Question about ASUS Eee 4G Notebook
Drive Eee pc 4 g ? - ASUS Eee 4G Notebook
  • 129 Answers
Could you at least be bothered to ask your question without us guys trying to work out what you are trying to type! Jeez!
You just told us which one you have but nothing about the problem.
Posted on Sep 25, 2008
What is the fault when the battery light flashes orange (suspect dead batt), also the unit will not boot, nothing from the screen, and the blue power and Wifi lights are illuminated?
1. Suspect dead battery- Your battery might be dead. just replace your battery.
2. Cd-drive spin but cannot run
- solutions is -
1. Please check if the support DVD has been damaged
2. Please check if the external optical DVD drive can work normally
3. Please unplug other USB devices
4. Please disable [Boot Booster] in BIOS
4.1 Start the system and press on bootup to show the POST screen. Press again to enter the BIOS setup.
4.2 Set Boot Booster to [Disabled]
4.3 Press to save the configuration and restart Eee PC.
Alos with other solutions,
ASUSTeK Computer Inc Support Troubleshooting EEE PC 1000HE
Jan 19, 2014 | ASUS Eee PC 1000HE Netbook
Change hard disk in Eee PC 4G
its a series of chips soldered directly to the motherboard and is not user upgradable without very special equipment. Most people add USB Hard Drives or Thumb Drives to increase the storage on an EEE PC.
Feb 04, 2011 | ASUS Eee 4G Notebook
I need to restart the netbook to go back to factory settings
You will need the following items:
1. External USB DvD Drive; Can be purchased from local retailer
2. Your Asus Eee PC Restore Disk; This should have come with your netbook. You can order an additional disk by calling Asus, 888- 678-3688.
3. Once you have the above items be sure all your photos, music, documents, data etc. are backed up to a flash drive or dvd. A factory restore of an Asus netbook will ERASE all personal data on the hard drive. You must back up the data on another device in order to preserve it!
4. Connect the external DvD drive to your netbook and insert the Asus Eee PC Restore Disk.
5. Restart the netbook and boot from CD (usually the default key to boot from CD is F12).
6. Follow the onscreen instructions that are on the restore disk.
7. After installation of all software, update windows and reinstall all your necessary software.
8. Enjoy!
Jan 24, 2011 | ASUS Eee PC 1000H Laptop
I just boughtthe.. Asus - Eee PC Netbook / Intel® Atom? Processor / 10.1" Display / 1GB Memory / 160GB Hard Drive - Black and i was wondering how i would sownload software into it ?
Hi, 1)Go to the below link http://support.asus.com/download/download.aspx?SLanguage=en-us 2)Under select Product,select Eee Family 3)Under select series, select Eee PC 4)Then select your model and click search. 5)All drivers for your netbook will be shown. 6)Was this useful to you ....good luck.
Nov 28, 2010 | ASUS Computers & Internet
A new asus eee pc 1005ha boot problem
replace hard drive,
First remove 4 bottom screws, and Ram cover.
remove keyboard by pressing down on the 4 tabs across the top of the keyboard with a small flathead screwdriver. disconnect ribbon from body
once keyboard is removed unscrew the 6 black screws where the keyboard was they are the same as the other 4 bottom so do not worry about mixing.
pop open the top casing starting in the top right working your way around to the top left in a clockwise motion.
remove and replace the harddrive from here.
Find a PC install a program such as WinToFlash (freeware) and create an installable copy of Windows XP on a flash drive no smaller then 2 gb.
Put flash in USB slot
press escape as computer starts choose the USB drive
Format and install XP from flash
Mar 29, 2010 | ASUS Eee PC 1000HE Netbook
How to install belkin G router via download? Eee pc notebook has no disk drive..
I just looked up the Eee notebook on Amazon and it has a disk drive, but I might have looked at a different model. But you might just get a jump drive, download whatever firmware or such that you need and put it on the flash drive, then move the flash drive over to the Eee and upload to the Belkin router from there. Good luck!
Jan 10, 2010 | Belkin (F5D5231-4) Router
Always need disk cleanup
Open up the Computer icon and right-click on your c: drive. Then click on Properties, then on Disk Cleanup. Once this has completed, you might want to run Defrag as well, in Tools, then Defrag, then Defrag Now. You might also think about Drive Compression too, to make more effective drive room.
Oct 31, 2009 | ASUS Eee 4G Notebook
Where can I get a 4/8GB drive for my Asus EEE PC701D?
google asus EEE PC701D they will possibly give you a link to e-bay spares.note even try puting the above it may find.
Jul 22, 2009 | ASUS Eee 701 Netbook
Eee pc linux properties not working
the harddrive is the problem. 4 GB's is a small drive, most programs need space for performance. think about an other larger harddrive.
Mar 18, 2009 | ASUS Eee 4G Notebook
How to reformat ASUS Eee PC 900 notebook?
I have the linux version, not sure if you have the windows version or if it really matters. If you are looking to "reformat", you can go with the other suggestions with the USB stick. However, if you are reformatting to get back to the default settings, power on the computer and immediately hold F9. This will bring you to a screen that gives you the option to "restore factory defaults". You will lose all your previous settings, but if you were reformatting anyway, that's probably not a big concern.
Jan 13, 2009 | ASUS Eee PC 900 Notebook
ASUS Eee 4G Notebook Logo
223 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
