Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
4 blinks in standby/timer no picture
Please help tv wont turn on
  • 3 more comments
  • dwilliams52 Dec 24, 2008
    7 blinks standby/timer no picture
  • MarshallDill Dec 26, 2008
    SONY WEGA TV is in standby/Timer mode and I do not have any picture when I try to turn it on
  • metacumbes Jan 21, 2009
    my 3.5 yr old was turning the unit on and off a couple of times. then nothing kd-36fs130. does anyone have a diagnostic procedure for1509 and g1505? thanks
    tom
  • Anonymous May 04, 2009
    yeah.....my problem is when i tray to turn on my TV theres no picture and the timer/stand by light blinks three times and when is turned off there are 4 blinks, a rest for the blinks, then 4 blinks and again and again and again.
    Can anyone help me? THANKS
  • DvDsss May 04, 2009
    hey a got a problem with my tv.Look, i was playing a videogame just like (almost everyday jeje)and from nothing my tv just turned off;i think it was the "sleep" mode so i tried to quit that mode but my tv not turn on just hear like it was almost to turn it on but there was no picture and the "stan by/timer" light blink three times then the tv just turn off, and when its off the same light blink 4 times ,stop, blink four times and again and again.
    Can someone hel me please?? thanks
  • 2,071 Answers
Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those, which you will see for each of these faults on a diagnosis screen described later in this article.
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 (data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Intermittent problems? This is a great feature. You can also bring up these fault codes on-screen to see a list of the problem numbers with the abbreviation of the problem and the number of times this problem has occurred. This is slightly different than entering the service mode. To see the diagnostic screen, press the following buttons: Display, Channel, 5, volume Minus, ( not plus ) then Power. This brings up a screen with a list of the problems and number of times they have occurred. Each of the problems named, are abbreviated as, "OCP", "OVP", "V STOP", ETC. We have repeated them in parentheses in the text for the "Blinks" described above so you can correlate between the diagnostic screen and the blink codes.
Now that you know about these self-diagnostics, how do you use them? Say that you have a set with a black screen. You see that the LED is blinking four times. This would tell you that you have no vertical sweep, which is why the video is muted. If it was blinking 6 times, you would know that you have a horizontal fault. It's not a sure cure..
IMPORTANT: After you repair the unit, you MUST clear the values on this diagnostic screen. These codes do not reset themselves after the fault is corrected, so if you don't clear them, you'll be seeing "old" fault codes the next time you enter this screen. Clearing is done by going into the service mode (display, channel, 5, volume plus, then power ). Press 8 and Enter,
Hope this may help;
Regards,
VOTIT
don't forget to rate
Posted on Aug 30, 2008
  • sonytvissues Oct 03, 2010
    So how do you repair a 7 or High Voltage Shutdown?
Re: 4 blinks: how to I "Check IC1509, Q1505?"
Posted on Sep 05, 2008
  • nc8tn Sep 12, 2008
    Thanks for the info. It's helpful. My 1998 Sony Trinitron has four blinks. What did you mean when you say "Check IC1509, Q1505?" And, could this V STOP have been caused by a power surge during a recent storm? I.E., do you think the chances are that it has been "fried?"
cyberclash
  • 6 Answers
SOURCE: blinking stand by light
the cause of your problem is in the crt socket your tube may be weak.try to adjust the g2
Posted on Jun 25, 2007
  • 40 Answers
if u can open the tv and u can see a board in the back of the tube just loosen it from the tube and then place it in the right position it can solve ur problem if the tube is not weak
Posted on Jun 27, 2007
  • 285 Answers
SOURCE: standby blinking no picture or sound
Ok. I think you'll need an IC or a PSU.
Posted on May 24, 2009
  • 668 Answers
SOURCE: Standby/Timer LED blinking
These unit are famous for the PCB Print to be cracked around the HV Circuit and or the Horizontal Drive Transformer pins needing to be resoldered. It can turn into a very Major repair if the HV Components short. In that case the Power Supply will also short out.
Hope this helps
Skyassoc
Posted on Jul 05, 2009
virka123
  • 6 Answers
SOURCE: my sony tv has sound but no picture and red light keeps blinking
In accordance with facility to watch The Wire online,you can go through entertaining .Watch Online The Wire Season 4 Episode6 - Watch-Series watch online series The Wire season 4 episode 6,download full episodes for freeWatch The Wire Online - Full Episodes ofThe Wire & More TV Set in Baltimore, this show centers around thecity's inner-city drug scene. It starts as ... the Wire - Watch Full Episodes of TV Shows Onlinecility to watch The Wire online with blinkx Remote
Posted on Jun 23, 2010
No picture just sound
GO SETTING TAB AND FIND OPTION SET DEFAULT MANUFACTURING SETTING AND TRY
May 18, 2012 | Sony KV-35S42 35" TV
Sony kv-27v40 standby/timer blinks 5 times
Apr 23, 2012 | Sony KV-27V40 27" TV
Hope this helps
Skyassoc
Jul 04, 2009 | Sony KV-32S42 32" TV
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Stand by\timer blinks,picture go out everytime it blink .
Blinking codes meaning:
Good luck:
Dont forget to rate:
Jun 30, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA..won't turn back on
Please post the blink count. The standby light should be blinking a repeated count. That will indicate the circuit where the problem resides.
Thanks,
Dan
May 19, 2008 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
Apr 02, 2008 | Sony KP-51WS500 51" Rear Projection...
Timer/Standby light blinks but no picture or sound when power button is pressed.
I'm having the same problem. My stand-by light blinks 3 times though. The tv clicks as if it is going to turn on, but it never does. Is there a simple solution to this problem?
Dec 22, 2007 | Sony FD Trinitron KD-34XBR960 34" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
4,658 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
