Canon ZR40 Mini DV Digital Camcorder Logo
Posted on Aug 30, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to record
I have a canon ZR40 mini camcorder in my hands and i can't figure out how to record anything.
Anonymous
Level 3:
  • Master 4,889 Answers
  • Posted on Aug 30, 2008
Anonymous
Master
Level 3:
Answers
4889
Questions
8
Helped
1512969
Points
14106
Checkout this manual(click here). it has everything that you ever need to know about your camera.
How do I turn on digital effect
Press the DIGITAL EFFECTS and select D.EFFECT from the Digital Effects menu. If needed, you can find a copy of the User Manual on the Canon website:
Canon Support Drivers ZR40
Canon ZR40A Camcorder. Dropped it and now there is no picture. It will replay OK, but the image recording is not working. Connected to computer it also will not capture an image. The display has a...
The best solution is to send the product back to the manufacturer for repair or replacement. If you have a receipt for the product and its within the warranty period (1 year) they will do this free of charge. I can help you with the process.
Muzu
1helpful
Can you copy your tapes to a computer?
Hello friend,
The Canon ZR40 Mini DV Camcorder has the port "Firewire" so you can copy your tapes to a computer. you will need to check your computer if it has also a firewire socket (All the new laptops have it).
You don't need any drive software, Windows has all the necessary drivers built in. You can use Windows Movie Maker for the capture, but if you want to burn your finished movies onto DVD then look at something like Adobe Premiere Elements 4.0 which is one stop shop application (Capture,edit and burn). you can download a 30 days trial and try it out and see if it's what you want before buying it.
Best Regards,
1helpful
2answers
During playback, only seee a blue screen.
kindly rate me if ui have helped u !
i hope ur problem gets solved
I press record... but nothing happens. Why?
is your disc fully insert and possition of the disc correct?
Canon zr40 stuck in pause mode
Remove the battery.   Wait 10 seconds.  Put it back in and see if that resets it.
Canon ZR40 would not turn on
The battery is probably so dead it is using all the power from the wall supply.  Remove the battery, and run only from the wall supply.
Top Canon Video Cameras Experts
NOEL
NOEL
john h
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
