Question about Toshiba 52HM95 52" HDTV Projection Television
What a mistake!
My 52HM95 is less than 3 yrs. old and it sounds like its 100. On start-up, shut down and during the actual viewing time the tv is so loud my neighbors can here it. Now as I watch tv my colors fade to shades of red and green and finally it shuts itself off. After reading other reports I see that I am not the only one with these problems and Toshiba is no help at all. The lamp was changed about 1 1/2 yrs. ago. I called the local repair shop suggested by Toshiba and they seem to think its going to cost around $1000 to fix it. Any ideas where to start???
    Problem Solver:
  • 4 Answers
Find a cliff and push. It will save you alot of money and headaches
Posted on Sep 22, 2008
Ventless wall heater shuts off during operation
Sounds like thermostat may have a battery going bad as to not supply sufficient power to turn on the relays. As safety procaution when a signal is weak or no longer detected the heater shuts down.
Nov 16, 2017 | Procom Heating & Cooling
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
Periodically my 52HM95 would have some little electrical glitch where it would not come on when I turned the tv on. I would have to wait a little while before I tried again, or I could shut the power off...
I have a similar DLP TV. If you losing your new bulbs that quickly there is likely a problem with cooling. There is a fan that keeps bulb cool. Make sure the fan is working and there is nothing blocking the air passages. I have not had a problem with my fan but you should be able to find a replacement at Radio Shack or a computer/electronics store like MicroCenter. They come in standard sizes just make sure the voltage is correct typically 120 VAC or 12 VDC.
I have had the computer inside crash such that the sound would work, the bulb would come on, put no picture. Fixed by unplugging the TV for one minute then plug in and turn on.
The bulb repeatedly goes through its startup cycle but never comes on. It tries about ten times then stops. Fixed by removing the bulb housing and firmly tapping it on a counter top ten times. This was at Toshiba instructions over the phone and it actually worked.
Dec 31, 2010 | Toshiba 52HM95 52" HDTV Projection...
The TV will shut off by itself randomly (anywhere
Sounds like the TV is going into the "protect mode", usually means there is a failure present and it's shutting down to ward off any serious damage to the electronics. The status light will usually blink a error code along with this symptom, call a service center and let them know how many times the light is blinking in a continious pattern and that will help them to diagnos your TV problem. Good luck and Merry Christmas!
Dec 25, 2009 | RCA D52W135D 52 in. TV/DVD Combo
My 50 inch hitachi projection tv keeps powering up and down.
First it is not an emergency.
No Legitimate repair company should be that busy.
Call Hitachi and get an AUTHORIZED Hitachi dealer to service your TV.
Your problem is beyond self help/
Unplug the TV until it is repaired properly or you will do more damage and have a much larger repair bill.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Philips Magnavox 51MP392H Rear Projection...
Loud hum with ramp up and ramp down sound
It is the color wheel but the bad news is Toshiba will not sell the color wheel for this model, you have to but the entire light engine. part # 23405474 for about $500.00
Jun 20, 2008 | Toshiba 52HM95 52" HDTV Projection...
52HM95 - Color Wheel noise - and then it stopped ....
I have the same tv and it is making a loud noise coming from a fan I think, and we already went through 3 bulbs, this tv really sucks I will never buy anything from toshiba again
Apr 21, 2008 | Toshiba 52HM95 52" HDTV Projection...
You have what sounds like a failing vertical output IC also could be some bad capacitors. If you are able to solder it would cost a few dollars to try this and see if it fixes it. If not you would need to replace the whole board itself and that could cost you a little bit more money. If you need a tech it is time to get rid of it you are looking at at least 200 dollars for repair.
Feb 06, 2008 | JVC AV-F29MX3U 29" TV
Toshiba 52HM95 52" HDTV Projection Television Logo
64 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
