Question about Coleman Mach 15 Air Conditioner
1999 toyota corolla
My car is leaking water underneath on the passenger side. Hose problems?
This problem is your heater core in the car you can change it which it is located under the dash
or there is two hoses under the hood on the passenger side that goes to the heater core your can plug them off and water will quit leaking until you have chance to change it but the heater will not work until changed
Posted on Oct 17, 2008
If you are running your ac, this may just be condensation from the air conditioner.  Do you see puddles in the winter, or when you do not run your air conditioner?  I live in a humid climate, and every summer, no matter what car I have had, I have experienced this same thing.  I have been told that it was just condensation, and as long as it was water (colorless/odorless) it should be fine.  Of course you should take it to a licensed mechanic to verify that there isn't something more serious happening.  As a temporary check, though, you might try driving around for 20 miles or so without the air conditioner on and then park for a few minutes and check for a puddle/leak.
Posted on Aug 30, 2008
1996 toyota corolla dx coolant spraying from back of engine
Hi. A big possibility is that you have a bad water pump hose. There is a short section of hose, maybe 3- 4" long that connects between the water pump and the block, attached with clamps on both ends. You can't hardly see the hose without raising the vehicle and crawling under it. It is located on the lower end of the block between the engine and firewall on the passenger side, rather difficult to get to. If it develops a leak, it could certainly spray onto the firewall. Good luck!
Aug 25, 2012 | 1996 Toyota Corolla
Radiator water is coming into the passenger side of the vehicle?
The heater core is usually under the dash on the passenger side, so you may have a loose hose or a hole in the core. If you have the time and patience to get in there, it can save you a grip of money, but it's not a simple quick fix.
Apr 20, 2012 | 1996 Toyota Corolla
1993 Toyota Corolla Dx: driving over labor day weekend, had the AC on for longer than i've normally had it on and noticed water on my passenger side floor mat. Then i looked and it was leaking from...
The drain on your evaporator core housing is most likely plugged. Condensation on the evaporator core drips down into the plastic housing and drips onto the ground through a hose on the firewall on the
passenger side.
Find the small hose on the firewall in the engine compartment. You should be able to pull off that
hose and see if its stopped up. If the hose is ok, you may need to remove some of the ac ducts
under the dash to get to the evaporator core housing to unclog the drain hole.
I have no doubt that thats the problem.
Sep 07, 2011 | 1993 Toyota Corolla
There is water the fills the floor of the passenger side of the car when the air conditioner is running
The AC condensation drain is clogged, when the AC is on water is condensed on the cold AC evaporator core (this part is what cools the incomming air), this water drains out the bottom of the heater/AC air duct, the drain is at the bottom of the firewall under the hood on the passenger side, run a coat hangar up into the drain to clear it.
May 19, 2011 | 2006 Toyota Corolla
Water leaks into the vehicle on the front,
It could be a plain old fashioned leak around the windscreen - difficult to find but try sitting in the car while somebody plays a water hose over the windscreen.
It could also be a blocked drain in the ventilation system - fresh air is normally drawn in to a car via vents at the bottom of the windscreen. These vents normally lead to a "box" like structure where any water that enters the vents drops to the bottom and then drains away via a short hose that runs to somewhere underneath the car.
If the drain outlet or hose gets blocked (by leaves for example), it can cause the box to fill with water to the point where it can leak out in to the passenger area.
Hope this helps you find the problem.
Nov 16, 2009 | 1999 Ford Taurus
2005 Toyota Corolla - car smells after rains
Look under the passenger side of the dash, behind the carpet. Feel the back side of the carpet for dampness. If so, try this: In the same area, look for a black rubber hose that comes from the heater plastic box, and pokes thru the firewall. See if it is plugged up. This is the drain pipe for the AC box, and the cowl panel if the side drains are plugged up. Try that, and please get back to me.
Sep 16, 2009 | 2005 Toyota Corolla
Water leak on the passenger rug for 2003 Corolla
well if you have water or coolant leaking on to the rug in your car, first you must remember that every car has 2 radiators. One for the Engine which is in the front of your car under the hood and one for your heater, which is usually hidden deep behind the dash inside of your car. So if you are leaking fluids on to the rug in the car; Im 90% sure its going to be something dealing with the heater radiator. What you have to do is find out where your heater radiator is on your car and check all the hoses.
Jan 05, 2009 | 2003 Toyota Corolla
Coleman Mach 15 Air Conditioner Logo
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
