Question about Honeywell Heating & Cooling
I need to remove a radiator from the wall to decorate behind it. How do I shut off the water on a Honeywell thermostatic valve please? Paul N
    An expert who has answered 500 questions.
  • 540 Answers
Its suppose to automatically close in the no-power position.
Posted on Aug 30, 2008
How to fit TVR to rear entry radiator which has supply from wall behind.
It can b installed i n the horizontal fit a 90 bend to fitting and connect up in to pipe work at the top of rad then bottom entry return
Sep 27, 2013 | Honeywell V2040DSL20 Straight Pattern 3/4...
How do i reset my honeywell thermostat
Remove thermostat from wall, leaving base plate on wall.
Model number appears on back of device.
Google search thermostat model in following format: Honeywell xxxx32 thermostat .pdf
Adding .pdf to search parameter will yield product manual.
Also while thermostat is off the wall, change batteries located in compartment on back of thermostat. These batteries must be changed periodically, for example each 3-4 years.
Jul 17, 2013 | Honeywell TH3110D1008 Pro3000 Thermostat
Heating not working and Honeywell Thermostat Heater states that the temperature is 45 degrees celsius.
without seeing it its hard to say, the thermostat controls the boiler and/or diverter valve depending how its been wired, the diverter valve shunts the water to were its needed ie from one circuit to another if you have two therostats there is a conflict somewere, best bet to have an engineer sort the wireing out
Dec 28, 2011 | Honeywell Programmable Thermostat Heater
How to take a honeywell radiator off the wall
Turn off the circuit breaker to the AC and heating unit. The circuit breaker is inside the home electrical box. The door of your electrical box has a guide indicating which circuit breaker controls the cooling and heating system.Pull the cover off the Honeywell manual thermostat. If necessary, use a flat-head screwdriver to pry the cover away from the base of the thermostat. Locate the two small screws securing the sub-base to the base of the thermostat. The sub-base is the portion of the thermostat that has the indicator dial or indicator lever. Remove the screws with a Phillips-head screwdriver, and pull the sub-base away from the thermostat.Remove the screws securing the base of the thermostat to the wall with the Phillips-head screwdriver. Pull the thermostat base away from the wall so you can access the wires.Loosen the terminal screws securing the wires to the back of the thermostat with the flat-head screwdriver. Wrap the wires around a pencil or a large screw. This will prevent the wires from accidentally falling inside the wall cavity.
Jun 12, 2011 | Honeywell Heating & Cooling
Ideal boiler no heat to radiators but hot water still working
check the divertor head and valve.
sounds like it ist adjusing from dhw to ch.
take head off(remove pi at back,or side pin) and push pin in valve when calling for ch,if it works then the head has gone.
Nov 19, 2009 | Honeywell Programmable Thermostat Heater
Hot Water But No Heat In The Radiators
bleed radiators and check for dirty flame sensor and clean it with steel wool
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
Have hot water but no radiators. Checked pilot
sounds like your circulating pump is bad or electronic zone valves
Oct 26, 2009 | Honeywell Programmable Thermostat Heater
Thermostat problem ?
If you start by looking on your gas valve, you should find the correct amperage to set the heat anticipator at. I am not sure if you have a forced hot water system or a steam system, but depending on the case, you may also have a second problem, which is easily addressed. If you have forced hot water, the upstairs baseboard/radiators may be airbound and need to be bleed. If you have steam, you may need to slow down the downstairs valves, and open the upstairs valves to get a balance. Hope this helps
Oct 20, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
48 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
