I dont have a diagram but most Chefs have a wiring diagram stuck behind the lower kickpanel or underneath the warming drawer ( if fitted) The Premier was a fairly basic unti when it came out. A lot of these had battery ignition. Look behind the kickpanel or under the warming drawer for a battery box. ( About the size of a matchbox) and has a 9volt radio battery.
I have not seen fuses in these ovens for over 10 years , so I would suggest that yours doesnt have one.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
