstal, switch off and remove printer from the usb port Next go to add/remove programmes and look for any HP printer software listing and uninstall it and restart the pc. If you have the installation cd that came with the printer reinstall the driver and when prompted reconnect the printer to a usb port preferebly a different one than before if you have spare and continue. reset the HP printer to the default printer if not already been prompted to do so by the software and try again printing, if the result is the same the printer itself is faulty and requires servicing or replacing
Jun 24, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP LaserJet 1020 Printer Logo
43 people viewed this question
Ben Johnson
