Question about Kenmore 72802 Gas Dryer
Kenmore gas dryer
  1. isnt drying and runs continously
  • kim108 Sep 16, 2008
    WHERE IS THE RESET OFR THE FUSE AND HOW DO I GET TO THE IGNITOR OR FLAME SENSOR?
  • 706 Answers
Probably not igniting a flame in the heater. Could be due to a few things.. The igniter is bad or defective.. one of the thermal sense switches tripped and disabled gas flow for your heater to work.. Your gas is off to the system coming in.. Some of these gas driers use non resettable fuses that if tripped, disable the heating system from coming on.. they also use temperaure 'snap switches' that if an overtemp condition happende would disable your heater.. In some systems,.... these snap switches need to be manually reset by pushing a small reset button on them.. Hope this gives you some ideas on what the problem might be..
Posted on Aug 31, 2008
Ge gas dryer heats but doesnt dry
if the flame is lighting you have lint blocking the air flow either in the dryer or in the vent line,also if you have a flame for the first 10 to 20 minutes and then the flame doesn't light you have bad gas coils located on top of the gas valve,when the coils are bad they can work for the first 10 to 20 minutes until the coils get hot and then they fail and you'll see the ignitor glowing orange but no flame,bad gas coils.then when the coils cool down they can work again.hope this helps.you can try removing the vent line from the back of the dryer and see if the flame stays on,if lint is blocking the air from blowing out the flame won't stay lit long enough to dry the clothes.
Dec 01, 2013 | Kenmore 73952 Gas Dryer
Everything works but the clothes dont dry i changed the coils but that didnt do anything. i notice the ignighter isnt lighting up could it be that.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';
Jul 10, 2011 | Kenmore Dryers
Kenmore dryer, the dry runs, but does not heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jun 11, 2010 | Kenmore 63942 Dryer
Dryer isnt heating up what could the issue be and how should i go about fixing it
Things to check, if these are all ok you will need to find a service company to come out and take a look unless you are really handy and have a good multimeter to do some testing. If so I would be happy to walk through some things to check.
- If it is an electric dryer check the fuses and or circuit breaker, one fuse or one leg of the breaker could be tripped and the motor still run.
- If it is a gas dryer make sure no one has accidentally turned the gas valve off to the dryer.
- Check the venting ( this would apply if you are getting some heat but not drying or taking too long to dry)
- If all these fail and you want more detailed troubleshooting send me the model number and your comfort level working with electricity and gas.
Thanks
Apr 18, 2010 | Kenmore 63942 Dryer
My kenmore 70 series dryer will not heat upa nd
bad ignitor
or bad solonoids on your gas vale
check your lint filter
and exhaust outside to be clear of cloggs with good airflow while running
Oct 05, 2009 | Kenmore 73952 Gas Dryer
Gas never ignites in any cycle in a 10yr old Kenmore dryer.
Chances are your igniter has gone bad. It must pull atleast 3.2 amps to open the gas valve and ignite the gas. A new igniter could probably purchased for 20 or 30 dollars.
Mar 13, 2009 | Dryers
Kenmore 600 series gas dryer not warm
Make sure the vent is clear and air movement is good through the rear vent.
Ten,
Check and or replace the flame sensor and the gas valve coils.
Mar 11, 2009 | Kenmore 73952 Gas Dryer
Gas dryer dont dry clothes,I changed ignator,but no light comes o
the element isnt burning thats why, you need a tech to inspect the element
Dec 21, 2008 | Dryers
Kenmore 70 Series
hello,
i have a kenmore series 70's gas dryer that will not heat up when it is turned on and i am now smelling gas when i do try to dry my clothing. it was working yesterday but now this is happening? please help.
thank you,
tina
Jan 05, 2008 | Kenmore 74602 Gas Dryer
Kenmore dryer
this promblem is about always a vent promblem or not cleaning the drier filter if your using the plastic vent check if its mashed behind the drier you must have 4inch of vent all the way throuch if its mashed or folded over its cut down to 2inches if it hangs under your house then comes up to the outside vent housing it can fill with water if the outside hood door isnt oping that will do it too its in your vent some where what i tell cust to do is run 4inch pvc from out side hood up through floor then run short metel vent to pvg attach with clamp to confirm vent restriction take vent loose for one load and see if it dries in right amount of time
Dec 28, 2007 | Dryers
Kenmore 72802 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
