Question about Olympus Camedia C-765 Digital Camera
Olympus C-765 does not focus
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} My Olympus C-765 camera does not focus any more. I just turned in on, and it failed to focus (after 4 years of use). No drops or impacts..just turned it on. It has a quiet clunk sound once the lens it at full extension on start up. It is in focus at start up. If I move the zoom, it can not find the new focus position. I can tap the zoom a bit one way or another and (perhaps by chance) it finds the focus. I have tried manual focus. I can go from closest to farthest range in manual with no change in image focus at all distances. I have tried change from ESP focus to spot, still no luck. My guess is that the (very soft, just audible) cluck has something to with the intern focus mechanism. Any suggestions?
  • benjaminbunn Oct 06, 2008
    Thanks for replying. I have been using manual focus for quite a while. By setting it as you describe, the speed of the camera is greatly reduced so you can capture those quick shots and actual focus on the subject you want.
    The solution you offer is not the issue.
    Luckily, the thing was in focus when it is turned on, so my wife took it on a trip and never used the zoom. When she came back, the focus worked on the zoom.
    If I had to GUESS, I would say a tooth is worn on the mechanism that adjusts the focal length from the lens to the photo-receptor and that after 70+ times of turning it on and off, the missing tooth is on the side of the gear that is not engaged when the lens is fully extended.
    I doubt if it is worth getting fixed at a shop, but if anyone has an idea what might be the problem, I'd like to know your suggestions.
    Like most things, it will work everytime I test it at home, but when I take it out to a race or an event, it will fail. That is just the way life is...
Dear Benjamin,
I also own an olympus c765 and was wondering how to use the manual focus option when I came across your post. Actually I have been wondering whether manual focus is of any use in an olympus c765 because the manual does not talk anything about it.
However, I just found out that there is a way of activating/deactivating manual focus. Here it goes:
1. Turn the camera on
2. Switch to any mode - portrait/landscape etc
3. Press and hold the 'OK' button on the centre for a second until you see a MF/AF option on the screen
4. Switch to MF and focus on any subject by pressing the up/down keys.
Most likely, your camera has been turned to Manual Focus option, which is why it is not focussing any more. Follow the steps above and turn it back to Auto Focus option and let me know if your problem gets solved.
Regards
Posted on Oct 04, 2008
C-765 olympus won't turn on
It can be many things.....Including a fool...!!!
Mar 04, 2014 | Olympus Camedia C-765 Digital Camera
My old camera was an Olympus Camedia c-765 digital. My new one is an Olypmus SP-800UZ 14 megapixel. The more I use the SP-8OOuz the more disappointed with the pictures I take. None of them seem sharply in...
No, you are not wrong. When there are more pixels, the picture must be more clearly and you can zoom it more. Because you have experience with another Olympus camera, I'm inclined to believe that
something is wrong with your new camera. Try to put it on AUTO mode and see the difference.If everything will be ok, it means that you are wrong when you set the manual parameters.
Mar 24, 2011 | Olympus SP800UZ Digital Camera
What card do i used
The C-765 uses xD picture cards, 16 to 512MB in size.
Jan 31, 2011 | Olympus Camedia C-765 Digital Camera
Olympus C-765 - won't take photos anymore. Memory card is fine and camera has worked perfectly for the past two years. Does anybody have a solution? The camera seems to function as normal, but when I press...
Reset the menus to default or factory settings.
Then test the camera again.
Make sure that the battery is fully charged or new.
You might consider to buy a new battery (Ebay is a good place) for this camera. Then test.
Problems like this can show up when the battery is weak or not fully charged.
You may try to remove the battery for 24 hours and then after try it again.
Apr 15, 2010 | Olympus Camedia C-765 Digital Camera
I have an Olympus C-765 for 5 years. Lately, the battery does not charge and in fact I cannot use the camera. How to know if the problem is with the battery or with the charger
1. Do not use ordinary batteries. Use rechargeable NiMH.
2. Measure battery voltage using tester or volt meter. 1.2 v for rechargeables.
3. Try measuring charger output.
Oct 31, 2009 | Olympus Camedia C-765 Digital Camera
Card cover open appears on screen despite it being closed. Tried removing card and battery replacting and powering on. No luck
The problem you are describing is a problem with teh sensor in side the card cover door. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $149 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
May 08, 2009 | Olympus Camedia C-765 Digital Camera
On my c-765 slow shutter speed
When operating any digital camera, the camera tries to capture the best focus and exposure for that particular scene. By pressing the shutter button half-way down, the focus and exposure is being set. There will be a green circle on the upper left hand corner of the screen, then your camera is ready to take the picture. Slowly depress the shutter the rest of the way down to take the picture.
May 03, 2009 | Olympus Camedia C-765 Digital Camera
Card Full when not full
I would format the card. Make sure you format the card IN the camera. Don't use a card reader or your pc. If that doesn't work (I'm sure it will), then you have a bad card.
Rob
Mar 02, 2009 | Olympus Camedia C-765 Digital Camera
Olympus FE-230 Digital problem
Someone on here with the same problem mentioned that they shook the camera violently and it fixed the problem of it not focusing. I tried the same thing and actually gave it some light slaps on the tabletop. Well, now it works! I'm somewhat concerned that this fix won't last long.
Like many others' FE-230s, this camera began not focusing shortly after the one year warranty expired. I found my receipt and it turns out that I purchased the 2 year service plan at Best Buy and could get the camera replaced. But, now it works. Will it fail again after the 2 year plan expires? Jeez....
Jul 27, 2008 | Olympus FE-230 Digital Camera
A non-Olympus brand xD-Picture Card
Yes, an Olympus brand xD-Picture Card also offers the ability to use the Panorama function.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Olympus Camedia C-765 Digital Camera Logo
160 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
