Question about Microsoft Windows Vista Ultimate Edition
When refreshing desktop icons get randomly placed not in the order I've set:(
I think problem is frustrating me for over a 6 months or so.
But one thing this will not hapn daily...whenevr i complete downloading softwares,music and any stuff from internet..and then when I rightclick refresh -Icons places are changed(not according to the order i've set).
My rightclick on desktop looks:
Could someone help me :)
thanx in advance!!
  • Srinivas
    Srinivas Aug 31, 2008
    Well I dont want to untick, if i do then my desktop looks like a complete MESS...but then i'll try.
    Thanq
    Scholar:
  • 87 Answers
Have you tried unticking the 'align to grid'. I just had a look at my settings and this is not ticked.
Posted on Aug 31, 2008
Gateway dx4380g-uw308 keeps restarting?
Windows 8 has a neat utility that is called "Refresh Your PC". This process does not change any of your files (documents, pics, vids, music, etc.). If you upgraded your PC from Windows 8 to Windows 8.1 and your PC has a Windows 8 recovery partition, refreshing your PC will restore Windows 8. You'll need to upgrade to Windows 8.1 after the refresh has finished.
To refresh your PC
  1. Swipe in from the right edge of the screen, tap Settings, and then tap Change PC settings.
    (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, click Settings, and then click Change PC settings.)
  2. Tap or click Update and recovery, and then tap or click Recovery.
  3. Under Refresh your PC without affecting your files, tap or click Get started.
  4. Follow the instructions on the screen.
Aug 20, 2014 | Gateway DX4380G-UW308 Small Form Factor...
Replacing ram (1 x 512mb and 1 x 256) with 2 x 1gb. PC boots ok (slowly) then seems to freeze (nothing shown on taskbar) - desktop icons take ages to appear then seem to randomly refresh. The new ram is...
Try re-installing the two new sticks two or three times. Sometimes there is a little build up of oxides on the contacts on the motherboard and keeps the bios from properly recognizing them.
Sep 18, 2013 | Fujitsu Siemens SCENIC P300 PC Desktop
Is it possible to place icons (shortcuts) on the MC9090 to gain quick-access to programs? If so, how is it done?
Hope this answers your question. First go to the .EXE file you want to be on the desktop. Touch and hold to pull open the sub-menu of that app. Select "Copy". Now go to the desktop. Find an empty section. Touch and hold down to open the sub-menu. Now select "Paste Shortcut". This will put a shortcut on the desktop for you. It will show the word "Shortcut" at the beginning of the title now, which is kind of a pain. A simple "Rename" can fix that though. That should do it!
Feb 25, 2013 | Symbol Motorola MC9090 Mobile Computer
I cannot move the icons around on my desktop computer. I have 'right-clicked' and made sure that the auto arrange and lock desktop icons options are NOT checked off. I cannot open jpegs witho
If its shared, are you logging in to user account or are you the administrator for the computer? The administrator account can add / remove rights for the others but locking desktop icons I haven't seen as an option. Try doing a system restore if there is a restore point available to a date before the problem started. No data is affected just settings and drivers and such
Jul 23, 2012 | Microsoft Windows XP Home Edition English...
I want to take my computer back to factory settings
It is the operating system which requires refreshing in a computer. So removing the present windows and instaling new one would definitely solve the problem, but b carefull as u ve to face some trouble with regards to the drivers
Jul 06, 2012 | Lenovo Computers & Internet
Monitor drops into sleep at random; power light amber; hard drive light green; disc drive light comes on green
Try another monitor and see if it acts the same way. Borrow a monitor from the next door neighbor for an hour or so or from a relative and see if it behaves the same way. If not, go purchase a monitor.
Apr 26, 2012 | Dell Dimension 2400 PC Desktop
I have a computer that i run dual montors on, both plug into the same video card, both monitors are crt's. my video card has 1 vga connector and 1 dvi connector. so i use a dvi to vga addaptor. now...
It is possible that you've got the resolution and vertical refresh rate set too high. CRTs tend to flicker if the vertical refresh rate is not set to about 72 to 75 Hz. If your screen resolution it set fairly high compared to what the monitor was designed to display it can overtax the video sweep circuitry in the monitor. If possible check the manufacturer's specs.
Often the video driver will let you specify different resolutions for primary and secondary monitor. If you can't find the manufacturer's specs it would be prudent to pick a less demanding resolution or vertical refresh rate for the secondary monitor.
Aug 10, 2011 | Computers & Internet
My monitor was distorted so i changed the screen refresh rate in the advanced tab of the settings panel under monitor to the max setting from the minimum one, and now the monitor wont turn on it only says...
dear,monitor have no fault but setting is dismissed.
1-restore factory setting from monitor.
if still problem then you open the control panel and uninstall the display driver and then again install.
3 method...
right click on desktop
then press tab and goto setting
then goto advance setting and then click on monitor icon and change the refresh rate.
i think you solve this problem easily
Apr 11, 2009 | Computers & Internet
Acer AT2001 cannot use as monitor
I currently own an Acer AT2001 21 inch Television/Monitor. The refresh rate on your computer should be set to 60Hertz. You can change this setting by right clicking the desktop, click properties, click settings, click advanced, click adapter, click list all modes, click 800by600 at 60Hertz. The screen resolution will not go above 800by600. Note; Initialize these settings with an old crt monitor and then plug in the Acer.
Mar 15, 2008 | Acer AT2001 20 in. EDTV-Ready LCD...
Microsoft Windows Vista Ultimate Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
