Question about JVC Audio Players & Recorders
We've had a JVC RX-5042S for a few years now and never a problem. All of a sudden we're getting "overload" all the time and the volume isn't even high! We're using the original speaker wire supplied with the system but am going to rewire with better wire just in case. Is there something else we can do?
  • BIGWETDOG Oct 15, 2012
    i had the same issue. audio amp IC was replaced with a few other components and now i only have audio output on one speaker output. the rest have no audio output at all. now what's wrong.
  • Thabo Cavon Seema
    Thabo Cavon Seema Feb 03, 2016
    Mine also display overload even thou nothing connected and i guess it was damaged due to i used high output audio from a computer sound card to my JVC RX-5042S DVD input jack.
    I don't what to replace either IC?
    Genius:
  • JVC Master
  • 1,550 Answers
The audio amplifier IC are damaged
Posted on Aug 30, 2008
JVC 6010V shows zero on volume wont go up or down
This is a fault on the D/A digital / Analogue converter , The volume control being analogue is not processing the data in the cicuit and so there is no change in the level. This can be a fault in the IC - the D/A convertor IC which is not giving any response with the turn of the potentiometer. So check this within the amplifier ONLY if you are able to trace the circuit and replace the IC connected to the potentiometer.
Oct 21, 2011 | JVC RX-6010V Receiver
Overloaded. When watching movies or dvd's or TV my receiver will shut down and it says "OVERLOADED". It happens when I have the volume at 50 or more. Am I underpowered? What do I need to do?
your probably overdriving your speakers. unit will detectand set overload when it gets hot or your speakers start to disort out. most amps is at full volume at half volume anyways
Sep 29, 2011 | JVC RX-9010V Receiver
Hello. I have a JVC RX-6042 and when I play music, DVD's or any other sound, it cuts out, either after 5 seconds or 5 minutes, it always changes. It cuts out faster at higher volumes. A few months ago it...
Generally speaking, an amp protects itself from heat, shorts and overloads. I'm thinking heat.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Feb 03, 2011 | JVC RX-6042 Receiver
On our JVC RX-6030V When we try to play a CD we the receiver flashes "overload then shuts down. Is the receiver done, or is there a fix for this?
Only when playing a cd?? If it does it all the time it probably needs repair of one of the output channels. $80-$120 parts and labor. If it only does it on cd it would be very odd.
Jan 26, 2011 | JVC RX-6030V Receiver
I have my jvc rx-778v that always overloads. why is that?
There could be a couple of reasons that its overloading one is make sure that there is no bare wire touching at all.The other thing it could be is the ohms rating over your speakers may be to low for you receiver.Most receiver can handle 8 ohms to 6 ohms there are a few that can handle 4 ohms check your speaker ohms rating then check how low your receiver can handle with out going into overload.
Sep 25, 2010 | JVC RX-778V
JVC - Problem connecting a Powered Subwoofer to a Receiver
Have you set speaker setup configuration to SUBWOOFER YES? Also check SUBWOOFER OUT ON/OFF button on the front panel.
Feb 20, 2009 | Pioneer VSX-D511 Receiver
Jvc receiver OVERLOAD
possible short across speaker wires somewhere or even inside speaker
Dec 21, 2007 | JVC RX-6000V Receiver
JVC RX6040 OVERLOAD TROUBLE
clean your volume control if that does not help take it to a tech for repairs.
Mar 29, 2007 | JVC RX-6040 Receiver
JVC RX-7000V
As per the instruction manual the overload is there because of high volume condidtions and your over heating the unit. They recomend to turn down the volume shut off the reciver wait a few minutes and turn back on the unit with lower volumes. Second it states that the peaker wires or speakers could be shorted so make sure the speakers are good and the wires when you connected them to the reciver are not shorted. If all is hooked up properly then you have a problem in the output stage of the amp and its gonna need service unless you know how to replace the defective output devices? If not Go online at the addy I give you to find about service parts or service manuals.. Good Luck http://www.jvcservice.com
Apr 23, 2006 | JVC RX-7000V Receiver
355 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
