Question about Maytag SkyBox MBV1976A Beverage Dispenser
Stopped cooling. My unit does not appear to be cycling at all, as others on this board have mentioned. I get no motor sounds at all. There is power (lights work) just no compressor noises at all. Any ideas? A service manual would also be an excellent help. Thanks for whatever you can suggest.
  • markmcwaters Aug 30, 2008
    One other comment about my unit - the fan appears to be running. At least that what it sounds like.
    Master:
  • 848 Answers
Just check the relay switch ........if fan runs then mostly problem will be with relay switch .....so better replace it .....
Posted on Aug 30, 2008
    Sergeant:
    Champion:
  • 310 Answers
This website will help u
http://repair2000.com/refrig.html
  • 435 Answers
I just replaced my in-pieces starter relay and thermal switch.
Note I had the same symptoms as other posts of the compressor turning on/off continuously (but no cooling)...I believe what was happening is that the starter relay would allow current to flow to initially start the compressor, but would never stop providing current to it after it had already started (as it should) thus in a few seconds the thermal switch would sense this and trip / remove power to the compressor...then this cycle would start all over once the thermal switch cooled down again and let power back to the compressor...
This kit is evidently the newer style of what is on the original Skybox compressors (functionally speaking)...the new starter relay looks and installs like the old one, but the thermal switch is different and you need to remove the old one (follow the black wire on the top post of the compressor back a little to a small black round thing with a flexible metal piece inside). The good news is that once you remove it, it already has the correct spade lug on the wire to plug directly into the new thermal switch which sits right on the top lug of the compressor above the starter relay.
Note I'm not a service tech, just a Skybox owner who was/is tired of Maytag disowning this product and calling it a "throwaway" when any part of it stops working (and all local authorized service centers laughing when asked to repair one).
Continuing on with my rant a little, I also see other posts on the internet which also state "throwaway" when you actually have a bad compressor because you can't get direct replacements anymore - my friend who does AC work on the side said he most certainly could put another compressor in there from probably just about any other mini-fridge...he just noted that it is a small place to do it so the replacement compressor form factor will have to be considered. He stated you may get a little more or less cooling efficieny but who cares if you really want to keep your machine working that you can't buy anymore (nor get a close alternative).
    Genius:
  • 1,011 Answers
Sir,
Please provide your Model No.
thanks
  • Asfiya Ahamed
    Asfiya Ahamed Aug 30, 2008
    Sir/madam,
    You need to replaced the thermostat.
    thanks
    good luck
  • Maytag Master
  • 19,396 Answers
  • Ginko
    Ginko Aug 30, 2008
    If it is not cycling and there is notpower at all check the power cord and socket.
    If it stopped completely:
    "First,
    check to see if the light comes on or if there is any fan, motor, or
    other sound coming from the appliance? If so, the refrigerator isn't
    really completely stopped--go to the specific problem you are having.
    If not, try adjusting the thermostat to a colder setting. If that
    doesn't work, read on.
    Second, check to see if there is power
    getting to the refrigerator. To do that, plug a lamp or other device
    into the same outlet the refrigerator is plugged into. If there's no
    power, check the fuses or circuit breakers. If the fuses or breakers
    aren't the problem, contact a qualified electrician to restore power to
    the outlet.
    If there is power to the appliance but it still seems to be stopped, there may be a problem in one or more of these:
    • Wiring
    • Thermostat
    • Defrost timer
    • Compressor
    • Overload and/or relay"
    If it is on but it is not cooling at all then it is the compressor.
    See more hints from Repairclinic.
    "If the refrigerator isn't cool, you need to answer some questions, then see if the compressor is running.
    First, answer these questions:
    • Is the refrigerator completely dead? If so, see “It's stopped completely.”
    • Is the thermostat knob turned to the proper setting? If not, reset it.
    Next, see if the compressor motor is running
    The
    compressor is a football-sized case with no apparent moving parts. It's
    on the outside of the refrigerator at the back near the bottom. If it
    is humming or making a continuous noise and your refrigerator is still
    not cooling, there may be a more serious problem with one or more of
    several different components, we recommend contacting a qualified
    appliance repair technician for further help.
    If the compressor is not running but you do have power to the refrigerator, there may be a problem with one or more of these:
  • The compressor
  • The Thermostat
  • The overload, relay, or capacitor
  • The defrost timer
  • The condenser fan motor"
  • Ginko
    Ginko Aug 30, 2008
    I have a Goodman Heat pump system Model ARUF061-00A-18 And the Blower wil work in the Heat mode but not in Cooling.
    Sounds like a bad relay. Unfortunately that relay is on a circuit board. You can bypass the board, I will help you if it's actually the case. But, to test it, turn power off to unit, on the circuit board you will have a relay(In the indoor unit) on this relay you have three wires, swap the two wires that are right next to each other. You will see 2 wires very close to one another and another off to the side. Swap the 2 that ARE RIGHT NEXT TO EACH OTHER. Turn power back on to unit. This should make the fan run non stop all the time. If it does let me know.
    Jun 03, 2017 | Goodman Heating & Cooling
    The control board won't do anything. It is lit up but the incline and speed display are just dashes and the other lit up section is just constantly running lights around it.
    Hi There, you didn't mention a make or model? It sounds like the motor control board has died. Has the deck been lubricated lately?
    Does the console appear like it's working but no belt movement?
    Fitness Remedy in Sun Prairie, Wis., repairs most brands of control boards.
    Nov 09, 2015 | Exercise & Fitness
    GE bottom freezer stopped cooling
    The unit needs two fans running and good airflow, one fan outside cools the condensor coil and the other inside the unit blowing across the evaporator. The compressor must start up. The defrost timer stops everything and switches on a heating element to defrost the evaporator for several minutes. Please verify these conditions.
    Jan 24, 2015 | GE Profile PGCS1NFZSS 20.7 cu. ft....
    GE bottom freezer stopped cooling sporadically every 1-2 days then cools again with no intervention. Unit is 5 yrs old.
    Put the old board back in. See what it does, from your post, sounds like it was working correctly.
    Remove c-24 errorminolta di450/500
    Sir/Mam,
    C0F24 Code is the code for the sensor that monitors the drum. I would remove the drum cartridge two black screws pull out the drum assy. Remove the drum be careful do not nick or harm the drum the sensor is located on the left side of the to the rear of the of the drum looks like to little eye of a bug. Dust with a brush NO VACUUM static could destroy it. Re-install drum and re-install cartridge. When the last time a PM was done Developer replaced and Drum replaced?
    Dec 14, 2014 | Minolta Office Equipment & Supplies
    Bryant furance cat.# 333BAV048080, with A/C cooling selected, blower motor during high speed operation stopped running, but the outside A/C unit was still running.Check that the motor is free wheeeling....
    Hello, sincebthe motor will not run in heating and cooling the first thing to do is check the capacitor, set your meter to ohms and disscharge the capacitor with a screwdriver, if the capacitor is good the meters numbers should ramp up and down, if not the capacitor is bad. To check the motor turn off power to the unit and take you meter and measure from the common wire to each other wire coming from the motor, you should have resistance,if not the motor is bad and must be repalaced. To check the board place one meter lead on the cool/high speed motor tap and the other lead to ground, if therebis no power on a call for cooling the board is bad.
    Jul 11, 2011 | Heating & Cooling
    Frig stopped cooling. Bad condensor Fan Motor.
    sounds like a bad thermostat,that tells unit when to kick on and off.
    May 15, 2009 | Maytag Refrigerator Light Switch -...
    Carlton dishwasher stoped working power still on just stopped mid cycle
    Hello gracepat,
    Welcome
    You only said,Carlton dishwasher stopped working power still on just stopped mid cycle
    What is the MODEL number and Year?
    Try turning off the breaker for 5 minutes and see if it resets the system!
    Possibly
    FIlls but Does Not Wash or Drain
    Faulty Pump and Motor Assembly
    GE models that will not wash or drain often have a faulty Pump and Motor Assembly. If the motor is receiving power from the timer and it is not operating that is the case.
    Temporary Work-around:
    With the power turned off to the unit, sometimes it is possible to manually rotate the cooling fan on the motor assembly. In certain situations where the dishwasher has set idle for a period of time, this may free the bearings enough that the unit will begin to operate. Where this works as a short term solution in some cases, it is often a sign of things to come. The frequency of the motor seizing will increase until it will simply no longer work
    Waiting your response and if it reset the system?
    Huuum
    Please remember to leave a rating
    Oct 22, 2008 | Dishwashers
    Side by side stopped working but clicling noises every second two.
    Ok the motherboard is malfunctioning. Ive observed this exact problem before. Replace the board and all will be normal again. If you keep lettig it click and click it may finally kill that relay that you descibed to me or even worse the compressor itself.
    Dec 02, 2007 | GE GSL25JFR Brushed Steel Side by Side...
    Frige not cooling and click noise.
    Sounds like a relay is chattering on the board. First thing would be to change that circuit board, it controls pretty much the whole unit. Make SURE the clicking is coming from the board and NOT the compressor though! See item 801 below http://www.partselect.com/Schematics/GE/00118404i08.gif
    Feb 05, 2007 | GE GSH25JSRSS Stainless Steel Side by Side...
    Maytag SkyBox MBV1976A Beverage Dispenser Logo
    159 people viewed this question
    Top Maytag Retail Supplies Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    Are you a Maytag Retail Supply Expert? Answer questions, earn points and help others
