Question about Microwave Ovens
Need instructions for mounting spacemaker coffeemaker model ODC440B
  • 706 Answers
Posted on Aug 31, 2008
I have a GE OTR microwave JVM1460 spacesaver xl1400. I am trying to take it down. I unscrewed the two top bolts from inside the cabinet. I thought it should just swing down on the mounting strip, b
remove-ge-spacemaker-800x800.jpgRemove a GE Spacemaker
The GE Spacemaker series of microwave ovens are designed to be installed above an oven range, freeing up counter space in your kitchen. Some of these Spacemaker models are connected to an outside venting system to carry kitchen vapor and odors outside. Other Spacemaker models utilize a ductless system to do this. Removing a GE Spacemaker microwave oven isn't a difficult task, but, because of the size of some of the oven models, it is a two-man operation. Have a question? Get an answer from an appliance repair specialist now!
Other People Are Reading
Things You'll Need
  • Assistant
  • Sharp knife
  • Phillips screwdriver
Instructions
    • 1 Open the cabinet above where the Spacemaker microwave oven is installed. If you see a vent in the cabinet leading to the Spacemaker oven below, your Spacemaker is vented. This vent needs to be disconnected before continuing with removal. Disconnect the vent either by loosening the duct clamps or by cutting the duct tape away with a sharp knife. Pull the vent out of the top of the oven.
    • 2 Have an assistant support the oven from below. Loosen the mounting screws connected to the Spacemaker through the cabinet bottom. Loosen the screws by turning counterclockwise with the Phillips screwdriver.
    • 3 Unplug the Spacemaker from the socket in the cabinet.
    • 4 Continue loosening the screws while your assistant holds the oven in place. Once the screws are removed, have your assistant slowly lower the Spacemaker down by lowering the front face at a 45-degree angle.
    • 5 Feed the power cable for the Spacemaker through the hole in the bottom in the supporting cabinet.
    • 6 Help your assistant slowly pull the Spacemaker forward and out of the mounting brackets on the rear wall. Once the Spacemaker is cleared of the mounting cabinet and rear wall, set it down.
    • 7 Remove the mounting bracket from the rear wall by loosening the screws.
Read more : http://www.ehow.com/how_7344250_remove-ge-spacemaker.html
Nov 26, 2014 | GE Microwave Ovens
Need mounting bolt sizes for GE Spacemaker Microwave oven, model jvm1440bd003, thanks!
see your instruction manual. download from www.fitness.manualsonline.com or www.retrevo.com and proceed according with common sense
God bless you
Jul 19, 2012 | GE Microwave Ovens
Trying to remove an old GE Spacemaker microwave JVM140-001 and can't figure out how to detach it. I do not have a manual or installation instructions.
On some of these old GE Spacemaker models, there are two long horizontal bolts at the top (R&L corners), accessed behind the upper grill. Remove the grill (four tiny screws), take out the two bolts (flat screw heads) that attach to the rear plate, and your microwave will come right down and out, providing you've removed the three mounting bolts on the top.
Dec 11, 2010 | General Electric Microwave Oven
I need a wall mount bracket for a ge spacemaker micro, but I have no model #
To get the wall mount you need to call GE here at this #.
1-866-775-4557
GTood Luck and Please Rate
Sep 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Where is fuse located in microwave
Yes but need the model number to help you know where it is.
Aug 28, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need a mount for my ge spacemaker mkcrowave
You can find helpful exploded view diagrams and order parts by entering your full model number here.
You can download GE owner's manuals and installation instructions here.
Jul 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for otr microwave please
I just pulled my ge spacemaker xl1800 out. The mounting plate installs on the wall and two 4-6 inch bolts go through the cabinet above and into the top-front of the unit. The two top mounting holes are about 8 1/2 in. from the back of the unit and about 1 1/4 in from the side. If you don't have the mounting bracket that comes with the unit, you will have to use a 2x4 or similar to support the back & bottom of the unit.
Apr 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Need installation instructions for the spacemaker GE microwave oven model JVM164owj01
Here is the link to the installation manual. Cut and paste on the address bar of your browser. http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-40409-1.PDF It is possible to do it by yourself, but its a royal pain in the a**, so have someone available to help you lift it into place and hold it while you get the screws into the cabinet above. You could use sheet rock anchors to put the mounting bracket on the back wall, but I would really suggest getting the mounting screw into wall studs instead, even if you have to drill a hole or two through the mounting bracket.
Apr 04, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I need an installation guide for a General Electric Model JVM130K
I have the same model and the instructions at this site on how to remove it will help you. The owner's manual is useless. Good luck!
Dec 11, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Mounting this unit under the cabnet
You can usually find helpful exploded view diagrams and order parts (including mounting parts) by entering your full model number here.
Aug 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
81 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
