Question about Toshiba Gigabeat MEG-F20S MP3 Player
00000010 SYSTEM ERROR
I tried turning my gigabeat ON but i got this error. how can i fix it?
  • 175 Answers
Format is and try updating the software here is a link to fix your problwm.
http://www.megaupload.com/?d=GTC188NU
Posted on Oct 12, 2008
Everytime when i switch on my gigabeat f20, it shows this error.NO SYSTEM FOUND ON HDD. i've tried formating but once this error appears, you can't do anything. Sometimes it shows SYSTEM ERROR.
Hi theofrimp109,
This error usually happens when the firmware has been corrupted or deleted. The easiest way to correct this is by updating the firmware. You may also try to restore the firmware data by following the steps below.
1. Connect the gigabeat to your computer using a USB cable.
2. Start Explorer on the PC.
3. Open the folder in which the gigabeat room is installed.
--> The folder in which the gigabeat room is installed can be opened by clicking [Start] [All Programs] [TOSHIBA gigabeat room 2.0] [gigabeat room 2.0
Program Folder]. Usually, the folder will be found in C:\Program Files\TOSHIBA\gigabeat room 2.0.
4. If you can't find the folder, please go inside the gigabeat then click on [tools], [folder option], go to [view tab] then select [show hidden files and folders].
5. Now, inside the gigabeat root, copy a folder named "GBSYSTEM" located in the folder that was opened in Step 3.
6. Use "Safely Remove Hardware" and disconnect the gigabeat.
Hope it helps.
Thank you for using FixYa.
Jun 28, 2011 | Toshiba Gigabeat MEG-F20S MP3 Player
How to fix a system error?
A system error indicates a possible software or firmware problem. If the unit is in warranty, contact Toshiba about a software upgrade (possible).
If it is out of warranty, the cost of repair is likely more than a new unit.
A system error can be caused by moisture (#1), physical damage (#2) and a possible software update issue. Your Toshiba Gigabeat Room software for your computer may be able to get upgrades for your MEG-F10K. Check the owner's manual. If you cannot connect to the unit with the computer to transfer songs and movies, it is likely not repairable for a reasonable cost.
Mar 22, 2010 | Toshiba Gigabeat MEG-F10K MP3 Player
I formatted the Gigabeat, install the software, it's now reads System error. Is there a fix?
I would try setting up RockB\box on your Gigabeat. Their port is not quite 100% but its very nice. I use it on my S60 and its very stable for me.
www.rockbox.org
Jan 10, 2010 | Toshiba Gigabeat S30 MP3 Player
My gigabeat f60/f20 sytem error
Your hardrive maybe faulty is it clicking??? otherwise format it and reinstall the software.
Here:
Jul 07, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Touchpad won't work on my Gigabeat F40
Mine did the same, touch pad became erratic then stopped working, I could still access everything when linked to a computer. Then all stopped, on power up I got a 00000010 or 0000020 error and nothing.
I popped the end caps off, removed the two small screws holding the back on and found the strap of wires connecting the hard drive was almost completely dissconnected. Pushed the connector back together , reassembled and now all working
Apr 26, 2008 | Toshiba Gigabeat MEGF40S MP3 Player
My gigabeat says system error
hello all my gigabeat f20 had that system error 00000010 on it so i removed the top and bottom cap, then i removed the rear cover off the unit (it takes a bit of force and the end caps just pull off). i noticed the long plug attaching the hard drive to the unit had semi-detached so i simply pushed it back on.NOW ITS FIXED!!!!!
Jan 24, 2008 | Toshiba Gigabeat MEG-F20S MP3 Player
Error number 00100060
Comment by MAHMOOD, posted on Oct 22, 2007 my younger brother plugged my megf20 gigabeat to pc and he formatted that using windows xp format disk utility now when i am turning on the gigabeat i just see an error and that is
no system found on hdd
error number is 00100060
if you can help me please
Oct 22, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Lynda having trolled through countless message boards it seems that there are many with the same problem but no way to properly fix it!! i think i will be giving toshiba a call tomorrow to see what they have to say. Alex
Jan 20, 2007 | Toshiba Gigabeat MEGF40S MP3 Player
Gigabeat System Error Problem
Error message 0000020 - System Error displayed whenevr devide powered up. Only way to shut down is by turning battery off. Gigabeat Software on PC not able to detect device, not listed in Device Manager or as an external drive in My Computer. (As it normally is) Is there a way to reinstall firmware from PC when device not detected?
Aug 14, 2006 | Toshiba Gigabeat MEG-F20S MP3 Player
Toshiba Gigabeat MEG-F20S MP3 Player Logo
148 people viewed this question
Top Toshiba Audio Players & Recorders Experts
James DuPont Jr
James DuPont Jr
 Grubhead
Grubhead
Are you a Toshiba Audio Player and Recorder Expert? Answer questions, earn points and help others
