Question about Kenmore 24032\24036 Top Load Washer
Water dont drain
When the sicle gets to the drainning part it just stop and then noting, it just dont drain.
  • 2 more comments
  • Anonymous Sep 03, 2008
    maytag top loader / heavy / duty / commercial quality / stainless steel tub
  • Anonymous Sep 06, 2008
    You are the man, it was the screws that came loose. Once I fixed that, the washing machine starting working like a champ again. Thanks!!
  • brblbabe Sep 06, 2008
    The washer filled up like normal and then nothing so I tried different parts of the dial; tried unplugging and re-plugging 10 minutes later; checked breaker switch (switched it on and off); checked connection to closing mechanism to start washer; etc. - cannot figure out the problem.
    Can you help?
  • letard Sep 13, 2008
  • 5,911 Answers
It sounds like you could have a lid switch malfunction. This is a common occurence when the switch wears out. The switch may be loose or not making good contact. As you open and close the lid, you should hear a "clicking" sound as the lid switch is activated. If you do not hear the switch, check to make sure the lid strike (if equipped) is still intact. This is a small plastic piece mounted on the lid of some washers that pushes down on the switch through a slot on the wash tub opening on the right hand side. If this piece breaks off, it will give the same symptoms of a broken lid switch. Next, check the two mounting screws on the right side of the wash tub opening to make sure they are tight. These are the mounting screws for the lid switch. Sometimes they come loose and the switch does not make proper contact. If you attempt all these preliminaries, and the switch still does not seem to be working properly, replace it.
Replacement parts can be found at searspartsdirect.com. Just type in your model number (located along the wash tub opening under the lid) and the lid switch will be located under the "Top and Cabinet" heading. The lid strike (if equipped) is listed under this heading as well. You may also check repairclinic.com. They carry the SAME parts and sometimes offer a better price. For instructions on how to replace a lid switch, click on the following link:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a simple and inexpensive repair if you wish to accomplish this on your own. Let me know if you require addtional assistance. I hope this helps you.
PS You do not have to drain the wash tub to replace the lid switch. With the switch repaired, the washer will drain on its own.
Posted on Sep 01, 2008
  • Jeff Rockwell
    Jeff Rockwell Sep 13, 2008
    Has the advice given you a solution to your problem or do you still require assistance?
Machine is set to drain out, but Drain Light wont stop flashing
sounds like the drain is plugged and wont drain all the way check the drain line and see if it is clogeed with something
Nov 20, 2014 | EuroTech EDC158 Electric Dryer
Kitchen aid KUDP021R does not drain
test this steps and fix it. God bless you
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#3#ixzz2aaqbXzEw
Jul 30, 2013 | Dishwashers
Get f21 message on machine. Machine start sicle and stops half way
“F21” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Jan 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a 1 1/2 year old Frigidaire in a rental property. The tenant mentioned a bad odor problem in the kitchen. What we found was a nasty growth of something in the drain pan and in the drain itself was a...
There are no brown liquids that any components of the refrigerator can create. There is refrigerant (colorless gas), refrigerant oil (light yellow oil), and clear water from the icemaker, if it has one. Remember that the drain water is from the freezer section, so a melted fudge-sicle in the freezer would get mixed in with the ice that was melted in the defrost-cycle.
Nov 02, 2009 | Refrigerators
Ge quietpower 3 wont turn on
HI. check the following areas for faults.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer or Control Board
Aug 05, 2009 | General Electric Adora GHDA670N Built-in...
It's still full of water !
HI. check the following areas for fualts.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 21, 2009 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
ADP 4502/5 not working,not draining water,start
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jul 13, 2009 | Dishwashers
Dishwasher stops after 10 minutes inlet/drain light flashing
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
May 31, 2009 | Miele 24 in. G646SC Plus Free-Standing...
Dish washer wont drain
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Feb 02, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
BOSH won't stop draining
take your dishwasher out and look for a water at the base of your dishwasher.
If that is a water at the botton base, just dry the water and its ok.
if you dont find water at the botton base inside replace the water level system PN= 263834 at repairclinic.com, item# 935595 for 41.00 and that part goes in the left side of your dishwasher
May 24, 2008 | Bosch 24 in. SHX46A05 Stainless Steel...
Kenmore 24032\24036 Top Load Washer Logo
48 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
