Question about SkyScan 86742 Digital Atomic Wall Clock
3M Precision Digital Atomic Wall / Desk Clock with Indoor & Outdoor Temperature and Alarm will not display outdoor temp, i have replaced batteries, outdoor sensor is transmitting, does not appear to "sync" with receiver
  • THOMAS DRESSLER Nov 07, 2008
    NO OUTSIDE TEMP READINGS
  • Anonymous Apr 23, 2009
    DOES NOT SOLVE MY PROBLEM. ANYONE ELSE?
  • 3 Answers
After replacing the transmitter batteries several times, I tried replacing the clock batteries. They must have been getting low. Once I put in new batteries in the clock it worked fine. Good Luck.
Posted on Jan 15, 2009
Make sure the batteries are new for both the clock and the outdoor temperature sensor. Put the batteries in the outdoor sensor first. Wait to see the temperature reading on the sensor. Then put the batteries in the clock. In about 15 minutes the outdoor temperature should show on the clock.
Posted on Sep 11, 2009
SOURCE:
Replacement Outdoor Temperature Sensor for Atomic Clock
Search the manufacturers website and ebay. It may require a little time and effort.
Jan 02, 2018 | Home
OUTSIDE TEMP SENDING UNIT GOT WET AND WILL NOT CONNECT TO CLOCK. HOW CAN I FIX OR HOW CAN I REPLACE?
[PDF]WS-8117 ATOMIC CLOCK WITH OUTDOOR WIRELESS ...
https://www.lacrossetechnology.com/products/.../misc/8117-manual.pdf
NOTE: Do not set the clock until the outdoor temperature is displayed. .... The unit will still try and receive the signal every day despite it being manually set. ..... sunlight, extreme cold and wet/moist conditions as these will lead to rapid changes ... Beforesending the atomic clock in for repairs, contact La Crosse Technology.
La Crosse Technology Top Solutions
https://www.lacrossetechnology.com/support/top_solutions.php
A: Complete a restart for display with the temperature/humidity sensor: ... to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing ... Products set outside of these time zones will not search for a WWVB signal as it is ... locate the Clock or Weather Display near an outside wall and point the unit in ...
Common issues weather stations: Click Here
www.weather-station-products.co.uk/faqs/common-issues-weather-stations
Under £30 £30-£75 £75-£125 From £125 Birdhouses/Feeders Outdoor Clocks ... I'mnot getting any outdoor readings from my outdoor sensor, what do I do? This willcure 90% of all sensor connection problems, important you must ... is the airtemperature, to get this reading you need to place the unit away from direct sun.
Replacement Temperature Sensor ' AcuRite
www.acurite.com > All products
Dec 16, 2015 | Audio Players & Recorders
My outdoor temperature shows three lines I have change the battier as manual said, but it didn't help? Do you sell replacements?
Fixya does not sell anything. The replacement batteries in the outdoor unit could be defective or installed incorrectly. The battery replacement procedure in the instructions must be followed exactly, i.e., batteries replaced in the outdoor unit then allowing time for the outdoor unit to begin sending data before installing batteries in the indoor unit to get an external temperature readout.
Oct 09, 2014 | La Crosse Technology Ws-8418u-it Atomic...
Skyscan atomic clock problem
Look carefully at the back of your clock for a reset button. The temp may have encountered a problem and stopped working. Also, be sure the battery is fresh. Hope this helps.
May 31, 2014 | SkyScan 86709 Atomic Wall Clock
WEATHER STATION AC100MB stops transmitting outdoor temp
I have experienced the same with numerous different, "quote un quote" atomic clocks! Please don't forget that this sender unit, that goes outside, generates a RF Singal to be received by the clock inside. This unit transmits a signal 433 MHz signal approximately every. 3 minutes, and after so many years the sender unit's RF section(electronics) just goes out or no longer function properly or not at all! The transmitter/sender for this model number, according to "3M" is obsolete and can no longer be furnished, DRATTS !!!!!
Mar 20, 2012 | 3M Measuring Tools & Sensors
The wireless transmitter doesn't work
Mine quits working when the batteries in the outdoor part need changed .
Dec 15, 2017 | Centrios Audio Players & Recorders
Remote sensor does not work after installing new batteries
Double check the batteries to make sure they are installed correctly. If one of the batteries in the outdoor sending unit is in backwards, it will not send the outdoor data. On the indoor unit, there is typically one battery that is used for receiving the signal from the outdoor unit. If all of the batteries are in correctly but that one, you will see the display and the indoor temperature information, but the outdoor information will not be displayed.
Oct 15, 2010 | ATOMIC Digital Wall Clock With Temperature
My clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Nov 16, 2009 | SkyScan 86709 Atomic Wall Clock
Outdoor transmitting
These devices have a limited range, normally 20-30' (~6-9m) and that range is influenced by the material that separates them. Any metal structures in their path can shorten the useful range. Also, I think all of these transmit only a second or two every few minutes to conserve battery power.
Mar 03, 2009 | SkyScan 86742 Digital Atomic Wall Clock
3m precision clock lost instructions
HOLD SET BUTTON UNTIL ITEM YOU WANT TO CHANGE FLASHES. USE + AND - BUTTONS TO CHANGE ITEM . PUSH SET TILL IT RUNS ON.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/thomas_6b90afb985d8f4bd
Oct 25, 2008 | SkyScan 86742 Digital Atomic Wall Clock
SkyScan 86742 Digital Atomic Wall Clock Logo
2,430 people viewed this question
Top SkyScan Home Experts
Dave Robertson
Level 1 Expert
Are you a SkyScan Home Expert? Answer questions, earn points and help others
