Question about Sanyo DP42746 42 in. Plasma Television
No picture but sound plasma tv
Sanyo ce32lc61 b was watching tv picture went of still got sound conekted to sky tv wich is fine put new leads on still wont work
  • Sanyo Master
  • 5,568 Answers
If it is affecting video only, the display's power supply is probably at fault and without some technical background and a couple of test instruments, you will not be able to do the repair yourself.
What you can do though is; unplug the set, let it stand overnight or at least several hours, remove the back panel and look for two separate boards with mostly larger components on them; they will have ferrite core transformers on them and several larger capacitors which are cylindrical and mounted vertically to the board.
Before touching anything inside, especially on either board, allow several hours to be safe since the larger capacitors can hold a painful voltage charge for some hours.
The section most likely to fail and cause your problem will be one that you see associated more with the display than the incoming AC line; the latter is the main power supply and its failure would result in no sound or video.
If you see signs of overheating such as discoloration of the board material, it may not be repairable but if you can find a part number on the board, you might be able to buy the power supply and install it yourself.
If there are no signs of heat damage to the board, there may be companies offering to repair it as a subassembly instead of repairing the whole set which could be much more expensive.
Posted on Oct 01, 2008
42 inch DO42746 no picture or sound
It is still possible the z sustain board is bad. or an x driver board.
Jun 26, 2009 | Sanyo DP42746 42 in. Plasma Television
Picture went out on TV
you need to change the sustainer boards and TV will be good as new.
Apr 05, 2009 | V, Inc. Vizio P4 Plasma Television
Screnn going blank
sounds like sky tv issue, try different cabling
Jun 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
No sound through ps3 hdmi
hi i had a problem, but had no pic, but did have sound, rang sony, and they said buy a new hd cable, went out and bought one, and it worked fine!!!
Jan 08, 2008 | LG 42LC2D 42 in. LCD HDTV
42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Dec 14, 2007 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
SAMSUNG LE40R88BDX 40" LCD TV with DVD home Cinema system
if ur surround hasnt got digital in then it wont work also its better to use the red white and yellow wire, i have hdmi and them wires hooked up and i have sound through everythin all i have to do is put it on aux 2, try it out
Dec 02, 2007 | Samsung HT-X40 System
sounds like it may be a software upgrade
Oct 16, 2007 | LG 50PX4DR 50 in. Plasma TV
When watching dvd having showing or fade background
yes it can be down to signal degradation especially via scart lead, make sure you use a decent scart if you buy an expensive one you can tell the difference. Run a cable from your sky digibox direct to your tv to see if the picture improves.
Oct 05, 2007 | LG 42PX4DR 42 in. Plasma TV
Sanyo DP42746 42 in. Plasma Television Logo
203 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
