Question about Car Audio & Video
Nissan Almera 1.5 2004 CD Stuck
Hi
The CY 460 CD player has swallowed a cd and I am not able to remove the plastic cover in order to get the CD player out.
Can you help please?
Thanks
  • kieranl Apr 07, 2009
    CD won't eject form radio and will not read the one in there
    Makes a clicking sound, I got quotes for new ones online ranging form £50 to £120. Can it be fixed or do i
Ignore the instructions in the Haynes manual!! (This will tell you to remove the centre console!) Pull off (forwards) the plastic that's just clipped between the centre console & the radio console.
This reveals the 2 screws that hold the radio console on. Remove them and pull the radio console forwards to remove. I think you could remove the electrical connections - I didn't and put the radio console on one side. Remove the 4 screws holding the radio chassis to the car and pull this forward and off. Pull out the aerial lead and carefully remove the electrical connections to the back of the radio/cd unit. For convenience remove the 4 set screws holding the radio chassis brackets and set to one side. (If it's in the way, remove the 2 screws holding the black plastic under-storage tray.)
Replace with a new unit. Take the current unit apart as best you can and retrieve your cd, undamaged.
Posted on Apr 01, 2013
  • 37 Answers
SOURCE: Nissan Almera Tino 2004 - built-in radio is quiet or screeches
with the proper wire harness you can retrofit any aftermarket indash you want call any car audio shop they will be happy to set you up with exactly what you need
Posted on Mar 17, 2010
Testimonial: "great thanks"
  • 4932 Answers
SOURCE: how to remove the cd player from nissan pulsar
Visit this free site and select the correct car make and radio instructions
http://www.fitaudio.com/
Posted on Sep 08, 2009
kenw392
  • 2226 Answers
SOURCE: cd palyer won't eject.
nissan comes with a clarion radio that had eject problems. you are probably better off removing it and replacing it with and aftermarket radio.
Posted on Jun 03, 2009
  • 4932 Answers
SOURCE: cd stuck in player of peugeot 307..how can it be
Try and tease it out with a credit card or old CD .Double sided tape stuck onto the leading edge often helps
If this does not work, then the player will have to be removed from the dashboard and the covers taken off to retrieve the stuck CD
Make sure you have the Security Code before extracting the player
Posted on Apr 02, 2010
  • 4932 Answers
SOURCE: can some one help me find radio code for my nissan
Sorry...this code is not available for free from anywhere on the Internet
Main Dealer or a Radio Decoding Service only
Posted on Jun 24, 2010
Hi my Onkyo DXC390 has too many cd's stuck in the change and it comes up with Mech Error. I read here that you have to remove a cover, I took the screws off and took off metal flashing but still cannot...
Careful when you remove the black plastic tray, note the alignment and position of the tray before you remove it.
First unplug the player and try tilting the player sideways to see if any loose Cd's will come out from under the tray. If that solves your problem do not dismantle the tray.
Jun 03, 2011 | Audio Players & Recorders
How do I remove the CD/DVD drive from this computer? The layout inside is different from many desktops.
just pop off the colored plate and the clips are on the side. the drive will slide right out.
(1) take off the left side cover, (2) near the front, at the bottom of the internal drive cage is a plastic lever, flip it down, (3) now open the front plastic CD holder cover (the bottom gray plastic thing), (4) there are two finger holes at the bottom of the top plastic cover - pull the top cover loose (note if you're scared to put a lot of pressure on it, you can use a small flat screwdriver through those holes to lift back the two tabs holding the cover on), (5) with the top cover off, pinch in the two plastic tabs on the side of the drive you want and pull it forward (note disconnect the IDE cable (and audio if there is one) before pulling the drive too far out), (6) pull off the two side rails from the old drive (they just push in and pull out) - but note which rail comes off which side (I'm not sure if they can be inserted upside down or not, so just keep track of which one goes on which side), (7) push the side rails onto the new drive (note you have to really push hard on the metal part of the rail to seat it properly - you'll know it's not seated if the drive doesn't slip in easily), (8) slip in the new drive & connect the IDE and power (and audio if there is one)cables (9) install the top plastic frame, flip up the lock inside the case, then close the bottom CD cover thing, (10) enjoy the new drive. hope this helps you and please vote for me
Dec 04, 2010 | Compaq Presario 5000 PC Desktop
A cd is wedged in unit. can not remove cd changer
First press and hold Track-Up and Mode buttons at same time on unit for three seconds to reset disc player, then check if cd get release.
In some cases, performing a reset on the MCD6 may resolve your problem. First try resetting the MCD6 player by pressing the TRACK UP and POWER buttons at the same time. If that does not work, remove the plastic front cover by pulling straight out and press the RESET button below the keypad. If your MCD6 player still does not operate, please take off cover from cd player and try to manually release wedged cd in unit.
If loading gears worn out then nothing will help to fix the unit, please contact local repair shop or M&S Systems at (214).358-3 196
Hope these info will help you.
Let me know if you have any question.
Thanks.
Nov 03, 2010 | M&S Systems MCD-6 6-Disc CD Changer
How do i replace lights on bubble tubes? They bubble but no lights.
You can order bubble tubes and damaged front plastics from Deer Park Dist (618) 427-3761. Once you get the parts, remove the back of the unit. You will be able to see all the screws which hold on the front plastics. Removing the screws and the plastics to get easy access to the bubble tubes. A long screwdirver is helpful. The magnets in the speakers will grab the screws and the screwdriver from you.
May 12, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
There is a disc jammed in my cd player and the tray sometimes opens and closes but wont bring the disc out
Hi
Thanks for using FixYa. Locate your CD player’s manual Eject button. It is usually a small hole located underneath the CD drawer.
Use a stiff wire, a paper clip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Remove the CD and see if there is a problem with it. Most CD player drawers get stuck when a CD is warped or the label is starting to peel. If the CD is warped, discard it. If the label is peeling, remove the label.
To open the CD player top to remove the cd/CD manually--
  • Unplug the CD player and take the outer casing of the CD player off. This entails either taking out two or three screws or simply sliding one of the pieces of plastic in either direction.
  • Locate the disc loader cover. The disc loader cover is located where the extending CD tray finally comes to rest within the CD player. It’s the part that holds the CD loader in place.
  • Bend the two tabs outward that hold the loader in place. This is a delicate procedure because you don’t want to hurt the device. The tabs are relatively easy to break since they're plastic in most cases.
Points to remember while performing above steps---
 Before you remove the CD player cover, try turning the device off and then back on to see if the disc will come out after the machine has rebooted.
 Use the opportunity while you have the outer casing off to clean the lens of your CD player.
 Never work on an electrical device that's still plugged in.
 Opening a CD player may negate the warranty. Read your warranty carefully before you proceed.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 18, 2009 | GPX KC318S CD Player
CD stuck in player.
there are four screws on the front of the cd deck. take them off and remove the cd deck from the main unit. there is a total of for screws u need to remove to get the cd out from the top. two are near teh front holding the silver cover. remove them and slightly slight the cover forward and up to removethe next are towards the back. after all screws are removed gently lift the top cover making sure not to crack the load arms. remove disc and seal case again. hope this helps... cuz thats how i did it with no problems and btw mine is shot too
Dec 21, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Fading
You can order the entire cover, if you'd like. And there are some generic metal colored covers available for them.
Also, we offer custom artwork in the form of a vinyl wrap for the CDJ units.
- OPTiC
Repair Videos
Pioneer DJ Repair
DJ Equipment Sales
Pioneer Parts
Nov 22, 2008 | Pioneer CDJ-1000MKII CD Player
Stuck CD
hi there bguedes
best solution take top cover of and as it says pleasewait and you hear the noise just give the tray a bit of a jolt to help it around but beware of electric wires and static that should fix your problem
hope this helps an please if you have the time please rate me if you dont mind
thank you
fixya
Jan 11, 2008 | Kenwood CD-323M 200-Disc CD Changer
CD is stuck in the Numark CDX cd turntable
hello, there should 4 little black screws on the top of the cd tray when it is removed from the deck. two of them are on the rear top in black plastic. the other two are holding the silver plate down as well. remove those four screws. the top should slide off. after that is off, you should be able to see how the disc is being secured. careful not to pry any thing it should all come apart. good luck.
Nov 29, 2007 | Nu Mark Numark Cdx Table Top CD Player CD...
Car Audio & Video Logo
2,737 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
