Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD-52525 I was wondering if you could send me the service manual. I'm trying to replace the caps. nikolaron@gmail.com Thanks.
  • xx007xx Sep 02, 2008
    same same here I need a service manual, although I have a chassis replacement manual
  • 927 Answers
Good Day;
A service manual will not help, but look for at other advice given and please respond.
Good Luck, big IRISH. PS: If again you need more info , come back.
Posted on Sep 23, 2008
The tv will turn on for 10 seconds and then power off with lamp indicator failure. The ballast and bulb has been replace the same problem model 52525 52 inch
The problem with your Mitsubishi is the Power supply board and the Digital board must be reworked. Numerous capacitors must be replaced because they have dried out or are bulged as with the power supply. If you would like to try and replace the 2 caps in the power supply first that will have to be your decision. If you choose not to a service center can send your cube off to Mitsubishi to be rebuilt for approximately $300.00 of which is a steal.,
Nov 26, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 picture problem
you didnt mention which two boards you replaced the caps on however each board in the chassis has the same capacitor issue. Sounds like you need either of the four V26 Repair kits. The FMT repair kit, The signal Repair kit, The Terminal 1 or the terminal 2 repair kit
Jun 12, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking green timer light on mitsubishi wd 52525
disconnect the connector for the front switch control board. Try turning it on with the remote. If it works replace that board, also look for bad caps on the small signal board. they're 1000Mf 16v
Mar 22, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Replacement Caps for Power board WD-52525
You can check out www.tritronicsinc.com just look for correct values VOLTAGE, VALUE, TEMP 100C or call 800-638-3328
Dec 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 air filter cover open error 33, FD connector?
connector locared on filter cover . back of metal filter .....
very small conector ........
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD 52525 mitsubishi - how to I get a copy of manual and check balist - or dm board?
you can get the service manual at the following link. Its under the mitsubishi category listed as the V26 DLP service manual.
http://servicemanuals.vstore.ca/
Sep 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
55 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
