Question about Sony Cyber-shot DSC-W30 Digital Camera
Lense stuck outside MY LENSE GOES OUT AND GOES IN (NO STOP) OUTSIDE OF MY CAMERA INFO APPEARS AT LCD MONITOR: ACCESS; WENN THE LENSE STOPS, THE NEXT INFO APPEARS AT LCD MONITOR: TURN THE POWER OFF AND ON AGAINST I FOLLOW BUT NO EFFECT DO I FIX IT?
  • 446 Answers
You need to send this to the shop, im afraid, these tiny parts are not easy to repair, the home positioning sensor need some repairing
Posted on Aug 30, 2008
When camera is turned on no picture appears in the viewfinder or on the LCD screen, it remains black. The batteries are new. I can access the menu, change settings. Everything works but there is no image...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Sep 04, 2010 | Canon PowerShot S2 IS Digital Camera
I have this lens on a D50. At times, it does not auto focus the lens. Just it seems to go from one end to the other and the motor can be heard working. At times it works correctly but it appears to have...
Double check to make sure that the camera/lens is not set to manual mode. The next item would be to check would be to clean the contacts of lens, where it attaches to the body. Try the camera with another AF-S lens. It may be that the autofocus unit on the lens has stopped working.
Apr 06, 2010 | Nikon Nikkor 18-135mm f/3.5-5.6G ED-IF...
Camera is constantly buffering and virtually nonresponsive.
I can help you fix the BUSY Error or Error 99 of your Canon EOS Rebel XS / Canon EOS 1000D.
Installation of this Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update will solve these problems:
  1. Some cameras may exhibit a phenomenon in which the LCD monitor does not display, the shutter does not release, and the BUSY indication remains lit in the viewfinder.
  2. The message, "Err 99 Shooting is not possible. Turn the power switch to<OFF> and <ON> again or re-install the battery", appears on the camera's LCD monitor, and after the above operation is carried out,the LCD monitor displays in a language that is different from the actual language setting.
See the firmware instructions and download the firmware upgrade by following these Fixya Tips :
  1. Follow this link to download a pdf version of the firmware installation instruction guide.
  2. Follow this link to download the Windows Version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  3. Follow this link to download the MAC version of the Canon EOS Rebel XS / Canon EOS 1000D firmware version 1.06 update.
  4. Follow this link to download the Canon EOS Rebel XS / Canon EOS 1000D Instruction Manual.
I hope that helps.
Aug 11, 2009 | Canon EOS Rebel XS 35mm SLR Camera
I have a cannon sd1000 , bought 1 month back. suddenly its stopped capturing pictures. i.e while in shot mode the display is black and not showing and capturing the image.but able to access al the menus....
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Jul 17, 2009 | Canon PowerShot SD1000 Digital Camera
Canon G7 lense does not extend fully but it is NOT e18
Maybe lens needs adjustment. The info on this page may help. Copy and paste this link for more info.
http://www.fixya.com/PostAnswer.aspx?thid=1841738&prdid=447928&ctgid=67
Mar 22, 2009 | Canon PowerShot SD500 / IXUS 700 Digital...
Aperture stuck on quantaray 28-200mm for canon AF (rebel)
Does the lens have an aperture ring? If so, some such lenses also has a 'lock' (a tiny button near the narrowest aperture) enabling it to be used with cameras having CPU contacts. Check if your lens has this.
Jan 27, 2009 | Quantaray 28-200mm f/3.8-5.6 for Canon AF
Lense error
send it in for repair. their is no easy fix for this sorry. www.digitalcamrepair.com can help.
Jul 07, 2008 | Casio Exilim EX-Z750 Digital Camera
Lense stuck outside
you have jammed the 3 lens studs outside of the track , you cannot fix it without dissembling the entire camera to the lens,
its best to leave it alone and sell it on ebay for the lcd is worth 35 to 60
Apr 13, 2008 | Cameras
Sony Cyber-shot DSC-W30 Digital Camera Logo
74 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
