Question about Vornado Standard&Full Size Air Circulator CR1-0076-06 Fan
Older Vornado window air circulator, model 280AE, need new switch
I own a Vornado window air circulator, model 280AE, serial AMJ190, purchased around 1986 from a specility catalogue. I have never seen that model since. It has a variable speed switch which I blew when I accidently severed a wire while changing the fan body from intake to exhaust. Anyways, my good neighbor Bob rewired to the motor to bypass the switch and the fan works well but on one speed. Can that switch be easily replaced so the fan can resume its normal functioning? If so, what do I look for? This fan has served me well for many years.
Many thanks! Molly Q.
  • Anonymous Mar 14, 2014
    I need a new rotary switch 3 speed I cant find any on patton web site any ideas where I can find one
    Master:
  • 638 Answers
Try to insert regulating switches.that will help.
thanks.
please rate the solution
Posted on Aug 30, 2008
    Genius:
  • 1,847 Answers
You can the wiring digram for this link..
http://www.efi.org/specs/panasonic_5505x093_wiring.gif
    Brigadier General:
  • 3,614 Answers
I need a replacement knob for my Vornado fan 530
Go on line to the manufacturers site. They should have listings for all parts for your fan. Order from there, or get directions to your nearest supplier.
Oct 19, 2014 | Vornado 530 Whole Room Air Circulator
How do i change battery on vornado remote
it may be held on with a tiny screw.. it needs removed before you can open it up
Aug 01, 2014 | Frontgate Vornado Tower Circulator Fan -...
Where can I purchase a Vornado fan replacement blade for a Type 530 Vornado fan?
Hi carim.
I think this one NuTone S99020165 Ventilation Fan Blade Fits. Anyway, contact the vendor before buying it.
I hope it was helpful.
Enjoy
Jun 03, 2011 | Vornado (CR1-0073-06) Fan
Model FA1-0013 TYPE SWAN SERIAL # MAY00 VORNADO FAN When you plug it in and turn on the switch it does not work.
The motor has a single-use fuse in the run winding; that may be tripped. Or there could be no power going to the motor. Some of the swans had a power lead that was too short and pulled out of the switch. Take the 5 feet/screws out of the fan and remove the bottom plate. Are any of the wires loose that go to the switch? One power lead goes to the white wire that runsd directly to the motor: is that hooked up? If you need more help, contact me.
cawicks at g mail
Aug 29, 2010 | Vornado Circulating Fan
Electric switch for a vornado fan model 280LS serial # OND89
mcdevito75 here, You may be able to match up the fan switch at a large hardware store in your Rea, Home Depot, Doodys etc.
Jul 24, 2010 | Vornado Standard and Full Size Air...
Cord was sparking at edge that goes into the module
The power cord should be replaced by Vornado.
Can you post the model number and serial number?
Jul 01, 2010 | Vornado Circulating Fan
Vornado Circulating Fan - motor will run but blades will not turn.
Does the motor spin, but the blade is not turning?
The motor has a D shaped shaft. If the hole in the blade that the shaft goes in is rounded, then the blade will spin. In that case you need a new blade. Vornado can supply that.
Jun 27, 2010 | Vornado Circulating Fan
Switch is broken on my Vornado floor fan, circulating
Hello. Here is the link to Vornado Support. See what a new switch will cost plus shipping before you decide whether to repair or not. http://www.vornado.com/Default.aspx?ISC_PageName=Support
Apr 09, 2010 | Vornado Circulating Fan
Vornado Standard&Full Size Air Circulator CR1-0076-06 Fan Logo
482 people viewed this question
Top Vornado Dryers Experts
Steve
Ian Summerfield
Ian Summerfield
Mack Baxter
Are you a Vornado Dryer Expert? Answer questions, earn points and help others
