Question about Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker
Kenmore elite 795.7756
I am getting the er dh code. It sounds like the problem is the controller assembly but how do you replace the controller assembly? Where is it located on the refrigerator? We have a model 106.74202402 top freezer refridgerator that a tech told us needed an evaporator motor. He hasn't shown up as scheduled although the motor was mailed to us. The diagram in the manual shows the part but not how to get to it. I've given up on their service techs and need to know how to get to the motor to replace it. I have removed the sliding shelf in the freezer but don't see any screws other than the ones on top. It looks like the ice maker might also have to be removed if these screws are removed. When the shelf was removed it looks like burn marks near the cover. I'm not sure if the motor is the problem or if we have had a short in the wiring leading to it.
  • 435 Answers
I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
Posted on Aug 30, 2008
    Genius:
  • 1,269 Answers
Go to the link below for repairing your fridge. The motor needs to be replaced.
http://home.howstuffworks.com/how-to-repair-a-refrigerator.htm
    Brigadier General:
  • 3,614 Answers
The defrost timer is often located at the bottom of the refrigerator, near the front and behind the kick plate.
  • Kenmore Master
  • 19,396 Answers
Try first unplugging th power cable for ten minutes to see if this clears the error.
  • 1 more comment
  • Ginko
    Ginko Aug 30, 2008
    On this site you find directions on error message:
    Kenmore Elite Refrigerator error er dh - FixYa
    The error means the termic switch that control freezer defrost is not working.
    Sometimes it restart working when you perform a complete defrost, leaving appliance unplugged overnight.
    If not the part must be replaced.
    On this website you find replacements for your model.
    If you need a repairman you can call the number listed on the fridge user manual.
  • Ginko
    Ginko Aug 30, 2008
    Test the termic switch in the freezer for continuity, on the post reported before said it was that, how do you know is the evaporator?
    In any case if evaporator has gone the thermistor may have gone after it.
  • Ginko
    Ginko Aug 30, 2008
    By the way you can get part details and complete diagrams at Partselect, give me the right model number, the ones posted did not work, see here how to ger model number.
    If you input right model number in Partselect you get the diagrams showing you how to access the part.
The code ER CO keeps coming on, on the display panel. The fridge and freezer still work but the code keeps coming up. Any info on that?
LG Bottom Freezer Refrigerator Error Codes Sears PartsDirect
Select
Use our model number finder
Choose your product type
Common model number plates
Close
LG Refrigerator Error Codes
These error code explanations can help you diagnose a problem with your LG bottom-freezer refrigerator. For repair how-to help, visit the PartsDirect repair help section, which includes repair help for washing machines, other major appliances, lawn and garden equipment, garage door openers, vacuum cleaners and more. You can also search for owner's manuals, get advice from an expert and find refrigerator replacement parts. Error Code
Er FS Error Code
Er rS Error Code
F dS Error Code
r dS Error Code
Er HS Error Code
Er IS Error Code
Er SS Error Code
Er rt Error Code
Er It Error Code
Er gF Error Code Error Code
r dH Error Code
Er IF Error Code
Er FF Error Code
Er CF Condition
Condenser fan motor is defective Check/Repair
Condenser fan motor, wiring or the control board Shop Parts
Condenser fan motor, Power control board, Wiring harness Error Code
Er CO Condition
Communication error Check/Repair
Communication error between main board and display board Shop Parts
Display control board, Power control board, Wiring harness
Jul 16, 2015 | LG LFX25974ST 24.7 cu. ft. French Door...
I am getting error code dH.. What is this?
Thank you for contacting fixya.com.
DH means defrost heater and refrigerator computer is not sensing the defrost cycle. It is due to a bad defrost sensor located on the evaporator behind the plastic cover in the back of the freezer compartment. You need to replace that.
Also check this link if it helps:-
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 73503 Stainless Steel Bottom...
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Trio Error Message ER DH
This is a refrigerator manufactured by LG and is well known for this type of malfunction. There should be two 1/4 inch screws on the outside of the freezer drawer tracks near the front that will allow you to pull out the entire door assembly. Once this is done and the unit is fully defrosted and unplugged, there are a couple/few screws in the back freezer panel. Once the panel is removed, this part is located on the upper right side of the evaperator coils. It is sometimes wedged in tigtly but should pull out with a good tug. Unplug the white harness, remove defective part and reverse this process. Good luck and happy shopping for the shoes.
Aug 25, 2009 | Refrigerators
The panel control going shows Er in temp display
ER in temp means error code next 2 letters are first letter of part giving problem or where problem located.. if " ER DH" means def heater not coming on, does not mean heater bad but def control bad not letting voltage to heater. could need main bd also
Aug 21, 2009 | LG LRSC-26922 Side by Side Refrigerator
I have error code ER dH. Unplug and then replug
Error Code - erdh
Kenmore and LG 795 Series. Model 795.77556600 but most models use the same repair. Controller Part # 6615JB2005H
To Verify correct part. Check part number for your model number at
www.searspartsdirect.com
Don't be intimidated by this repair... The 'erdh' error code indicates - error defrost heater. Replacing the controller is EASY. The difficult part is removing everything in the freezer section to access the evaporator coil but hang in there and stay with it. You will not hurt anything if you use common sense.
The new part (defrost controller) is relatively inexpensive ranging $10 - $14. Here in the SouthWest I used Appliance Parts Depot for a $10 part cost. Don't forget to have 3-4 small wire ties to secure the defrost heater, defrost sensor and wires.
It would help to write down a few notes of some of the particulars during disassembly.
I had the same ERDH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel.
(See Diagram Image) I accessed it by removing the freezer door, all components inside the freezer, including the slide rails / tracks mounted on the sides of the freezer. Be careful when removing the rear white panel because an evaporator fan is mounted on the back of it and plugs into the back left side of the freezer compartment. You just saved yourself about $375 or more.
Stay With It & Good Luck!
Feb 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Sep 21, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
http://www.searspartsdirect.com/partsdirect/retrieveSubComponentPartsAction.action?diagramPageId=00002&documentId=50029842&modelNumber=79577549600&productCategoryId=0161000&brandId=0583&modelName=REFRIGERATOR&backToLink=Return+to+Sub+Componentsyou can go here when the site is up enter your model number and click on refridgerator controls section you will see parts look for defrost control get the part number then will be a little square box click on it it says show diagram then check the diagram fo the part number thats the easyist way to tell you if you need more help then reply to me picture is wworth a thousand words
Apr 11, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Great advice from medeer, I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
My refrigerator is 20 months old, just a few months past the warrentee,
Feb 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite 22.4 cu. ft. Bottom Freezer Refrigerator with Adjusta Cube Ice Maker Logo
208 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
