Question about GPX MW3837 MP3 Player
CHARGING BATTERY I WANT TO KNOW HOW DO I TELL WHEN I NEED TO CHARGE THE BATTERTY.
  • Anonymous Sep 01, 2008
    I have hd no problem to date with my GPX MW2827 Player. I an not a daily user but use it about every three months to update chime and songs on our Church bell system.
    It would not turn on this morning. The monitor shows USB, I have it plugged into my computer and in the upper rright hand corner the three line indicator keeps flashing one line, two lines then three lines and repeats.
    It is recharging? How long can I expect to wait to the recharge to take effect?
    Thanks
    Cris Janson cjanson@swbell.net
  • 3 Answers
  1. your an azzhole
Posted on Sep 09, 2008
If you can please tell me how I can tell when I need to charge the battery. I also need to know the amount of time to that I should continue to charge it. Can over charging hurt the battery???
The Tablet should have a Icon, showing you Battery Life , (ie) how much you have left in battery . You can't over charge battery , as computer has safty cut off,
Mar 15, 2015 | Tablets & eReaders
Sukam 800VA not charging my battery
Check the charging voltage if you know how to use a multimeter .
if it is 13 volts then it is ok.please tell me how old is your UPS and battery.if the battery is 2-3 years then it may need replacement.
after checking the charging voltage charge the battery or some 6-8 hours promptly maintain charging .
Aug 10, 2014 | Computers & Internet
Battery problems
This is usually due to the battery not holding very much charge (when fully charged) or a fall in the voltage of the laptop battery. Do you keep it plugged into the mains much - this can dramatically reduce the battery life. If you need it to run off battery I would consider replacing the batterty pack - try ebay
Oct 07, 2013 | Lenovo Computers & Internet
My samsung 8000s battery is not taking charge
my licecnse key for ultra mp3 333333333333333
Aug 07, 2012 | Samsung Cell Phones
Will not fully recharge battery
Ifthe battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Dec 03, 2010 | Cell Phones
My 500 predator is running thru batteries like crazy. Won't start unless jumped.is there a charging prob or is the starter gone?
Hi again,
After you start the quad, you need to check the volatage at the battery. With it running at medium throttle, you should have 13.5 to 14 volts at the battery, maybe 15 volts if the batterty is bad. If you check the battery before starting, and you have the same or slightly less when running, your voltage regulator is not working or your charge coil/stator is fried. FYI, if you jump start and leave you cables or battery charger hooked up while the quad is running, you could/will damage the charging system.
Check your voltage, this will tell you whats wrong.
Nov 10, 2010 | Polaris ATV
Are accord will run fine then start losing elect. power. Unitl the car wont produce enough current to fire. We replaced the batterty and the altinator and still have the problem.
Charge the battery and put a voltmeter on it. While running the volmeter should read 14.6 volt or at least in that vicinity. Battery volts before you start it should be at 12.6 or close. When alternator is charging correctly, it should produce 2 volts higher. Hopefully this will let you know if you have good parts and then go from there.
Jan 17, 2010 | 1992 Honda Accord
I have bought a brand new Suzuki Hayabusa and ever since I have taken delivery of the same I have battery charging problems 1.The battery discharges within 10-15kms of use and the bikes stalls dead 2.Upon...
regulator problem!!....battery should charge a lot higher when throttle is rapped up to around 4000rpm...should go up to 13.5 to 14 volts then go down quickly to 13v.... no less. check for loose connections on both stator and regulator connections..clean it up could be dirty connections. a battery that is less than 12.6 volts means it needs charging,....and definately a batterty that reads only 12v volts is not good.
Oct 08, 2009 | 2008 Suzuki GSX 1300 R Hayabusa
I cant use the phone.
Is the battery in the phone charged?
when not in use leave it in its holder so that it is kept charged.
How old is the battery?
If after charging it still makes no difference then you need to buy new batterty as the old battery won't be holding charge.
Oct 14, 2008 | Uniden Cordless Phone
Charge Flashing
the batteries lose their memory and need to be shocked back to life.. Here's the fix:
"Hi,I just found a soultion on another website and it appears to have worked for me.Apparently the battery loses it memory when fully discharged,to fix this take a 9v battery and place the terminals + to + and - to - with the camera battery for 30 seconds or so then put the battery back in the camera and charge as normal.I just did this and it seems to be charging and the red light is solid.hope this helps."
Oct 03, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Top GPX Audio Players & Recorders Experts
Tequella Chapman
Level 1 Expert
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
