Question about Samsung SpinPoint P80 SP0802N 80 GB Hard Drive
Hard disk c: drive not detecting
Hello my name is umesh.i am not getting my c:drive,when i am formating it showing me your c: drive is corrupted try some other drive please help & tell me any software is there i can repair it please help me.
  • umeshjoshi20 Sep 01, 2008
    hi my name is umesh. thanks for your solution but my problem is that i can't delete or or format it. because when i delete or format it showing me your c:drive is corrupted try some other drive. please help me.
    me.
Format the drive from Command Prompt, if possible.
Else u delete the partition using partition Manager.
If it is not working even after thet, then you have to Delete by using XP cd...and delete the partition
Posted on Aug 30, 2008
But i cant delete or format it by xp it's showing me your c: drive is corrupted & try some other drive please help me
Posted on Sep 01, 2008
Hello, I bought a 250 wd and it is not recognized on my powerbook g4. I have a USB 2.0 cable. Can you help? Also, it does not show up on desktop or on Disk utility.
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use asoftech data recovery program to recover your files. get the data recovery program from
http://www.asoftech.com/adr/
Sep 05, 2011 | Western Digital 250GB ELEMENTS EXTERNAL...
I can not initiliaze wd 160 Gb disk! I just delete all from disk and whan put in USB, power Ok but no name in my computer?
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this data recovery software to recover your files.
Aug 31, 2011 | Western Digital Passport 320GB External...
Hard disk is detected and shows up in device manager and safely remove hardware. but wont open
First if it gives any error like drive is damaged or corrupted try to connect your drive on upper version of windows(like you have widows xp try to connect it on windows vist or windows 7) If the drive open in them first save your data from each of the drives and format them and again place your data in them it will work now.Or if it still not work Try to format it or create new partition of it through Right click my computer go to manage then go to disk management select your drives and format them.
Aug 12, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My usb sandisk cruzer is not being detected by my computer vista and the light isnt turning on either, but i hear the sound on the computer when i plug it in
Go through disk management.
Try lo locate it.
May be it need to initialise.
At time the file format get corrupted.
You will need to format it with fat file system
To go through disk management, go control panel ,
administrative tools,.then computer management.
Feb 18, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Toshiba (MK1031GAS) 100 GB Hard Drive - Cant be viewed in My comp
The first thing you need to do is go into the Control Panel, then double click on Administrative Tools. After that, open up Computer Management, then go to Storage, then Disk Management. This is where you will see all of your drives listed. Be extremely careful in this section because you don’t want to screw up your main hard drive.
What you are looking for in the Disk Management area is your new hard drive. If you only have one hard drive, it should show up as Disk 0. Therefore, your new drive should most likely be Disk 1. Underneath the name Disk 1 it should say Unknown, the size of the disk, and Not Initialized. Right click in this area and you should get a pop-up window. Click Initialize Disk and it should only take a couple of seconds.
Once your new hard drive is initialized, you will still have to format the drive before you can use it. To format, right-click in the column to the right of the Disk 1 label and then click New Simple Volume in the menu that pops up. From here, you can allocate how much of the drive you want for a new volume, what drive letter you want to call it, give it a name, and finally format the hard disk.
Formatting the hard drive may take a while, depending on the size. My 500 gigabyte drive took nearly an hour to format, so don’t be alarmed if your's takes a while. Once the format completes, your new hard drive will now show up in My Computer and you can start putting files on it.
Dec 24, 2009 | Toshiba (MK1031GAS) 100 GB Hard Drive
Pen drive showing insert disk
check your pend drive on some other system if the message is the same, it has become corrupt,replace it
Sep 16, 2009 | IBM Iomega ZIP 750 (22P7099) External ZIP...
Compaq desktop pc not detecting any hard disk
it shows, you lost your hard disk, if it is in warrenty claim it first otherwise consult any technician
Oct 23, 2008 | Computers & Internet
Hard disk problem
your hard disk is developing bad sector (it will be dead) so better to backup your data
May 17, 2008 | Samsung Spinpoint MP0402H 40 GB Hard Drive
Samsung SpinPoint P80 SP0802N 80 GB Hard Drive Logo
112 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
