Question about Sony CDX-R3300 CD Player
How do ya work this thing?
Hello, I just bought a used truck with a Sony Xplod CDX-R3300 in it. I was listening to the radio and turned up the volume on a good song and volume went through the rooof! In an attempt to keep my ear drums from bursting and blowing the speakers, I turned the unit off by pushing off button in upper right hand corner. Now I cant get the unit to power back up. What do you press to start it up? How do you eject a cd?When you push face plate down it says " eject" with small arrow but what do you actually press? Read where it plays mp3 music? Can I play my ipod Nano through stereo without buying an after market adapter?
  • t6881 Jan 25, 2009
    I have the exact same problem. Pushed the off button and can't get it to start.
I had the same problem. I would just take the face plate off and put it back on, shift it around a little and after a couple DAYS of doing this it would start working again. It did this to me about once a month. Also to eject, slide the eject bar down so its covering the screen, then slide it down til it clicks, wait until the CD comes out before you slide the bar back up.
Once your player has started doing this volume this I suggest getting a new one altogether because it will drive you crazy.
Posted on Nov 12, 2009
  • 3 Answers
Press the SOURCE button "Bottom left of Row"
Posted on Mar 13, 2009
Where does the remote wire for amp go to on sony xplod cdx gt520
their should be a blue white wire on the back of the radio. this wire is called the amp turn on wire connecting to this wire will provided 12 volts when the xplod cdx gt520 is turned on but if you press the off button on the radio the 12 volts will drop to 0 volts but when the radio is turned on the 12 volts will come back.
Aug 01, 2011 | Sony CDX-GT520 FM / AM Receiver
I turned the volume up the other day and it got stuck, it kept getting louder and louder. I turned it off, but now I can only use the CD player. I can't change the volume on the CD player. I also can't use...
You need to free the stuck switch. As long as it is jammed, it is going to send a signal to the microprocessor. The microprocessor can only handle one command at a time, so while the volume up switch is sending a signal to it, it will do nothing else.
Apr 07, 2011 | Sony CDX-R3300 CD Player
I recently installed my sony xplod to my jeep and the radio, volume works fine. when i insert a cd, i hear nothing, counter and track displays but no sound...please help
are you using an amplifier? if so, it sounds like you are using the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) to turn the amplifier on.
Feb 17, 2011 | Sony XPlod CD Player w/MP3 Playback...
When I turn off my truck and the blue lights on, it turns off but when the radios on and I turn the truck off the radio does turn off unless I hit the off button! Help sony xplod cdx-gt640
do you mean the blue light on the power button? it sounds like your radio's switched power input (usually red) is hooked up to a 12 volt constant source.
Feb 22, 2010 | Sony XPlod CD Player w/MP3 Playback...
Where can I find a manual for in-car sony xplod cdx-r3300?
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXR3300
Feb 11, 2010 | Sony Car Audio & Video
Turning off sony cdx-gt170 display
Hold the volume button down until the clock setting comes on. Then press the same button until you see "Demo:On" on the screen. Turn the volume either up or down to change the setting and then hold the volume button down until you see "AUX" or "TUNER" on the main screen again.
Mar 15, 2009 | Sony Car Audio & Video
Poor sound
Sit low Bass @+3 / Mid@ 0 / Hi+10
Add SubWoofer with separate Amp and use low pass filter @78hz cuttoff.
It's a cheap unit -don't expect High Fidelity & a warm EQ<
Nov 19, 2008 | Sony CDX-R3300 CD Player
Sony cdx r3300 Won't play...simply scrolls a message
_half fixed, use the remote -@least can get more life outa the unit!
Nov 11, 2008 | Sony CDX-R3300 CD Player
Ipod connection
Sorry that is the only way to do so with your radio because you do not have the input to do it
Nov 01, 2008 | Sony CDX-R3300 CD Player
How to set time on sony CDX-GT50W
press and hold the volume control dial. when a menu appears press the volume control button until clock adj appears. then press seek to change from hours to minutes. to adjust the hours and minutes just rotate the volume control dial
Apr 22, 2008 | Sony Xplod CD Player w/MP3 Playback...
Sony CDX-R3300 CD Player Logo
555 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
