Question about Palm Treo 650 Handheld
Trouble sync'ing with two computers
I am trying to sync my new Palm Treo 650 to both my home and work computer. I had been using two separate Palm VII's (one personal, one office) and now I am trying to get everything into one. The sync at home worked fine, but the office computer says the user name is already being used and to try another. But that user name (my name) is what was configured on my home computer, so if I change it, it won't sync at home, right? Help!
Hiya, I manage to sync with both home and work, I upgraded to a Treo 650, and sync'd at home, then deleted my work user, and sync'd at work... and it's worked fine. I'm able to add tasks, events, apps etc either at home or work, and they successfully sync with the other machine. The only issue I've had is once or twice, my photos have doubled up, but that hasn't happened often. hth David
Posted on Apr 05, 2006
  • 537 Answers
SOURCE: Receiving MMS on Treo 650
This device should be compatible with MMS.
I found this thread which might help you set up MMS on your Treo 650. Look at the 2nd entry:
1. Start, Settings, Connections, and then tap the Connections Icon
2. Under "My Work Network" tap Add a New Modem Connection
3. Name it Picture Messaging and under Select a modem select (GPRS,3G)
4. Under Access Point Name type: wap.voicestream.com
5. Username, Password, and Domain is left blank and then click Finish
6. Now, go into Proxy Settings and check "This network connects to the Internet" and check "This network uses a proxy server to connect to the internet"
7. Under the Proxy Server box type: 216.155.165.050
8. Tap the advanced button and tap on the HTTP line. Make sure the HTTP settings shows 216.155.165.050:8080. If not, change it.
9. Click the OK button a few times to get out of the settings completely.
10.Now go to Start, Messaging, Menu, then Options, Advance, then Click Manual, and then the Edit button
11. Message center number +12063130004
12. Email center number is 500
13. MMS gateway address is 216.155.165.050:8080
14. MMS URL is http://216.155.174.84/servlets/mms
15. Finally under Network Profile select: My Work Network and then click ok.
Posted on Dec 13, 2007
cropp
  • 377 Answers
SOURCE: Outlook Calendar synchronization failed in palm treo 650
hi dear
BACK UP your Treo 650 software and data BEFORE doing the following.
1. RESET the Treo 650 back to default set by holding power buttom following by reset the treo.
2. There is a way to reset the voltage regulator in the Treo ; believe is by holding the RESET for > 3 seconds. Believe need to take out the battery in out during this process. Can't recalled the correct steps. This could could reset the Treo's power regulator.
3. TRY reinstall your palm software with minimun software or 3rd parties one, this software could be running in the back ground which drain the battery.
Try above steps might help.
Mine also got the same problem last two weeks, my treo could felt there is kind warm sensation if it took out from my waist pouch after leaving it for sometime on the table. BTW, the battery could felt quite warm also.
If yours also behave the same which I believed the Treo got some kind of contact problem which draw more power then usually does.
Now, mine got no more warm sensetion after carry out above steps. It gets better as Compared to last two weeks ago BUT not that good as compared previously when it can last 3~4 days after a full charge.
Good luck
cropp
Posted on Mar 26, 2008
SOURCE: Palm Treo 650 Unlock Code.
do u have a unlock code for your treo 650?can u share me a code so that i can unlock my treo 650 here is my messenger and email account respetadong_pogi@yahoo.com i hope you can help me too.
Posted on Aug 16, 2008
Joed911
  • 4338 Answers
SOURCE: I need to delete data on my Palm Treo 650 so I can hot sync
Follow the instructions on this link:
http://kb.palm.com/wps/portal/kb/common/article/42094_en.html#treo650
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Posted on Jun 22, 2009
  • 16 Answers
SOURCE: i forgot my code to unlock my palm treo 650 cell phone
A last resort is to hard reset the device, but you will loose your data.
See here how to hard reset.
Posted on Jul 30, 2009
Unable to Synchronize with Vista 64 bit
Treo 650 can't be synced to Vista 64 via the cable, but Bluetooth works OK. Details later (I hope).
Apr 28, 2009 | Palm Treo 650 Handheld
Can not sync palm treo 650 with vista
download active sync and install, also make sure its running on the pda itself
Jan 25, 2009 | Palm Treo 650 Handheld
TREO 650 can't see the computer
Did you try opening the hotsync manager and configuring your details?
Oct 01, 2008 | Palm Treo 650 Handheld
Suncing Media, Photos, Videos and MP3
The Palm Desktop Manager, which is free on the Palm website, can sync all your media to and from your phone. Here is the site, just choose the right OS for your computer.
http://www.palm.com/us/software/palmsoftware.html
When you sync your phone to your PC, it will ask you initially for what you want to sync. You can also do this anytime when you open up the Palm Desktop Manager on your PC. You can drag and drop your MP3s to the music folder on the Palm Desktop Manager and then sync it to your phone. This is the easiest way to get the MP3s on your phone.
You can also move photos/MP3s from your phone to your PC by using a 1GB SD card (the TREO 650 cannot accept any size larger than 1GB, trust me!). Copy your photos/videos/MP3s from your phone to the SD card and then take the card out of your phone. Use a USB Card Reader and connect it to your PC to read the SD card you just removed.
Good luck.
Apr 20, 2008 | Palm Treo 650 Handheld
Hot sync treo 650 Zip-Linq cable
i have the same F***** probelm
Mar 27, 2008 | Palm Treo 650 Handheld
Unable to hotsync treo 600 with my computer
What is happening with the Sync? Does your PC and the Palm Desktop Manager recognize your TREO 600? If not, the issue may be that somehow the driver for your device was removed. I would suggest upgrading to the latest version of the Palm Desktop Manager and try plugging in your TREO 600 again and try synching.
Here is the location for the free software from Palm. http://www.palm.com/us/software/palmsoftware.html
You also have to make sure that the setting on the Palm Desktop Manager is the same as the type of cable you are using. If it is a USB cable, have that setting on your PC's Palm Desktop Manager Hotsync settings.
Jan 27, 2008 | Palm Treo 600 Handheld
I lost my calender during a Hotsync.
Hi mikeand,
you could check the calendar on your computer using Palm Desktop application. You could restore the data to handheld only if the Palm Desktop show the data you need.
Nov 08, 2007 | Palm Treo 650 Handheld
Syncing a 600 and 650??
I have Treo 600, 650 and old Handspring Visor -- all sync perfectly well using Palm Sync Ver. 4.0.1 software.
Sep 22, 2007 | Palm Treo 600 Handheld
Intellisync problem
First, uninstall all software, Palm Desktop and Intellisync. Move the user files to the desktop. Reinstall all software. Try a sync. If this doesn't work, move the user files back to the proper location. Then uninstall all software, Palm Desktop and Intellisync. Now do a hard reset of palm unit. Try sync-ing.
May 18, 2007 | Palm Treo 650 Handheld
Palm Treo 650 Handheld Logo
80 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
