Question about Sony Cyber-Shot DSC-S75 Digital Camera
DSC-S75 - The 14 bit A/D Converter
Can anyone enlighten me as to the 14 bit A/D converter? Is that an internal bit depth or an external bit depth? In otherwords, will I get to work with all 14 bits/pixel in Photoshop, or is it just used inside the camera for processing, resulting in only the standard 8 bits/pixel available in Photoshop. Thanks for your help! I preparing to make my first digital camera purchase and want to make sure I fully understand everything first! -Sean
    Master:
  • 551 Answers
To explain a little further on whether the 14-bit DXP makes a difference with the S75, it was described to me this way by a knowledgable individual: "Having a good ADC (analog to digital converter) means you can represent that larger dynamic range with finer "steps" than you would with a lower quality ADC. Typically high bit ADC's are matched with CCD's with good dynamic range. Remember, those 14 bits are at the end of the day downsampled to 8 bits to generate the JPEG/TIFF. "To answer your question a 10 bit ADC should be more than capable of doing the same job, you'd probably have to look VERY closely at a fine gradient to see any difference, and certainly downsampled to 8 bits there shouldn't be any difference." Here is a Sony chart, reproduced and enlarged to illustrate what was said above. Sony claims that their 14-bit DSP is going to produce a better image, but you will really see it in gradients and in shadowed areas. The steps should be finer, if that means anything.
Posted on Sep 11, 2005
    Master:
  • 551 Answers
All of your pics are output at 8 bits/pixel, so the 14 bits are related to internal processing. For your purposes in Photoshop, this won't really matter as you'll be dealing with either a JPEG or with a TIFF image, both of which are 8 bits/pixel. What is more important and that you want to makes sure of is that your images are well exposed, well saturated, well focused, and not overly sharpened.
SOURCE:
I have a 1998 town and country 3.8 tranny that won't go into gear. The van stays in neutral for all gears. Everything from the internals to pump to torque converter are brand new. It was rebuilt 2 times....
If the unit has been rebuilt properly in an accredited shop then a place where a problem occurs is the installation of the box in the car. It is essential that when fitting the unit that the torque converter is fitted onto the shaft and pushed back to the box to engage the pump drive before it is offered up to the flex plate and bolted onto the engine. Once the bolts have been fixed then the torque converter can be pulled forward that bit to bolt to the flex plate. If the torque converter is bolted first and then the box offered up it is possible that the pump is not engaging correctly and not working. To check this put a pressure gauge in a line to check for oil pressure in the box when running.
May 02, 2014 | Cars & Trucks
Tip
Mac Sony M2TS Converter-Convert Sony HX9V M2TS Files to H.264 MP4 on LG media...
Mac Sony M2TS Converter-Convert Sony DSC-HX9V M2TS Files to H.264 MP4 on LG media station MS450H <br /><br />I have a Sony Cyber-shot DSC-HX9, which produces AVCHD .m2ts files with 1920*1080. I record some more m2ts videos by HX9 and want to enjoy to LG media station MS450H for sharing with my family. I use <b>PS3 (Play Station 3) </b>for displaying these recorded M2TS family videos. LG media station MS450H supported formats are almost all, including MKV, DivX HD, H.264, FLAC and OGG. But LG media station MS450H does a great job with 1080p H.264 video. So I need a <b><a href="http://www.aunsoft.com/final-mate-mac/">M2TS to H.264 MP4 Converter</a></b> on my Mac 10.6. <br /><br />Now I will show my experience to <b><a href="http://sony-mts-converter.com/2011/06/mac-sony-m2ts-converter-convert-sony-dsc-hx9v-m2ts-files-to-h-264-mp4-on-lg-media-station-ms450h/">Convert Native Sony DSC-HX9V M2TS Camcorder Clips to H.264 MP4 on LG media station MS450H</a></b> for enjoying and sharing on PS3 with Full HD 1080p resolution on Mac OS X like 10.5 Leopard and 10.6 Snow Leopard. <br /><br />Step 1. <b>Capture native M2TS from Sony DSC-HX9V to Aunsoft Final Mate for Mac</b>. <br />Run Aunsoft Final Mate for Mac as the fast <b><a href="http://www.aunsoft.com/final-mate-mac/">Mac Sony M2TS Converter</a></b>, and use USB cable to connect your Camera to PC. Then follow the camcorder wizard to import videos. After selecting the Import option, you will face the window to choose the .m2ts video clips for importing to Aunsoft Final Mate for Mac. <br /><br />Step2. <b>Merge Sony DSC-HX9V .m2ts files into one movie for conversion</b>. <br />Click the drop-down button of "Add Movie" icon and choose "For Conversion" to create a blank movie. Once you've imported your video footage, drag and drop the video clips from Camcorder Tab to the blank movie in Movies Tab. In this way, all video clips will be merged as one single movie for conversion. <br /> <br />Step3. <b>Convert Sony DSC-HX9V .m2ts files to H.264 MP4</b>. <br />Click the Export button. Follow HD Video &gt; H.264 HD Video (*.mp4) to choose output format for playing on LG MS450H. The Mac M2TS to MP4 converter will start <b><a href="http://www.aunsoft.com/final-mate-mac/">Converting Sony M2ts files to H.264 MP4</a></b>. <br /><br /><b>Tips</b>: You are free to set/adjust output MP4 files parameters (Bit rate - high quailty, Frame rate - original, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. <br /> <br />When the conversion process is done, then connect the converted h.264 mp4 format with LG media station MS450H. By connecting the LG media station MS450H via HDMI with Sony PS3, you can enjoy and share full 1080p high-definition video and digital audio with family.
on Jun 27, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
Tip
How to Play AVCHD with Sony DSC-HX5V on VLC Media Player? After recording some...
After recording some HD videos with the new Sony Cyber-shot DSC-HX5V, do you want to play the videos on computer? You may face the problem that the full HD videos at 60 fps in .mts file format do not play properly, and the playback on VLC is choppy.
If the VLC media play shows the HX5V .mts video, but with pixelation or interlaces, you can adjust VLC to see if the video playback on VLC is perfect without interlacing artifacts. Just play the video as normal videos on Mac, and right click on the player to choose Video > Deinterlace and choose the options like Discard, Blen, Mean, Bob, Linear, X, Yadif, Yadif (2x).
If the above solution does not work for you, you may try Mac Sony DSC-HX5V MTS converter to deinterlace AVCHD, convert HD .mts to HD .mov, HD .mpg for VLC media player. The output HD MOV is compatible to QuickTime too. Here are the simple steps to convert Sony Cybershot DSC-HX5 .mts to HD .mov with Aunsoft MTS/M2TS Converter for Mac.
Step 1. Load Sony DSC-HX5V videos to Aunsoft MTS/M2TS Converter for Mac.
Run Aunsoft MTS/M2TS Converter for Mac as the Mac Sony DSC-HX5V MTS converter, and click the Add button to load .mts videos.
Step 2. Choose HD .mov output.
Click the Format option and choose HD Video > H.264 AC3 HD Video(*.mov) for converting .mts to .mov.
Tips: The Mac Sony DSC-HX5V MTS converter will convert 1080i AVCHD to 1920x1080 by default. If you records videos at 1440x1080, you can click the Settings button and change video resolution by choosing 1440x1080 from the drop down menu.
Step 3. Convert Sony DSC-HX5V .mts to HD .mov.
Click the convert button under the preview window, and the conversion from Sony DSC-HX5V .mts to QuickTime HD .mov starts immediately.
When the conversion is finished, you can play 1080p videos on VLC without interlaces or choppy problem on Mac. Your QuickTime will play the HD .mov videos seamlessly too. The Mac Sony DSC-HX5V MTS converter would work perfectly on Mac Leopard, Snow Leopard for your iMac, MacBook Pro.
on Jul 15, 2010 | Computers & Internet
2002 ford escape v6 with trans code p1744 and 741
Unfortunately, the possible issues are numerous. The problem is most likely either your torque converter, or electrical issues with your transmission. Without knowing how the vehicle is acting, if it's drivable, when it trips the codes, etc, it makes it more difficult to accurately diagnose.
Here is what ford says about those codes...
SERVICE PROCEDURE
The torque converter clutch may not engage if one or more of the following conditions exist:
- Stuck converter regulator valve
- Stuck solenoid regulator valve
- Stuck bypass clutch control valve
- Stuck pressure failsafe valve
- Pump bore ring groove depth incorrect
- Worn pump shaft or damaged pump shaft seals
- Pump shaft internal sleeve loose (rattles)
- Turbine shaft seals damaged or missing
- Incorrect Torque Converter Clutch (TCC) solenoid
- TCC solenoid mechanically stuck or electrically inoperable
- Damaged internal wiring harness
- Incorrect gear ratio (wrong sprockets)
- Damaged or worn stator support
- Worn torque converter hub bushing
- Torque converter clutch worn or damaged
Use a scan tool to monitor the following PID's:
- TCC = Commanded duty cycle for TCC solenoid
- TCCMACT = Actual slip across the TCC, measured in RPM
- RPM = Actual engine speed
- TSS_SRC = Actual turbine shaft speed
- TCCRAT = Speed/Gear ratio of torque converter/transaxle
Hope this helps.
Feb 16, 2014 | 2002 Ford Escape
What can I do to convert Sony DSC TX55 1080p videos to new iPad?
I have an ipad 3 and I have collections of downloaded MKV videos converted to iPad 3 compatible video formats. The program I am using is PAVTUBE Video Converter which provides presets for iPad 1, 2 and 3. The output movies play perfectly in my iPad 3. In my experience, video quality is based more on video bitrate. So please set the bitrate of output ipad video as its original value to keep TX55 video intact quality. http://www.pavtube.com/video_converter/
Jun 11, 2012 | Audio Players & Recorders
Tip
Aunsoft MTS/M2TS Converter-Convert/Edit 1080i video footage from Sony HX5V While...
While more and more people are looking for high resolution video camera with 1920x1080, Sony Cyber-shot DSC-HX5 was released in January 2010 as one of the AVCHD cameras with small size for high definition video recording. Sony DSC-HX5V records HD video in .mts file format, which is not compatible to players or editing software. Aunsoft Studio released MTS/M2TS Converter as a camera companion for Sony HX5V users to easily edit 1080i video footage to enjoy HD videos on computer.
Edit Sony DSC-HX5V .mts videos:
The Sony HX5V MTS converter enables you to merge/join/splice .mts videos into one single file. You can also trim and cut .mts videos to get the video segment you want.
Convert Sony DSC-HX5V .mts videos:
You can convert Sony .mts videos to .mp4 for portable devices like iPad, iPhone 4, Android phone, HTC Legend; convert Sony HX5V HD video to HD MOV, HD WMV for Adobe Premiere, Sony Vegas, Avid Media Composer and even Pinnacle.
Why Choose Aunsoft MTS/M2TS Converter?
- Deinterlace AVCHD .mts files from Sony Cyber-shot DSC-HX5V.
- Downscale 1080i video footage to 720p for iPad, iPhone 4, HTC.
- Convert Sony HX5V mts video to HD MOV, DV-AVI for non-linear editing software.
- Merge video clips with one click.
Download Sony Cyber-shot DSC-HV5V MTS converter to play around your camera videos. Aunsoft MTS/M2TS Converter is the perfect Sony AVCHD MTS converter for you to play camera videos, convert .mts videos to QuickTime .mov, Windows .wmv, and .mpg.
on Jul 09, 2010 | Computers & Internet
Why my motorola razar v3 phone can't hold any more song an it,an i cant put no more than 2 song on my phone
Hi, first, your Motorola razor V3mobile phone, has blue tooth and mp3 player facility to recieve and play song which is good. All motorola razor V3 phone has the capacity to receive song into the phone, but does not have the capacity to with hold much songs.Why?
Because all Motorola razor V3 phone does not have and external memory slot to accommodate more extra song on the phone, But it has an internal in-built memory to store data in the phone.
The input memory has the capacity to store data,like music, videos,pictures and so on, But the memory which is the "internal memory" of the phone only has a limited amount of data it can carry in it.
So that's why you can not put in too much data inside the Motorola razor V3 phones.
You can also put more some more music inside the phone by managing the internal memory of the phone by using a converter to convert the music files into smaller bit rate.
Normally music bit rate is always 128kb,but you can reduce it by converting it to small sizes of bit rate precisely 64kb or 32kb.
Warning!!, when you reduce the bit rate of a music,it might not have the same quality of sound it has before you converted it into a smaller bit rate.
Hope it helps.
Thank you for using fixya......
Dec 29, 2010 | Motorola Mobility RAZR V3
Cannot select a lower bit depth in colour than 24 bit?
With better processors and large storage, higher color depth is the order of the day; however if you dont want higher color depth, you can convert the images after scanning. Ofcourse it requires an addl effort.
May 21, 2008 | Canon DR-9080C Path-Through Scanner
External connection to download a laptops hard drive content
converter...
usb to serial converter or vice versa.
check out this link
Apr 20, 2008 | Televison & Video
Sony Cyber-Shot DSC-S75 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
 Russ Hill
Russ Hill
Are you a Sony Camera Expert? Answer questions, earn points and help others
