Question about Sharp AL 1631 Copier
Could not pick up papers from paper tray.
One day, the machine just could not pick up papers from the tray. I removed the paper tray and hit the copy botton and found that the roller just did not move to pick up paper at all, despite the wheels at the bottom(side)were rolling.
  • smiller117 Sep 04, 2008
    Roller continues to roll non-stop but is not picking up paper. The only way to make it stop is to turn it off
  • Anonymous Oct 11, 2008
    I have exactly the same problem. Anyone has any solution?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
1- either the tray is not lifting the paper to meet the rollers ( which may indicate a motor problem) or the rollers are not coming down to meet hte paper (clutch problem)
Posted on Sep 02, 2008
Photocopy unable
Sir/ Madam
Hear Is The Soluction which Help You To Fix Your Brother MFC 210C Photo Copy Problem,
Description: Issues with the paper feed could include:
  • Feeding multiple pages.
  • Misfeeds the paper.
  • Printed pages are not stacked neatly.
  • "No Paper Fed" or "Paper Jam" messages appear on the LCD.
To prevent these issues, try the following recommendations:
  1. Verify the paper is loaded properly in the paper tray and the paper support flap is unfolded.
  1. Pull the paper tray out of the machine and remove the output paper tray.
  1. Remove the paper from the paper tray.
  2. Pull the paper support out and unfold the paper support flap.
  1. Fan the stack of paper well to avoid paper jams and misfeeds.
  1. Gently insert the paper into the paper tray print side face down and the leading edge (top of the paper) in first. The paper should be flat in the tray and below the maximum paper mark. Be sure you do not push the paper in too far as it may lift at the end of the tray and cause feed problems.
  1. Press and slide the paper guides on the sides of the paper to fit the paper width.
  1. Clean the paper pick-up roller
    NOTE: Illustrations shown below are from the representative product and may differ from your Brother machine.
    1. Pull the paper tray completely out of the machine.
    2. Unplug the machine from the AC power outlet and remove the Jam Clear Cover (1).
    Note DO NOT place the jam clear cover face down as shown in the illustration. You may damage the cover and cause paper jam.
    1. Clean the Paper Pick-up Roller (1) with isopropyl alcohol on a cotton swab.
    2. Put the Jam Clear Cover back on. Make sure the cover is set properly.
    3. Put the paper tray firmly back in the machine.
    4. Re-connect the power cord.
  2. Verify there is only ONE type of paper loaded in the paper tray.
  3. Make sure that you use paper that meets our specifications.
    To see the detail of the specifications, refer to the User's Guide. The latest User's Guide is available in the Manuals section.
  4. Do not use paper that is damaged, curled, wrinkled, or irregularly shaped.
  5. We recommend using Brother paper to ensure the paper meets the proper specifications.
If your question was not answered, please Tell Us More Information About Your Brother MFC 210C Photo Copy Problem Issue And Errors
Jan 03, 2014 | Brother MFC 210C All-In-One InkJet Printer
Paper jam
Being in the printing business for some 19 years... Uggg the Paper Jam. Well not actually knowing your machine. you have to remove the paper. If the take-up roller and separator tire/pad are dirty (usually from pre-printed or 2-sided copying ) try cleaning with DeNatured Alcohol with an Alcohol soaked pad if you can get to it... ANOTHER WAY IS ...to do this If you take a clean sheet of paper and get it damp with The Alcohol put in the paper tray, then hit print let the tire scuff the sheet with the Alcohol it usually will not feed but it will clean off the glaze of ink that makes the tire pick up too many sheets. ( The system works by first scuffing the top sheet and then the bottom turns/or a pad rubs, backward to separate the sheets) . Do this a couple of times to clean the whole wheel.
Or you may have to get new tires if they are too hard, they should be somewhat soft and grippy.
Hope this helps.
Dec 30, 2017 | Canon PIXMA MG2220 Inkjet Photo All-In-One
Will only print 1 copy then says paper jam, but I think it is not picking up the next sheet of paper. I have taken the paper out fanned it and replaced it only to have the unit make 1 copy and display...
Clean the paper feed tire. If it is not picking up the paper this is the most common cause.
Just remove the paper tray completely from the machine. Now look into the port where the tray was. The tire is in the center from left to right and on the top side right at the front edge where the tray goes in. Just use a cloth and some glass cleaner or even dampened with water as we are just trying to remove any paper dust/dirt buildup on the roller. Just clean the part you can see then rotate the tire around to clean the rest. I think on this model the tire will only rotate 1 direction.
Once clean just re-install the tray and test.
Good Luck and thank you for using Fixya.
Aug 05, 2010 | Brother MFC 7420 All-In-One Laser Printer
In A4 and LGL the paper is fully loaded but it
first of all: when you put in paper cass. does the paper cass. produce abnormal sound like kling kling but without klang- if so the gear that rise paper is broken.( do not tray to remove and replace the gear without copy repair experience) this gear is in paper pick up unit, under the countless of clutches, spring, gears, solenoids,...
second: can you see if there is any sensor hanging, remove both cass. and try to compare!
If the machine copys normal from second cass. it is allmost 100% pick up unit.-call service
Jan 12, 2010 | Canon imageRUNNER C3200 Copier
Samsung Scx-4216f wont pick paper out of drawer
Below would be the suggested solution regarding paper feeding problems;
If Paper does not feed into the machine.
• Remove any obstructions inside the machine.
• Paper has not been loaded correctly. Remove paper from the
tray and reload it correctly.
• There is too much paper in the paper tray. Remove excess
paper from the tray.
• The paper is too thick. Use only paper that meets the
specifications required by the machine.
Below is the suggested paper specifications;
Supported Sizes of Paper
Paper Dimensions* Weight Capacity**
Letter 8.5 X 11 in. (216 X 279mm)
• 60 to 105 g/m2 bond (16 to 28 lb) for the paper tray
• 60 to 120 g/m2 bond (16 to 32 lb) for the Bypass tray
• 250 sheets of 75 g/ m2 bond (20 lb) paper for the paper tray
• 1 sheet of paper for the Bypass tray A4 210 X 297 mm (8.3 X 11.7 in.)
Executive 7.25 X 10.5 in. (191 X 267 mm)
Legal 8.5 X 14 in. (216 X 356 mm)
Folio 216 X 330 mm (8.5 X 13 in.)
Hope this helps!
Sep 10, 2009 | Samsung Office Equipment & Supplies
Wrinkled paper
Many possibilities can cause this....
The Pick Up Rollers could be worn out and not picking the paper up correctly.
Something blocking, or catching in the paper path
The Fuser unit rollers could be sticking, going bad..
The Exit Delivery could be warped, cracked.
After these machines get old, the heat from Fuser unit causes the delivery Exit to melt, warp, and become extremely brittle.
The simple things you can check your self:
Entirely remove the paper tray, look in the copier where the paper tray slides in, look in side the machine where the paper tray goes, make certain there is nothing in the trays path.
Take the paper out of the paper tray, go through the paper make certain there is no crumbled paper in the tray, it should lay flat and even in the tray...
My favorite, check the paper it self.
I once was at a customer whom recently changed their paper supplier; every 10th piece of paper was creased from the new **** of paper. I found that the entire Box of paper had creases in every ****. It was the paper not the machine. It was pre-wrinkled.
Feb 06, 2009 | Sharp AR-207 Copier
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Printing problem with MFC-665CW
1. Take paper tray completely out of the machine.
2. Remove the rear cover, clean the paper pick-up roller.
3. Put rear cover back, put paper tray into machine.
4. Copy a blank page for paper feeding test.
Jan 23, 2008 | Brother Multi-Function Center MFC-665CW...
Sharp AL 1631 Copier Logo
149 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
