Question about Kenmore Elite HE4 Electric Dryer
HE5 dryer I read your postin regarding your dryer. I am having the same problem. Did you get any info on what was wrong with it?
Yes the door was not latching and door switch had to be replaced
Posted on Aug 30, 2008
  • ashgm Aug 30, 2008
    Try the diagnostic cycle. If it gives 4E then it is a door latch issue. Another way to diagnose would be that the drum light remains on even when you shut the door.
The dryer is not drying clothes
Hi,If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly.if you dryer is gas check out this gas no heat tip....If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 22, 2011 | Kenmore HE5 Electric Dryer
How do you replace the door switch? i have he5 kenmore elite
last on the list:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Dec 02, 2010 | Kenmore HE5 Electric Dryer
The dryer is locked and i can't unlock it
Hi.
If the appliance is control locked , follow the instructions in the link below:
The front light lit on my Whirlpool dryer...
The article was written for Whirlpool. It is the same on Kenmore dryer. Kenmore dryer are built by Whirlpool, and re-tagged and distributed by Kenmore. Kenmore does not manufacture his own branded appliances.
Regards
Apr 27, 2010 | Kenmore HE5 Electric Dryer
Found a large gray felt ring dryer - now it rattles
reattached the felt ring correctly around the drum to make it run quite again
Apr 26, 2010 | Kenmore HE5
I got a f25 code on my he5 Kenmore washer . What is wrong?
This is a communication error with the motor. The first spot I would check the MCU on the lower front of the unit. Remove the lower front panel three screws check the wires there unplug and plug back in if that does not work check the wires on the top board. The top has three screws in it then it will slide back and off.
Kenmore He5 Dryer
try replacing the door strikes and catches part # 279570...possible door hinge issue but less likely
Aug 20, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE5 Electric Dryer
I have a Kenmore HE5 Steam: after a power failure last week, now when you turn the dryer on and push"start" the cycle stops emediately and flashes PF...
May 07, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
78 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
