Question about Singer 132QRFB Mechanical Sewing Machine
Singer 2010 Machine will not wind bobbin. The needle/thread doesn't seem to be connecting with the casing. I have taken the bobbin case out and checked for foriegn matter........none, I have checked/changed the needle, I have changed thread, re-treaded the machine several times. I put a pre wound bobbin in, to check to see if this was the only problem. Stitches are not being formed. I am bewildered. The last time I used my machine, all was zinging along. Please advise Anna
  • chut_cn Oct 10, 2008
    I have same problem. it just could not wind bobbin. I checked local Hancock Fabrics repair dept. It will cost $60 for initial diagnose, then plus any labor/parts. I donot know if it is worth to repair or not. How much it will cost me in general? Appreciate any advice.
    Thanks.
If model 2010, the problem is a part metal- part plastic part attached to the bottom of the bobbin winding lever, the white tear-shaped thing with the arrow on it. If that will turn past the center of the bobbin it's broken inside. to try a do-it-yourself fix, turn upside down, remove 4 screws, including one by the plug (which must be pulled out for safety anyway) remove bottom case. looking at left end of the works, move the bobbin lever and you'll see the broken part move. The plastic part should be broken about half-way down. You can see how the part should push the white plastic bobbin winding shaft up and down when lever moved. the part can be removed by loosening the 2 tiny hexnuts holding it on the metal shaft. you'll need the smallest size allen (hex) wrench there is. NOTE where the part is at bottom of the metal shaft for when you put have to put it back on. be careful to hold the bobbin winding shaft itself in place, but it's easy to see how it goes back in if it pops out. if the break is clean (like my wife's that I just fixed this way yesterday!) you can put a drop or 2 of good crazy glue in the break, making sure lined up on the sides, then clamp in a vise (or hold firmly together with pliers) for at least 10 mins, longer better. wait at least an hour before putting back. putting back on is a little tricky but you move the bobbin lever to left (open) position, make sure it's just on the end of the shaft (shaft barely protruding) and see where the part isn't pushing the bobbin winding shaft. re-tighten with hex wrench then see if the repaired part now pushes the bobbin winding shaft up and down when you move the lever back and forth. Turn back over and move the lever without a bobbin spool- you should see shaft move up in the middle of bobbin case where it will engage the bottom of the bobbin spool where the x is.
Now if part can't be fixed it is available from auth Singer service center in you state but runs $40 or so. they'll try to tell you they have to install it because of special anti-static gloves that wont fry your motherboard on the machine's computer, but the center in Michigan finally said they would mail it to me. hope this helps! funny I just saw this after fixing our machine which hadn't been used for a long time until I decided I might as well look inside if I was going to have to buy her a new machine!!!
Posted on Nov 24, 2008
  • drmary
    drmary Oct 27, 2015
    brilliant, described my exact problem and my husband just followed your instructions to fix for me - thank you so much, really appreciative.
I have a new Singer 2010; I bought it on qvc or hsn; don't remember which. I cannot figure out how to do the fancy stitches. I tried to do the feather stitch turning the mode to A then punching in "10". It made a circle. What am I doing wrong?
Posted on Mar 09, 2010
    Sergeant:
  • 284 Answers
Its most likely out of timing.
you might have to take the bottom shielding off to see if any of the gears are worn, if so you might to replace, some places depends on where you live will do this diagnostic, singer are very good machine.
Posted on Sep 15, 2008
I'm getting an E2 error message on a Singer 8768 Heritage model.. Re-doing bobbin and bobbin placement but still getting the message.
This answer on Pinterest:
How to Fix Code E2 on Singer Fashion Mate Sewing Machine 7256 eHow
In case you are unable to view--here is the text:
The Singer 7256 Fashion Mate sewing machine has a top drop-in thread bobbin and an automatic needle threader. The digital display on the side of the machine is used to select different stitch settings on the machine. When the display reads error code E2, it means that there is a bobbing threading error, which may be caused by the thread looping or bunching under the fabric as you sew.
Things You'll Need
  • Pen
  • Screwdriver
  • Push the bobbin-winding spindle of the sewing machine back to the left.
  • Turn the hand-wheel toward you, hold the needle thread (thread on the sewing machine needle) and tug it lightly as the needle goes down and then raises up. A small loop will raise up through the needle plate on the sewing machine. Use the tip of a pen to lift the loop up through to the back of the machine.
  • Check the position of the needle. It should be seated in the sewing machine with the flat side facing the back of the machine. If it is not, remove the needle and reinsert it so that it is facing the correct way.
  • Remove the bobbin case. Use a screwdriver to turn the screw on the side of the bobbin until the loops of thread pull taught and are removed.
  • Remove any loose fibers or threads that may be stuck in the tension disks.
  • Reset the upper tension disks. Raise the presser foot lever up. Put the tension setting of the sewing machine on setting "4." Hold onto the spool of thread in your right hand and with your left, route the thread down through the tension channel, around the bottom of the disk and up the other side. When done correctly, the thread will click into place and slip in between the tension disks.
  • Set the thread bobbin in the bobbin case, with the thread passing over the top of the bobbin and then down to the right. Route the thread through the notch located at the left of the bobbin case and pull it through. Move the thread over the top of the throat plate and over to the back of the machine.
Tips & Warnings
  • Using incorrect bobbins may cause error E2 to occur. Not all plastic bobbins are the same size, so check the model number of the bobbin to ensure that you are using the correct one with your sewing machine.
  • Never turn the hand-wheel on the sewing machine away from you, as it will change the timing on the sewing machine.
Singer 8768 HERITAGE Instruction Manual Page 58
Dec 05, 2016 | Singer Heritage 8768 Electronic Sewing...
I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area under the bobbin case.
Singer Sewing Machine Needle... Repair Questions - Fixya
www.fixya.com/support/p7766091-singer_sewing_machine_needle_bar
Recent Singer Sewing Machine Needle Bar questions, problems & answers. ... 0 Answers I am having a problem with a Singer Sewing Machine, Model 6268. When I try wind the bobbin it seems as though the needle is scraping the metal area ...
My Singer Curvy 7880 will not wind bobbin. It starts to wind ...
www.fixya.com/.../t24096734-singer_curvy_7880_will_not_wind_bobb...
Apr 12, 2014 - Neec to - Singer Sewing Machines question. ... When I try wind the bobbin it seems as though the needle is scraping the metal area under the ...
I oiled my machine and cannot put the needle plate back on ...
www.fixya.com/.../t24483790-oiled_machine_cannot_put_needle_plate
May 22, 2014 - I have a Singer Sewing machine, Model #6268. .... When I try wind the bobbin it seems as though the needle is scraping the metal area under ...
Repairing a Sewing Machine ' ThriftyFun
www.thriftyfun.com/.../Machines/Sewing_Machines/Repairing-a-Sewing...
My sewing machine keeps jamming, down in the bobbin area. ... If it seems really tight, on the side of your bobbin, there should be a little tiny screw for which you .... Itried everything else first: changed needles, to a brand new spool of thread and bobbinthread, ... My Kenmore sewing machine model 158.16800 freezes.
Dec 13, 2015 | Singer Sewing Machines
Singer facilita 9858-1 top thread is winding around the bobbin case. It seems to get caught under the bobbin case retaining plate, around the left side of the case,& under the rim of the posi
try cleaning cleaning the tension disks, remember you tension setting,, take some unwaxed dental floss and go between the disc's to clean in them, and then reset the tension disc's by to normal
Dec 10, 2014 | Singer Sewing Machines
Singer touchtronic 2010
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
adjust the top tension one number or letter higher when the stitches
on the bottom are loopy, until the stitches become normal
also change the needle--flat side to the back side of the machine
check with singer website for a manual--some times they have free
pdf downloads
Go to the singer website
Click on customer support--there will be a drop down menu
Choose instruction manual
In the box type the model number( example 2010)
Click search
having a machine serviced once a year is a good idea & makes the machine last longer
and the sewing machine shop will tell you if they can get parts for the machine & if the machine is worth the money to fix it.
I myself have 2 sewing machines, when one is being serviced then I have the other one to use, so I'm not with out a sewing machine when I need one.
good luck
Debbi
May 17, 2012 | Singer Sewing Machines
Singer Sewing Machine model 9224. Bobbin thread
If you turn the handwheel, can you see a metal ring rotating around the outer edge of the bobbin case? If not rotating, broken gear or timing belt off.
If that ring is turning, remove the needle plate and bobbin case. As this ring now rotates, you will a finger on the ring that will pass behind the needle from right to left and it should catch the thread from the eye of the needle. If this finger, the "hook" passes above the eye, you have a timing problem.
Let me know.
Feb 16, 2010 | Singer Sewing Machines
I have a Singer mod 9134 sewing machine. It keeps
Try inserting the bobbin in the reverse direction. Most machines take a bobbin clockwise or counterclockwise and it can make a difference. Also try a new needle, a bad needle is often the problem believe it or not.
Nov 10, 2009 | Sewing Machines
Machine No. K1831(256) No.28 how do you set up the stop motion wheel to wind bobbins. It either winds bobbins whilst sewing or just free wheels. I think there must be a way of adjusting this action....
Oct 26, 2008 | Singer 7462 Mechanical Sewing Machine
Singer 132QRFB Mechanical Sewing Machine Logo
2,739 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
