Question about Campbell Hausfeld 04 Gallon Twin Stack Compressor HL5502
What the prop
Air flows will not hold press
  • glen097 Dec 04, 2008
    I have an oilless Campbell Hausfeld twin stack air compressor. Last time I used it everything worked fine. Next time I plugged it in and it ran okay, but won't build up any pressure in the tanks. Tank valves are all closed, safety valve is closed...it just won't build up any pressure. Finally it stopped althogether, as if it had seized up. After a cool-down period it runs again, but still won't pump up any pressure. Any ideas????
    Champion:
  • 254 Answers
This is caused by a bad pressure regulator most likley, or you might check the drain on the bottom to ensure it is closed.
Thanks
Zerko
Posted on Aug 30, 2008
Put outboard in gear and prop turns ,anything abohe idle prop doesnt keep up 30hp
with engine off put in gear and check prop fully in gear , get a friend to hold the flywheel solid and you put pressure on the prop and if you can turn it try adjusting linkage to get more selection in forward then check neuteral and reverse ok also ! check the prop bush isnt slipping also !
Sep 03, 2014 | Motorcycles
How to replace Mass Air Flow Sensor
the mass air flow is located on the outside of the air box. this is where you put the air filter. undo the clamps that hold the hose onto the air box and to the throttle body. undo the bolts that hold the air box in place and remove the air box. there are 2 small bolts that hold the mass air flow to the box remove these and reinstall in reverse order. heres a couple pics to help you identify it. hops this helpsonetufshoppe_49.gifonetufshoppe_48.gif
Jan 26, 2011 | 2003 Cadillac Sts
The center hub is slipping in my outboard propeller,can i press it out,reglue and replace it, what kind of glue is recomended?
When you run the prop into sand or something else you 'spin ' the prop and need to get a new hub pressed in- I think it's like a 12 ton press to do it. Better to buy a new prop online than to get a new hub-at least in Canada it is.
Nov 20, 2010 | Yamaha Boating
No heat also overheats within 5 minwhen i drive it. new radiator new radiator cap new themistat.
seems like you might have a bad head gasket remove radiator cap and let it run. make sure the antifreeze is flowing if not it could be the water pump prop many car makers are using plastic props and they fail with time.also very possible that thermostat is bad was it overheating before it received a radiator ,cap and thermostat if so it is between head gasket.,and water pump but if you have no flow it is possible that the water pump prop is broken .there is head gasket test that can be done most shops have them and cost a little to do.to be sure.
Nov 14, 2010 | 2002 Nissan Sentra
I am getting error code...NF
Hi
Thanks for using FixYa. Error NF means No Fill. The washer has tried to fill but was unsuccessful. NF indicates No Flow. There is something that is interrupting the inbound flow of water to the washer, either hot or cold. Sometimes this happens when water service in the area is interrupted, creating an air pocket that causing the water valve not to sense water.
Try running the diagnostic test by—
  • Press the delicates and heavy soil keys together for 3 seconds.
  • You are in the service mode.
  • Now, press wrinkle free key, cold water should start entering.
  • Then, press the cotton sturdy and hot water should flow.
  • To exit the test mode, either unplug the machine or press the delicate and heavy soil again for 3 seconds.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Sep 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Front prop shaft on a 2004 polaris Atv
the best way to remove it by using a air chiping gun
if you do not have one a punch and hammer will work
Sep 28, 2009 | Polaris ATV
Dishwasher doesn't drain completely after full cycle
If there is any blockage in your diposal, water will comes up to the sink, since it happened to me. As soon I installed the air gap then it fixed the problem. No air gap, water flowing is slowing down conflicting with timed draining causing this problem. Let's think of this, if you fill up water in a 1/2 galon milk container, and you try to emty it. If you pull down straightly , it will be slow compared to pull it at an agle to let air going into the opening. The air vent helps water flow better meeting the timed draining.
Sep 13, 2009 | KitchenAid 24 in. KUDP01IL - Multiple...
Water will not flow out of dispenser
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Sep 07, 2009 | GE Refrigerators
How do we replace propeller on super cub?
The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
Jun 14, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
1991 318i bmw 4door sedan engine keeps cutting off
hello right have u had service done recently may be sh**y plugs check oil lvls and get her running with someone reving and unplug air flow meter se wht happens if theres no change in engine noise it prop tht otherwise take off air intake pipes etc check for blockages (very rare) i can also suggest common fault is pipe from air flow meter to the engine suffers dramaticly from lil cracks and alsorts check tht over completely and the hoses beneath it try all tht first if you dnt have any luck thn start thinking fuel filter alot of crappy fuel about nowadays but i rekon its your pipes either crackes of poped off let me know how ya get on
Jan 02, 2009 | 1999 BMW 318 ti
Campbell Hausfeld 04 Gallon  Twin Stack Compressor HL5502 Logo
145 people viewed this question
Top Campbell Hausfeld Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you a Campbell Hausfeld Air Tool and Compressor Expert? Answer questions, earn points and help others
