Question about Whirlpool Refrigerators
Whirlpool ARG 581/2 built in refrigerator
Cannot work out how to fit the door
  • 230 Answers
SOURCE: Whirlpool refrigerator won't make ice--just out of warranty
I would have to say control board but you could look for a bin level switch. This is what tells the machine that the ice Bin is full. If it is duty or damaged the machine will never make ice as it thinks there is enough already there
Posted on Sep 06, 2012
Whirlpool GD25FFCHT01 dispenser not working
It might also be the cable that connects through the hinge door to main unit.
Feb 08, 2013 | Whirlpool Refrigeration White Side Trim...
Sep 05, 2012 | Whirlpool Refrigerators
Need to know how to hook waterlines up
Good Afternoon, JohnHerren27:
Here are the instructions to install your water line:
http://whirlpool.custhelp.com/app/answers/detail/a_id/975
and your parts can be found here:
http://www.repairclinic.com/Whirlpool-Refrigerator-Hose-Tube-Or-Fittings-Parts
Literally fresh water in minutes.
Chr
Aug 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
WATER DROPS AT TOP OF FRIDGE
sounds like the door was left open,make sure nothing is overhanging on the shelves preventing the door from closing next time send model number
Nov 27, 2009 | Refrigerators
Small pool of water underneath Whirlpool fridge
There may be a water filter built in. Look for access lower front panel below door. recommend replace every year. They will leak when neglected.
Nov 06, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
My fridge is not getting cold
low gas level in the system
Oct 16, 2009 | Whirlpool Refrigerators
I just bought second hand Whirlpool fridge freezer, ARG/918/G/WP (8534918010180) - is there a user guide/manual available? I don't know how to set it, defrost, it or anything.
I assume that you are in the UK (as indicated by your product number) so call Whirlpool Service on 0844 815 8989 and give them the mnodel no and the 12 digit number that begins with 85 and they will assist you.
If you are not in the UK then go to
http://www.whirlpool.com/custserv/global_sites.jsp
and select your region / country and locate the contact suppoprt tab and contact them with the same details.
Sep 11, 2009 | Refrigerators
Refrig door trays do not stay in place. Door studs too far apart.
Hi there. Take one of the trays to a hardware store or even a home depot and but a 12 inch piece of clear plastic tubing which fits snuggly over the studs. Cut the pieces just long enough so that the trays snuggly fit into the refrigerator door. This will solve your problem for a few cents compared to a very pricey repair kit from the manufacturer of the refrigerator. good luck.
Feb 01, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Refrigerators Logo
81 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
