Question about Palm Tungsten E Handheld
Cannot establish connection with desktop.
Literally, overnight I became unable to hotsync. Bought new cable, still nothing. When I finally cancel the hotsync, it says "a connection between handheld and desktop could not be established". Am connected to a hub where all else connected is fine and all lights are green. Why all of a sudden? My whole life is on this Tungsten E. HELLLLLPPPPPPPPP!!!!!!! Not using Outlook, using Palm Software. Not sure what version. It is about 1 year old. Thanks
    Master:
  • 473 Answers
My problem was resolved by uninstalling Palm Desktop, then then reinstalling it. First, I had to make a copy of my Palm folder to make sure nothing was lost. Then uninstall Palm Desktop, reinstall it off the CD, and synch. And because I use Chapura Pocket Mirror XT as the interface, I had to reinstall that as well and then resynch. While talking with the Palm representative cost money and was time consuming, it was ultimately the best option. It also left me with duplicate entries which I had to clean up, but at least I'm back to synching again.
Posted on Sep 11, 2005
    Master:
  • 473 Answers
Try to connect it not through the hub, but standalone ... could be a power issue from the hub ...
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
Garmin hotsync issue
Hey uninstall the program, download the newest one available and try again.
Sep 08, 2008 | Garmin iQue 3600 GPS Receiver
Unable to connect with desktop through usb cable
Jan 24, 2011
1 post
Oct 19, 2004
Mar 16, 2004
Dec 18, 2002
Palm Desktop 6.2 & Hotsync manager (windows) cannot ...
h30434.www3.hp.com > Tablets & Calculators > Palm/WebOS
Jan 03, 2016 | Palm TX Handheld
I am unable to HotSync and cannot load HotSync manager
Reinstall Hotsync manager and make sure selected port is correct. Use alternate method to sync like Infrared
May 29, 2009 | Sony CLIE PEG-TJ37 Handheld
Can't get device to hotsync
First thought is that the cable has become defective - they do go wrong.
Assuming the visor is fine other than when hotsyncing, I suggest you reinstall the Desktop manager and hotsync manager on your PC or Mac, HAVING BACKED UP ALL FILES of course.
Sometimes the managers get corrupted and cause problems. Try that first, then check cable and finally a hard reset, assuming you have hotsynced recently and so won't lose loads of information.
May 21, 2009 | Handspring Visor Deluxe Handheld
I reinstaled the Palm Desktop again it worked....
Sep 20, 2008 | Sony CLIE PEG-TJ37 Handheld
Hotsync (on its own) Problem
i have fixed this issue.
you must open up the phone a little ... with a soft tooth brush and clean around the connectors ... you probably spilled something and some rust has made a connection across some of the bus lines near the bottom of the device.
also clean near the bottom on the circuit board almost immediately right next to where the battery is.
Feb 07, 2008 | Palm Treo 650 Handheld
Ibm workpad sync & port issues help!
You have your Hotsync software set to use a com port instead of USB. Right Click on the Hotsync icon on the lower right part of your PC desktop and change it to USB and you should be good to go. The IBM Workpad is just like a Palm. I have the Workpad C500 which is actually a Palm M500. If you have a Workpad C505 it is a Palm M505. Anything you can buy for a Palm M500 will work with a C500 and anything you get for a M505 will work with a C505. If you do NOT have a USB Sync cable for your Workpad I suggest you do what I did... Just get a combination Sync and charge USB cable at Staples or Best Buy for your M500 or M505 and use it. It was about 20 but you can get them cheaper on the Net. I hope this helps you!
Sep 14, 2005 | IBM WorkPad z50
Vx to Outlook 2002 failed - no connection Established
hi, on ur palm tap on home , u would see hotsync icon tap on that , on the hotsync page , u would see ur name on top or just welcome , make sure u see direct serial on the same page , tap on the top left corner where it says hotsync in words , in the drop down , tap on lan sync prefs , make sure local hotsync is darker in shade. on the pc make sure u see the hotsync manager at the bottom right corner , if not , click on start , click on all programs , choose palm desktop , inside that u would see hotsync manager , left double click on that , if it doesnt appear at the bottom right corner , try 4times , then if it still persists , restart the pc and try again. Once u see the hotsync manager at the bottom right corner , right click on that , left click on setup , left click on local , choose a different com port , reduce the speed to 9600 , click on ok restart ur pc and try hotsyncin , if it doesnt work try the previous step again and do not forget to restart ur pc , and then perform a hs , it will work .... Regards
Sep 11, 2005 | Palm Vx Handheld
Palm Tungsten E Handheld Logo
122 people viewed this question
Top Palm Computers & Internet Experts
Marvin
Marvin
JC Meredith
JC Meredith
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
