Jumpstar secure 11 plus know how to put things(photos) on but do not know how to put them back on computer to be printed etc.
    Scholar:
  • 133 Answers
Your photos should be still on your hard drive to work with , copying to the flash drive only leaves them intact on the main drive.
Posted on Aug 30, 2008
How do I print photos from my cd using hp Photosmart plus?
Don't Connect the printer. First use the cd to install the software for your printer. in the software is a program called print photos or print pictures. After installing the software, connect the printer and switch it on. Start the software and a menus should guide you trough he straps to choose and print the pictures you want to print. Be aware you need to setup things once the program is running, like how big the pictures should be. Don't make them bigger than the paper you insert. Also what kind of paper you use, like plane paper, or photo paper, matte or glossy.
Mar 20, 2015 | HP Photosmart Plus All In One Printer b210
I can't open the pictures on my google plus photos
Ok. Go to your google plus autobackup photos. Find a photo that you would like to save or send in an email put on facebook, etc. Once you do, click "More" which has a down arrow next to it. Then navigate to "Download Photo" > "Original" This will download and save the photo on your computer. Then you will need to get to your downloads folder where you will find the picture saved. Now you can select it to attach to emails post on facebook etc. Hope that helps.
Mar 25, 2014 | Google Gmail
I have a Lexmark X8300. All was ok till recently. I can print out anything from the computer but can't use the copy feature. Also, all of the lights stay on - the copy light, fax light, scan light,...
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
If that doesn't help, try the steps below:
1. Disconnect the printer from your computer.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
2. On your computer, go to Control Panel > Printers and Faxes.
3. Delete the Lexmark print object.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print again.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eO4Y77. Select your operating system, download and execute the file.
If the problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 23, 2011 | Lexmark X8350 Print, Scan, Copy and Fax...
HP c5280 only prints green photos. All other printing is fine. I have put in new hp ink and photo paper. I have tried printing both from computer and with computer unplugged. A print from a website on...
This Problem is based on the Color Management so , The Perfect Solution for this problem is open the Photo or image etc in Adobe PhotoShop then goto Enhance->Adjust Color->Remove Color Cast , after removing the color cast , create a new layer for adjusting brightness , contrast & etc , then finally goto Image Size and change the DPI from 72 to 300 then save the image as JPEG or PNG etc , after saving the image close the Photoshop and open the image using Windows Photo Viewer and take the printout which will come as it is in the System
May 23, 2011 | Office Equipment & Supplies
Photos are printing with too much blue un them. I have changed the color cartridge, cleaned print heads, etc. I am using only Epson namebrand products. Is there any adjustments I can make to correct this?...
It sounds like the print head may be clogged. To clean print head:
  1. Get a saucer and fill it with hot water
  2. Dip the print head in for 30 minutes
  3. Wipe the print head with a dry cloth
  4. Repeat the above at least 3-4 times (replace the hot water in the saucer each time)
  5. After repeating and wiping down the print head, put it back in your printer, put the cartridges in and run the print head cleaning function 2-3 times.
If it still doesn't work, then you may have to replace the print head.
May 10, 2011 | Epson Stylus Photo R280 Series
How to scan photo to save on computer ?
Instructions Things You'll Need:
  • Pictures to scan
  • Computer
  • Scanner
  1. Step 1 ** Prep your photos **
    What we're going to do here is take all your photos and put them onto one 8 1/2 x 11 sheet of paper.
    So take some tape and put it on the BACK of a photo. Then put that photo on the 8 1/2 x 11. You want to do it on the back so it won't ruin your original.
    Then repeat this for the other photos you've got. And make sure you leave some space between the photos. This is so they don't get stuck together or overlap.
    If you have lots and lots of photos that won't fit on one page, then use multiple pages to hold them. In other word, put as many as you can on a page.
  2. Step 2 ** Preparing to scan**
    Now that you've got your photos on an 8 1/2 x 11 piece of paper, it's time to put it onto the scanner. And be careful when holding the paper so your photos don't all fall off.
    Now carefully lay the paper with the photos facing DOWN on the glass of your scanner. And it doesn't matter if you're using a flatbed scanner or one of those combo printer/scanner/fax machines.
    TIP #1: I suggest making sure your glass is clean and free of streaks beforehand. Otherwise, you may see lines or distortions when the photos are scanned.
    TIP #2: Do NOT feed the paper through the sheet feeder if you have one. This may jam the feeder or damange your photos. So make sure you only lay the paper on the glass!
  3. Step 3 ** Ready to scan **
    The only thing left to do now is actually scan your photos. Now depending on your scanner software, you may be able to scan a specific area.
    In other words, many scanning software programs allow you to select the region or area of the paper you want to scan. If so, then I suggest you use this to crop your image around a specific picture. This will make the process easier.
    When you've done this, scan it! Once it's on your computer, you can edit it to make it ligher, sharper, etc. Or save it as is. Then you'd repeat this process for the next picture.
    If your software won't allow you to scan a specific area, then you'll need to scan the entire page. Do it! Once the image is on your computer, then you can use editing software to copy a specific portion to a new file. This is what you'll need to do to get individual photos.
    As an alternative, you could crop the one you just scanned and then save it. Then rescan the whole page again and crop it to the next picture. Both ways work the same, so is your choice which way to go.
Hope it will help you :)
Jul 23, 2010 | HP PSC 1350 All-In-One Thermal Printer
Product/ reg key of ulead video studio 11 plus
Unfortunately, Fixya does not provide crack license keys. Installing one means that you are taking away the right for your computers to be safe. Product updates, most especially the security patches will not be installed if you are using a crack key. One more thing, it is ILLEGAL.
Jun 03, 2010 | Corel Ulead VideoStudio 11 Plus Full...
I cannot scan photographs to computer
hi! there,
well,if you are trying to print a photo under photo album
and you want to select photo or you are to fetch photo, if you click this you are going to menu of your windows exactly, on that you go to my picture,on that menu select your picture to print,if you selected your picture your going back to your photo print menu in this photo print menu it will flash your picture to print,there option there before you print,set all this e.i your photo size 4x6,5x10 or wallet size depend on you,on lay out you have to select how does it print on you photo paper is it 4 pic on one photo paper or 6 etc..the thing is it has you to return in menu in order to flash your photo,this will help you print your own photo no need to go to your photo shop to develop it easy.cheers have a good day thank's to log in fixya don't forget to rate me.
Apr 03, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Printer photo paper
Scrapbooks work very well and they come in such beautiful sets of ornamentation etc. that you can create a beautiful wedding album. Or you can purchase a beautiful 3 ring binder and use the more expensive plastic sleeves that are sturdy and insert all of your 8 X11 pages into them. Or you can make every document or photo that you print 8x10 by setting up your printer to print that way. Good luck to you!!
Aug 15, 2008 | Office Equipment & Supplies
I don't know how to load the 4" x 6" photo paper plus glossy to print a photo, using the Canon ip4000
put the paper on the right corner of the printer. Canon Easy photoprint software will automatically print from the right corner
May 23, 2008 | Office Equipment & Supplies
Computers & Internet Logo
David Payne
David Payne
