Question about GE Refrigerators
We have a ge profile 3 temp water dispenser with small fridge that will no dispense water through the cold water side. Nothing seems to be blocking the tube. Could it be frozen?
We discovered that it was frozen, so defrosted it and now it works great!
Posted on Aug 31, 2008
GE Profile Arctica ice dispenser switch quits working
I came across this problem recently , and found the main control board was bad . Check this site first , to see if it can be covered under warranty .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
It was covered under warranty , at the previous customers residence .
Nov 20, 2009 | GE Profile¿ Arctica® Energy...
Fridge is too cold no matter what temp I put it to
the temp is controled by airflow from the freezer. If you have a slide temp control, the control lever or knob might have come loose from the lever that opens the airway to allow airflow. You should be able to find a small opening that goes from the freezer to the fridge. This controls the amount of cold air that is allowed into the fridge.
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My fridge keeps freezing my food
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Oct 07, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
No ice and no water dispenser
Would have to talk you thru with chat .
Jul 17, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice dispenser not working, temperature display off then on
If you pull out the collecor of ice can you then hear and see rotater arm rotating in the back of freezer. If not you need to remove panel and check for voltage at notor and inspect motor.
If you have 120vac and no motion you'll need to replace motor. We have them same day shipping 704-819-6657
Mar 14, 2009 | GE Profile¿ Arctica® Energy...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Cold temps
Same thing happened to us. A baffle that conducts air from the freezer to the fridge gets stuck in the "open" position and needs to be replaced. That'll fix that problem but watch for others including the water dispenser that spontaneously begins blasting water across your floor. We've dealt with this twice.
Jun 08, 2007 | GE Monogram ZISS480DRSS Stainless Steel
Refrigerators Logo
49 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
