Question about GE Washing Machines
Washer is leaking when draining...
I washed a heavy rug in the washer and since then it has leaked right before each spin cycle. It's not just a little leak it's all the water from the load. I checked all hoses and they are in tact. Could you please help me with any other solutions or troubleshooting ideas before I call a repair man or get a new washer? I really appreciate the help.
GE WASHER/WBSE2090A2WW
  • 706 Answers
Ok..so you checked al the hoses.. do you mean ALL the hoses inside the washer? or outside the washer.. chances are one of the hoses broke free durin the violent spin cycle of that over-sized rug.. and you haven't found it yet. If you have sufficient room to extend the washer out from the wall.. gain access to the inside of it from the back.. then check each and wvery hose connection/clamp to make sure they are secure.. also.. look at the pump assemby to make sure it isn't the source of the leak..then if nothing is obvious,, watch for leaks by using a flashlight and examining everything you can while it fills the tub.. Leaks are normally the easiest thiong to zero in on.. and ... try to have a few towels or wet/dry vac handy during all this.. Hope this helps...
Posted on Aug 31, 2008
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Hello - we have a top loading Maytag Performa washing machine that leaks water during the spin cycle when my wife is washing heavy items that she has placed on center spindal to avoid an unbalanced load....
Maytag Epic is leaking water from the bottom about 8 or 9 inches from the front door back on the right side. Is there and thing i can do. It only about 2 years old or less.
Oct 13, 2009 | Maytag Performa PAV2200
Leak with heavy load
Is the machne noisy? If not, it may soon become noisy. Sounds as if the grease seal protecting the basket spindle bearings is leaking. soon the bearings will fail
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
How do you wash one rug? I can't get the machine
You dont say how big this rug is, but I am guessing its not big enough to spreadevenly around the machine. The machine senses an imbalance and willo not spin or failos to spin at a rate that would rekove the water. Try adding some balance to the drum with another object that will evenly spread the load to see if that helops to get rid of the sopping water.
BTW any pictures of you whipping the rug around in the backyard? That should make for Utube fame!
Aug 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer will not start washing cycle. Machine hums like the dryer
Check the drain for clog. If the drain is dirty, the washer won't fill, rinse, or drain.
May 23, 2009 | Frigidaire ATF6000ES Front Load Washer
Kenmore 80 series spins but won't ring out clothes
Check for buildup of detergent/foaming while washing. Check for oil leaks around the clutch area. Could also be the clutch lining is worn out. Replacement parts kit includes all parts
Mar 06, 2009 | Kenmore 22422 Top Load Washer
Kenmore@Heavy Duty Washer - 70 Series
ck lid switch ..rug may have gotten off balance first spin and broken lid switch
Aug 28, 2008 | Washing Machines
Washer leaking from bottom
Take the front panel off of the washer, and run it through a cycle. Watch to see where the leak is coming from. Also, pay attention to the drain in the wall when it is in spin/drain. If this has a blockage in it, it might be backing up causing water to come back out of it.
If you see no leaks the next time you run it, it's possible that it splashed over while spinning because of the off balance load and may not happen again unless it becomes off balance again.
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Bosch WFR2460 Leaks
are you sure it only happens in the spin cycle? and is the leak comming from the bottom front of the washer? most front laoders will leak due to a tear in the belows. that is the rubber boot that seals the washer tub to the front panel. if there was a hole or a tear in the bellows it should have a leak inthe wash cycle also. but there are also other possibilitys too.but its strange to only leak in a spin cycle due to the washer is extracting the water and not adding it. so check and see if it leaks in the wash cycle to and get back to me and we can go from there. looking through my training manual i dont see what could cause a leak in just the spin cycle
Aug 04, 2007 | Bosch Axxis+ WFR 2460 Front Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
