The horizontal lines on my 42" rear projection TV are mixed up and so are the colors. Red, Green and Blue are separated.
  • 927 Answers
Good Day, 321sold;
Sounds like you have a Convergence Circuit failure, this is NOT an easy repair. I would recommend that you call an Authorized Service Center to give you a written estimate before repairs. Depending on location the price of repair can vary from $450.00 to $750.00. Good Luck, big IRISH. PS; If your handy you can de solder the STK's ( IC's) yourself.
Posted on Aug 30, 2008
How to set color, verticl and horizontal lines
Not all universal remote control's operate MENU button on TV!!!
If you have >>COLOR separation ( red blue green) and CAN NOT adjust via MENU button then you must replace conversion IC's>>
part number: STK 392-xxx.....easy repair!!
May 19, 2010 | Hitachi 53FDX01B 53" Rear Projection...
I was getting nine flashes and know the green crt
Sounds like a bad green crt. These Sonys are bad about that.
Jul 06, 2009 | Sony KP-65WS500 65" Rear Projection...
Yellow stripe across middle of the picture
yes rteh color of the wires(ends)red,blue,green,sounds like they may ahve gone bad or are interchanged, what does it do with a dvd picture
May 23, 2009 | Hitachi 42V710 42" Rear Projection HDTV
Convergence
you need to replace both convergence ICs they are STK392-110 you can get replacements at the following link with free installation instructions so you can do the repair yourself.
http://servicemanuals.vstore.ca/
Aug 23, 2008 | Mitsubishi WT-42311 42" Rear Projection...
Flashing Horizontal, Circuluar, Colored Lines
sounds like bad capacitors on the FMT board need replacing that is a common fault with the first generation DLPs There are 3 bad capacitors.
May 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
42" Rear Projection color issue
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded overs.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 22, 2008 | Toshiba 42HDX82 42" Rear Projection...
Toshiba 40pw8db with colored lines horizontally
there are some boards in the tv that plug in (push down) have the power off and unplugged have a look around, and see if any boards have come loose, stay away from any thick red wires (EHT) DO NOT PULL At the Gray Rubber Caps that go to each gun (tube) RED GREEN Blue, this can carry a heavey charge even if the tv is off and has been for days, regards mark
Mar 15, 2008 | Toshiba 40H80 40" Rear Projection...
Mixed colors and separation of colors
Common problem known as convergence. The most common reason is the failure of convergence ics. these ics fail all the time because there big and get fairly hot. there is a possiblity that it can be reconverged if the convergence cuircit is not damaged
Jan 05, 2008 | Samsung HCN653W 65" Rear Projection...
LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Dec 29, 2007 | Televison & Video
Convergence not lining up
Sounds like the green is out of focus. If the focus control for the green does not control it enough to make the width the same as the red, then, the lens on top of the green can be adjusted to focus that tube. On the lens, there is a wing nut on a screw to loosen it and move the lens left or right a bit to help with the focus. Hope this helps.
Apr 15, 2007 | Mitsubishi WS-65315 65" Rear Projection...
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
Electro Med Services...
