Pioneer elite rear projection - unit crashes frequently, making a popping sound, gets yellow/black striped screen with inward arcing edges. Have to manually turn off unit, wait a while, usually, then manually turn back on. It may then function normally for a few minutes, or a day or two, before crashing again. What's the likely cause. Thanks in advance for any thoughts on what needs to be done and probable cost.
    Genius:
  • 1,269 Answers
Try to turn off the TV for 2-3 hours first, unplug the power cable. If that didn't work, there's a problem with its internal power supply chip. You may need to double check the circuit board of the TV to see any burned components. If you can't open the casing of the tv, just contact any pro tv technician to do the component replacement.
Posted on Aug 30, 2008
    Genius:
  • 1,847 Answers
You may need the power supply board resoldered as I had the same problem. The guy listed below can do it for you as I shipped mine from Illinois to him in California... Piece of cake getting the board out of the back and it's not too fraigile... Just pack in bubble wrap and it will be fine. My TV is now working great.
Pioneer deh 15ub wire diagram
Yellow - Constant 12 Volt (battery)
Red - Accesory 12 volt (switched) only 12 volts when car in accesory or on position
Black - Ground (chasis)
White/white with black stripe - Front left speaker (black stripe is negative polarity)
Gray/Gray with black stripe - Front right speaker (stripe negative)
Green/green w/ black - rear left
purple/purple w/ black - rear right
solid blue - power anteanna (not all have this wire)
blue w white stripe - remote turn on (used to turn amplifier on or power anteanna)
yellow w/ black stripe - mute (for cellphone handsfree kit)
Jan 21, 2014 | Car Audio & Video
Black screen pops up states caution your screen may seem reversed
I'm assuming this is a DVD player or at least contains a video screen. The message you are seeing sounds like the rear camera input has been activated. They give this alert to inform drivers that the view through the rear cam may be reversed. Most cameras have a switch setting to allow this adjustment.
If you do not have a rear camera installed, then it sounds to me like the rear camera trigger has been improperly connected. This is a wire that when it sees a 12-volt signal, activate the rear cam input on the radio. If you do not have a rear camera, this wire should not be connected. You did not give a make/model so I cannot begin to guess the wire color, but look for a wire that is not either black, red, yellow, white, gray, green, violet, or blue (with or without stripes). There is no standard color for this wire. Some Alpine units use orange/white, but on most radios, this is a dimmer wire. Pioneer and Kenwood often use a light purple or purple/white.
Find out what wire is for reverse camera and disconnect it.
Dec 19, 2013 | Car Audio & Video
How to install a pioneer deh-p8400mp car radio
Here is the wring harness colour code for Pioneer.
Yellow= Constant 12V
Red= Switched 12V
Black=Ground
Blue=Power Antenna
Blue/White stripe= Power Amp Rmote turn-on
White & White/Black stripe= Front Right Speakers
Grey & Grey/Black stripe= Front Left Speakers
Purple & Purple/Black stripe= Rear Right Speakers
Green & Green/Black stripe= Rear Left Speakers
Orange= Illumination
Ajin
Apr 27, 2012 | Pioneer Car Audio & Video
Pioneer premier gm-x434 wiring diagram
Yellow - Constant (battery 12V)
Red - Accesory (switched) only 12 volts when car in accesory or on position
White/white with black stripe- Front left speaker (black stripe is negative polarity)
yellow w/ black stripe - mute (for cellphone handsfree kit)2_17_2012_9_02_19_am.jpg
Feb 17, 2012 | Pioneer Car Audio & Video
I need wiring diagram for DEH 2100 pioneer
Wiring information is as follows:Yellow = +12V ConstantRed = +12V AccessoryBlack = Ground (Chassis)Blue/white stripe = Remote amp turn-on/Power antennaWhite = Left Front +White/black stripe = Left Front -Gray = Right Front +Gray/black stripe = Right Front -Green = Left Rear +green/black stripe = Left Rear -Violet = Right Rear +Violet/black stripe = Right Rear -
Here is a link to a website that has a PDF document for the Pioneer Owner's Manual:
http://www.manualowl.com/m/Pioneer/DEH-2100IB/Manual/56355
In this, you should find the information you are looking for. I hope this was helpful.
Aug 27, 2011 | Pioneer DEH-2100 CD Player
I purchased a Pioneer Deh-1400 cd am fm player 2nd hand with no manual. Can anyone tell me the proper wiring connections? Only the power line is labeled.
remote turn on is blue with a white stripe and antena is blue 12+ is yellow acc is red ground is black left front is white with gray stripe right front is gray with black stripe green with black stripe is rear left and purple with black stripe is right rear
May 18, 2010 | Pioneer DEH-1400 CD Player
It has blue and green arc colors showing up with duplicate words at the lowest part of the screen-just showed up yesterday It is a Pioneer Elite projection monitor receiver PRO-710HD
Replace Both of Your STK ICs They are Big Black ICs will have STK392-110 on them upgrade ICs to 120s-150s,or 180s Call Mat Electronics for parts
1-800-628-1118 ICs will be on the Left hand side of Chassis Mounted on The very First board,there are screws holding board on Fame/ board also plugs in bottom of chassis.
Jan 21, 2010 | Pioneer PRO-710HD 64" Rear Projection...
Pioneer Elite Pro 620 HD TV on several occasions the screen has gone black but sound continues and the power green libht remains on. After shutting down for 10-15 minutes picture comes back.
Pioneer Elite Pro rear projection 620HD - Picture is still there but brightness and "white" have faded over years allowing for mediocre viewing when room is dark only. During the daylight picture is visible if viewed straight on and within 15 feet from set. Any suggestions?
Oct 16, 2009 | Televison & Video
I do not have the wiring diagram for a pioneer deh p7800mp.
If you're installing this the easy way to go is go to like walmart and buy a stereo2.gif wiring harness for your specific vehicle. This plug plugs directly into your factory plug and has the wires that connect to your pioneer unit attached to it. All you need to do is match color to color. tracing wires to splice directly into your factory wiring can be a royal pain, trust me i've done it and it ain't fun... but for what its worth here you go.
Red...Accessory
Yellow...power
Black...Ground
Blue w/ white stripe...remote turn on
Blue...power antenna
Gray...Right front+
Gray w/black stripe...right front-
White...Left front+
white w/black stripe...left front-
Purple...right rear+
Purple w/black stripe...right rear-
Green...left rear+
Green w/black stripe...left rear-
Sep 21, 2009 | Pioneer DEH-P7800MP
Need wire color codes for pioneer model DEH-P3001B
If you're installing this the easy way to go is go to like walmart and buy a stereo wiring harness for your specific vehicle. This plug plugs directly into your factory plug and has the wires that connect to your pioneer unit attached to it. All you need to do is match color to color. tracing wires to splice directly into your factory wiring can be a royal pain, trust me i've done it and it ain't fun... but for what its worth here you go.
Red...Accessory
Yellow...power
Black...Ground
Gray...Right front+
White...Left front+
Green...left rear+
Aug 30, 2009 | Pioneer DEH-P2900MP CD Receiver...
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
