Question about Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense...
Ice maker would not stopp making ice so it overflowed. I turned off the switch. now it won;'t make any ice.
    Sergeant:
  • 409 Answers
please provide the brand and model # off your fridge.
thanks
Posted on Sep 25, 2008
Ge pfs22mis ice maker won't stop
Hello:
No real fix here, just a design flaw..
Try switching ice maker on /off switch until you ready for more ice..
Cheers
Jul 15, 2017 | GE PFS22MIS
Frigidaire PLHS67EESB0 ice maker stopped not making ice and the ice ejector keeps turning and the machine keeps filing with water and overflows
If the ice ejector turns constantly, and water flows with each turn, you have a bad limit switch inside ice maker. This switch stops the motor inside, and thus the ejector, and allows for a freeze cycle. There are other possible problems but i suggest just getting a new ice maker. Not that hard to change out if you have any mechanical skills.
Oct 12, 2013 | Frigidaire Refrigerators
How do I get my my GE refrigerator model no. GSS201EPJWW to stop making ice? Bin fills with ice but don't know how to turn off icemaker. Thanks
slide the panel out from in front of the icemaker,there is a slide switch on the icemaker marked on/off
Jan 11, 2013 | Refrigerators
Fridge freezer door won'tstay closed
Faulty door seal.The seal that holds the door has a grip and a magnet on other side.May be that needs to be replaced.Or any fringe section tray is not completely fitted,to its end causing these.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 24, 2012 | Frigidaire Refrigerators
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
Ice maker will not stop making ice
You didn't state what make and model fridge you have. But most newer units now use an optical eye system, and when the ice blocks the eye's beam it stops making ice. If you've turned the switch to off and it still makes ice, then you need the unit serviced.
Hope that helps...
Geno
Apr 04, 2008 | Refrigerators
Water doesnt stop after ice tray is filled
there is a micro switch in the ice maker motor module that shuts power off to the ice-maker water valve when the ice maker is full but i rarely see them go bad this is the easy way to deal with it pull the unit out unplug both the valves and turn the water on a sec if its running in the ice maker with the valves are unplugged then replace the valves if its not replace the ice-maker motor module
Mar 28, 2008 | Kenmore 21.7 cu. ft. Side-by-Side...
Water dispenser
wow that's agood one!!!! theres a short for sure, just a matter of where. somehow your energizing both sides of water valve at once, sounds as if it would be behind the dispensor, at the switches. would remove the dispensor cover and have a look for a bad switch or exposed wire
Mar 08, 2008 | Refrigerators
Kenmore 9550580 ice maker
try turning down water pressure or reduce flow into ice maker by turning tap partially off, this should resolve problem. Regards Advisor
Aug 23, 2007 | Kenmore 73952 / 73954 / 73959 Top Freezer...
Frigidaire Gallery Series GLHS269ZDB 36" 26.0 Cu. Ft. Side-by-Side Refrigerator w/ 7 Button Dispense... Logo
152 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
