Question about Frigidaire ATF6000ES Front Load Washer
Front load washer
Why does my fabric softner not drain into the washer. after a load is done the softner is all still in the dispenser.
  • 3 more comments
  • bamagirl050 Aug 31, 2008
    I have taken the tray out and thoroughly cleaned it. Softner still does not dispense.
  • sbabineau Oct 07, 2008
    I own a front load Firgidaire washer and my fabric softner dispenser doesn't work porperly. Sometimes it works and sometimes it does not. I'm guessing it's not plugged if it works sometimes. Also after the loas is finished I sometimes have water where the bleach goes! Help me.
  • Luv2crop Nov 09, 2008
    My softner has completly stopped dispensing. I have cleaned the tray and run water through just fine. Initially it worked most of the time but now not at all. Would rather not have to make a service call for something like this.
  • mediocer Nov 09, 2008
    frigidaire ATF6000ES fabric softener not dispensing.
    I seems the water is not getting into the fabric softener part on the dispenser. Detergent and Bleach release just fine. The fabric softener just stays there.
    Is this something that a support call would warrant or could I do this myself?
  • tah553 Jan 08, 2009
    I HAVE THE EXACT SAME PROBLEM WITH MY FRONT LOADER.. PLEASE HELP
  • 639 Answers
Friend,
ngfam1 At your service!
Try opening the little holes in th softener try that may be clogged up! it's usually this
Below I referred you to a great service nation wide!
If none of these tasks remedy the heat problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • Neil
    Neil Aug 31, 2008
    If you did clean the tray!
    THEN it is a mechanical fault and you need factory service!
    If I was there hands on, I would have remedied the problem too!
    A&E Factory Service
    1(800) 905-9505
    You will be fine
    Bless You ngafm1
The fabric softner tray isn't draining
Here is a tip that I wrote about what I found out about the fabric softener not dispensing into the washer...
Fridgidaire Washing Machine Fabric Softner not going into washer
heatman101
Feb 21, 2011 | Frigidaire GLTF1240A Front Load Washer
Water left in fabric softner area when load is done
heatman101
Feb 14, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Fabric Softner
that is normal you can either add water to make it drain or pull out the drawer and dump it.
Sep 13, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water collects in the fabric softner dispenser during in the washing and doesn't drain. We have to pour it out vbefroe washing the next load.
Take the dispenser out the washer and clean it very good.
Pull the caps off and make sure no fabric softner is hanging around the hole. The unit uses a siphon effect to drain the compartments.
It's normal to have some water left over tho. Just not full of water.
Sep 03, 2009 | Frigidaire ATF6000ES Front Load Washer
My HE washer doesn't dispense the fabric softner
Try removing the dispenser cup - and washing the inner cup thoroughly- run a sanitary cycle with whites and chlorine bleach mold and mildew likes to haunt these front loaders - be sure to run a bleach hot water cycle once weekly
Mar 01, 2009 | Kenmore Elite 45986 Front Load Washer
Samsung frontloading washer won't dispense fabric softner
clean filters in washer inlets on back of washer. take off hoses and look up inside of inlet, pull out the filters by pulling stright out on them. then fush backwards to get sand or whatever out of fiter
Dec 30, 2008 | Samsung WF337AA Front Load Washer
Fabric softener does not drain out of dispenser
Hi. Remove dispenser and thoroughly clean, are you sure you have cold water going into dispenser?
Nov 25, 2008 | LG WM-2277HW Front Load Washer
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Front Load Does not dispense fabric softner and bleach
under the bottom panel of the washer on the left hand side is a tech sheet that will tell you how to fix this
Mar 05, 2008 | Frigidaire GLTF2940ES Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
318 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
