Question about Bemis 526 300 Humidifier
Runs, but nothing comes out
I have a 2.8 Gallon Holmes Humidifier and it is great except I went to turn it on and now it runs, but nothing comes out of the top anymore. Any idea why?
  • 3 more comments
  • bgtone Oct 14, 2008
    I have the same problem, I checked the fan in the base, and it's running pretty good. It worked for a day or so, and after I refilled the tank, nothing. Please help.
  • BrianneN Oct 22, 2008
    I'm having the same problem. The fan runs, and cool air comes out of the fan and the top, but no mist.
  • jrodrig Nov 21, 2008
    It is like my water bottles keep getting airlocked, so that no water is coming out of them. The fan runs and you can feel air, but no moisture.
  • jalmt Dec 07, 2008
    I have a Bemis model 4973 which is now showing the same problem as posted on Nov 21st. The tanks get airlocked and no water comes out when tanks are inverted in the unit. It's like a vacuum is created in the tanks which prevents the water from draining into the unit. The unit runs and runs and runs but because no water is being pulled through, it simply blows air, not moist air. As soon as the tanks are inverted and plungers manually depressed, the vacuum is eliminated and the air allowed in displaces the water into the unit. This only lasts a few minutes. Besides getting a new unit, what can be done to stop me from babysitting my unit?
  • BrianneN May 11, 2010
    Any other thoughts? It worked fine for several years, just recently stopped misting, and the tank is not emptying.
There is a vapor lock when water isn't being used. Grab handle of water "jug" and move slightly up and down until air bubbles begin to rise. They should continue to do so after you replace the water compartment for a minute or two or the vapor lock is still there. I put the small cap from a hotel shampoo bottle over the piece on the bottom that is supposed to raise up the round disc in water compartment. It helps, but occasionally I still get a vapor lock and need to raise water compartment as noted above.
Posted on Feb 29, 2012
Not all humidifiers mist. If your humidifier's water tank is running dry every day or two, and the humidifier's not leaking, it's working fine.
Posted on Nov 02, 2008
    Scholar:
  • 146 Answers
Check the filters and the fan blade it may have come loose. Do you still hear the motor running? Get me the model number on the unit. Sorry it took so long to get back to you I have been sick the past few months.
Posted on Sep 06, 2008
How do I clean my humidifier Holmes hm 500? I don't have the manual anymore. Thank you! Jaimee Murphy
If you are trying to descale it of all the mineral build up. The easiest way is to mix a 50/50 1 gallon solution of Distilled White Vinegar and Bottled Distilled Water and pour it in the empty tank. Allow it to sit for a couple of hours (Longer if it's really scaled) . Then turn it ON and run it, until the tank is half empty. Then empty the remaining solution and fill the tank with Bottled Distilled Water and run until it's empty. In the future, it's better to use Bottled Distilled Water, rather than tap water.
Hope this helped you and thanks for choosing FixYa.
Aug 26, 2011 | Holmes Products HM500-UC 1 Gallon...
The Humidifier HM6600 does not working. It only runs for 5 seconds after I turn it on. It's almost new!! What shall I do???
Since the unit is "almost new", contact the customer support phone number in your Owners Manual. This way, it's covered under the warranty.
Apr 04, 2011 | Holmes Products HM6600 3 Gallon Humidifier
What happens if the humidifier runs out of water? Humidifier is new and working fine. I Does the humidifier shut off automatically when it runs out of water?
The humidifier has a float valve in it much like a toilet tank does. If the water gets to low, the float valve should allow more water to enter the tank automatically. When it reaches the proper level, the float valve stops the water. The water line (either copper or plastic) coming into the humidifier should have a shutoff valve on it. Make sure that it is turned on.
Feb 02, 2011 | Holmes Products HM4600-U 11 Gallon...
I have a brand new hm500 humidifier and when I turn it on I can see the mist being produced in the reservoir but it won?t come out the top. How do I correct this?
If you can see the mist, then, it is working. The outlet
port of your humidifier could be closed/stucked up/clogged. Please check this the outlet port.
Jan 06, 2010 | Holmes Products HM500-UC 1 Gallon...
Need Manual for Holmes Humidifier HM4600
because no one else posted the site, heres the pdf
http://www.appliancefactoryparts.com/content/pdfs/116674.pdf
Dec 21, 2008 | Holmes Products HM4600-U 11 Gallon...
Need a manual for Holmes Model HM5601.
I have a manual for the Holmes Model HM5601. If you contact me I can make a copy & mail
it to you.
My email is jadamson7@cogeco.ca
Dave
Dec 10, 2008 | Holmes Products HM5601-UC 1.8 Gallon...
Wondering if damage to Holmes HM500 humidifier is fixable...?
unfortunately running the unit for too long will permanently ruin the unit. there isn't really a way to fix it. i do deeply apologize for that. so unfortunately you might have to replace the unit.
Nov 22, 2008 | Holmes Products HM500-UC 1 Gallon...
Hm495tg
possibly calcium or other deposits from the type of water you are using in the unit..........
Feb 03, 2008 | Holmes Products Holmes 3 Gallon Cool Mist...
Will not reset
Per the operators manual you have to reset it. 1. Unplug the unit
2. Remove and refill the water tank, being sure to follow the Daily
Maintenance Instructions. Replace the tank onto the base.
3. Wait 5 minutes for the Automatic Shut-Off to reset.
4. After the 5 minutes, plug in the unit and turn the unit on to HIGH
(HI). The RESET light should now be off (if not repeat steps 1 through
3). In about 2-3 minutes, the humidifier will begin to produce
moisture.
Jan 03, 2008 | Holmes Products (048894556579) 4 Gallon...
Bemis 526 300 Humidifier Logo
444 people viewed this question
Top Bemis Humidifiers Experts
Paul Carew
Dennis
Are you a Bemis Humidifier Expert? Answer questions, earn points and help others
