Question about Whirlpool LER3622HQ Electric Portable Dryer
Dryer will not turn on. The electric plug in is fine (there is power on the electric line) we used this dryer for years fro the same location. What should I check first on the unite? is there an electric diagram available for this dryer on line? thanks, H
  • sisuent Aug 31, 2008
    Great!
    Thanks ! - will keep you posted on progress my efforts to get it fixed.
  • 706 Answers
You can get the parts breakdown and information at this link
http://www.pcappliancerepair.com/model-display.php
Hope this helps..
Posted on Aug 31, 2008
Dryer has quit heating
Sounds like the heat coil has went bad you can pick one up at a appliance store,but the cost would be close to buying a used dryer,also check and see if something has gotten on the coil and shorted it out I had a dyer one time that I found a little dead snake on it,I removed it and it work for many years good luck....
Jan 10, 2013 | Dryers
Dryer has power, buttons on front beep when touched, but dryer will not turn on when you hit the run button, and drum light has quit working, cannot seem to locate my users guide or fine one on-line to...
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
Jan 29, 2011 | Kenmore 84072 Electric Dryer
We moved into our new home, we connected the washer and dryer, the dryer was working fine, our dryer is a whirlpool dryer and it electric, it a duet, the model number is GEW9260PW0 the dryer was working...
sounds like the element could have went out. if you cant take the dryer apart you should call a service co. always disconect the power before working on it.
Dec 23, 2010 | Whirlpool Dryers
1 year old dryer has no power. Yes, it's plugged in, breaker seems fine. any ideas?
First you need to actually test for power, Breaker seems fine doesn't mean you are getting power to the recepticle.Please post back after testing for power.
Aug 18, 2010 | Samsung DV218AEW Electric Dryer
Whirlpool WED5800S electric dryer - wont start
There can be many reasons why your dryer2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
Dryer2_bing.gif Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Jun 11, 2010 | Whirlpool WED5800S Electric Dryer
My maytag electric dryer has worked perfectly fine for 10 years. today i unplugged the dryer and did some work on the wall. when i plugged the dryer back in it tripped the breaker. could it be the dryer or...
You already unpluged before the wall work, so the problem is isolated from the dryer from its plug. Take off the wall socket to inspect since it may have damaged. If you have the voltmeter, measure each pair of the terminal. they should have a voltage at least 110V since it is three-phase voltage. If there is no voltage then just replace the socket. Make sure to turn main power off when you do the replacement.
Apr 27, 2010 | Whirlpool LER5636P Electric Dryer
Dryer stops
Unplug your dryer plug. Go to your house electric panel, turn off your 30 amp dryer breaker, and then turn it back on. This resets the breaker. So before opening up the dryer to look for fuses, make sure you have power at the receptacle. Don't plug anything into the receptacle until you have wired it correctly. If you want to run it by me when you're wiring it, that's fine with me. . I hope this helps. Good Luck! Jim
Mar 16, 2010 | GE DBSR453EBWW Electric Dryer
Blowing breaker
hi. I can help you.
Electric dryers use 220 volts or two power lines of 110 volts each. Some components in the dryer need only 110 volts; the heating element requires 220 volts. So it's possible for one part of the dryer to be fine and another part to have a short circuit. Short circuits can be caused by the heating element, the main power cord, or any other part of the internal wiring. To decide where the problem lies, unplug the dryer, then:
  • If the circuit breakers or fuses remain on and/or intact when the dryer is unplugged, it's likely the problem is with the dryer. Contact a qualified appliance repair technician.
  • If the circuit breaker trips or the fuse blows when the dryer is unplugged, it's likely the problem is with the house wiring, fuse box, or circuit box. Contact a qualified electrician.
Jun 22, 2009 | Kenmore 63942 Dryer
Kenmore Elite HE3 front load dryer no power
Yes. Remove the kickplate and check the continuity of the thermal fuse located on the blower housing.
Feb 23, 2009 | Kenmore Dryers
Older washer/ dryer with no power
Check to see if power cord is loose at connection inside dryer. ONLY after UNPLUGING! Held on by three screws inside.
Aug 22, 2006 | Maytag PYE2300AY Electric Dryer
Whirlpool LER3622HQ Electric Portable Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
