Question about Graco SnugRide - Giselle Infant Car Seat
Uninstall snugride base
I installed the snugride base using latches, which obviously is very tight and has no slack. Now I can't figure out how to loosen the latches to un-install the base.
Any help is appreciated.
    Scholar:
  • 70 Answers
The straps should have a release buckle, just pull it really hard while the carseat is removed. Its a lot easier if you put all your weight on the base like kneeling down on it while pushing the release buckle toward the crease of the seat and alternating weight on the base. Good Luck, and remember, you can always cut and replace the belt if necessary!!:)
Posted on Oct 17, 2008
DO GRACO SNUGRIDE INFANT CAR SEAT BASES WORK WITH A DIFFERENT MODEL?
Some do, some don't.
From Graco's web site:
What base will work with my car seat?
We have designed many of our car seats to work with more than one base, for your convenience. Please see the chart here for Classic Connect models.
The SnugRide Click Connect 30, 35, 35LX and 40 infant car seat carriers are compatible with any SnugRide Click Connect infant car seat base. Consumers should adhere to the height and weight requirements for the SnugRide Click Connect infant car seat carriers as stated in their owner's manual; however, the SnugRide Click Connect 40 infant car seat carrier is restricted to a height limit of 32 inches when used with a SnugRide Click Connect 30, 35 or 35LX base.
Jun 15, 2014 | Graco Baby Gear
I have a 2007 Hyundai Santa Fe, the fuel door lever does not release the fuel door. What should I look at to fix this?
There is a latch inside the fuel door and it may be the case that the latch is a little bent or tight and when you hit the fuel door release the latch isn't releasing because it is bent.
Bend the latch in towards the door hinge a little bit at a time until it releases normally.
Hope this helps,
Cheers,
Dave
Nov 26, 2010 | Computers & Internet
Rear seat back not securly latching slack allows
If you want a quick and inexpensive way to fix this immediately and have it last a long time just take black electrical tape and stretch it tightly over the seat catch/latch this will take up the slack without having to try to adjust the seats while at the same time creating a cushion between the two metal latches and catches which should dampen the annoying sounds of the rattling.Hope this works.
Happy Motoring!!
Jul 15, 2010 | 2007 GMC Sierra 2500HD
Graco/baby trend frame
Download the manual, they should snap right in, I used snugride with mine. the babies should be facing you
May 31, 2010 | Baby Trend Snap-N-Go LX Double Stroller
Do we have to use the graco car seat fixing base in the car as it doesnt actually fit behind my seats and couldnt we just use the actual car seat on its own as long as it is held in with a seat belt etc,is...
You can use the base or just use the car's seat belts to hold the car seat in place. Make sure it is tight. Download the instructions from Graco or it should be on the side of the car seat on a sticker.
May 04, 2010 | Graco Snugride - Family Tree Infant Car...
Trouble removing snugride base from car
If the base was installed by someone who put their body weight on it to get it really tight, try to do the following:
If you are able, climb in the car and place your knee in the center of the seat base and put your weight onto it. Then, at the same time, try to pinch the clip end of the latch belt (the strap part that is attached to the car seat base) and push the clip away from you (toward the seat) to remove it from the metal latch loop/ring (the part of the latch system that's actually part of your car).
If this doesn't work, you can try to loosen the strap a little while leaning on the base, and then try to push the clip forward and out of the latch ring.
Aug 06, 2009 | Graco SnugRide - Giselle Infant Car Seat
Cannot tighten graco snugride in my toyota sequoia
Does your Pilot or Sequoia have leather seats? It seems its harder to get them to tighten right on leather. If it is leather, trying getting a seat saver from BabysRUs. They will give you more friction when tighting. Also tr!physically kneeling on the base when installing. I know it sounds crazy but if you shift your weight from side to side its much easier to tighten down. Good Luck|!
Oct 23, 2008 | Graco SnugRide - Giselle Infant Car Seat
Safe Seat stuck to base
Ok. You should be able to put your weight on the base to create some slack in the strap. Then push the release buckle and alternate your weight to pull the strap and loosen. Then you'll have enough room to manipulate the improperly installed latch.
Aug 25, 2008 | Baby Gear
Graco Snugride Infant Car Seat
HI! I've had 3 babies and alwyas use the Sungride! My presonal trick......First, be sure to roll up a towel (try different sizes for the perfect fit) and push it under by the seat crease (where the back cushion and seat cushion meet). Then, when you are pulling the belt to make it tighter, put your knee in it to add some weight and really get it tightened! I'm sure you'll notice a world of difference! :)
Aug 08, 2008 | Graco Snugride
Installation of Car Seat base
Try this link it seems very good http://www.aap.org/family/carseatguide.htm
May 13, 2007 | Cosco Travel Systems 01-938 Stroller
Graco SnugRide - Giselle Infant Car Seat Logo
604 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
