Question about Zanussi ZEBF277W Bottom Freezer Refrigerator
Fridge doesn't work but freezer does
Hi i have a zanussi znb 4051s refridgerator. unfortunately the fridge compartment does not work- the light comes on and the top panel of lights work as does the freezer. there is no noise coming from the fridge...any idea? its 1 year old
thanks
  • ivanansell Nov 27, 2008
    zanussi zk59/32rf the freezer is working though the fridge is not geting cold the light is operating and I think the fan is runing could it be the thermostat!
  • poor_zanussi Feb 03, 2009
    I am also facing the same problem. Freezer is working but fridge is not.
    Model is Zanussi ZX99/5SI
I have had the same problem, it was the fan which needed to be replaced.
Posted on Oct 07, 2008
How do I change the door from one side to the other on my Zanussi ZNB 38 NDX?
The door comes off a set of hinges. You may have to remove the front fascia at the top, and access the screws holding the top hinge on to the frame. Unscrew these and remove the door by lifting off the bottom hinge. With the door off you will be able to remove the screws holding the bottom hinge. If you are lucky, they will reverse fit to the other side as they are. If not, use what was the top hinge as the new bottom hinge, fit the door and use the bottom hinge as the new top hinge.
Jun 09, 2012 | Zanussi Refrigerators
Zanussi fridge compartment has stopped cooling but freezer is ok
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
OR.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Aug 24, 2009 | Zanussi ZI918 / 12K Bottom Freezer...
How do I replace the blower fan motor in the freezer section of my Zanussi ZNB 343 W Fridge-Freezer?
unplug unit
use screw drivers, 1/4 & 5/16 nut drivers , to remove panel and any trim required, usually not required. remove braket with either nutdriver, replace and reassemble , simple.
Aug 23, 2009 | Refrigerators
Zanussi fridge freezer not cooling
no, its probably weak capacitors which provide power to switch the relay. Take the control board out and ask a friendly TV repair tech to change the capacitors
Jan 22, 2009 | Engel Freezer 22 Qt. Fridge/Freezer
Fridge making a purring sound then stopped working
Yes, I think you have a problem that can be fixed easily by a repair technician. The sound as you described it could have come from the air circulation fan in the freezer compartment striking ice. As the ice builds up it could have stopped the fan from rotating and air flow to the refrigerator compartment.
Nov 27, 2008 | Zanussi Freezers
The freezer is working but the the fridge
same here. have the znb 4051s refridgerator. freezer works fine but fridge does not. there is no sound eminating from the fridge either...any ideas? its 1 year old!
Apr 13, 2008 | Zanussi ZEBF277W Bottom Freezer...
I have a zanussu fridge
Re. Zanussi ZK87/46EFS Fridge Freezer
The same symptom occurred in our fridge freezer. The fridge compartment warmed up whilst the freezer compartment continued to keep temperature.
The cause of our problem was diagnosed as a frozen sensor that controls a flap, that controls the flow of cold air from the freezer compartment up into the fridge compartment. We were advised to power off the fridge freezer (removing all food and trays from the freezer unit first), and to leave it to defrost for 24hrs. We needed to place a few towels on the floor of the freezer compartment to soak up the melt water. After 24hrs we followed the power up instructions in the manual (versions are available online if you have lost yours). Within a few minutes it was obvious that the fridge compartment was being cooled – Problem solved :)
Apr 13, 2008 | Zanussi Refrigerators
Zanussi ZNB 3450S Fridge Freezer not cold enough
it is going into defrost,not enough frozen items in freezer to hold temperature down. if you bought it july last year.it should still be under waranty
Feb 27, 2008 | Refrigerators
Fridge not cooling
Three most common problems are bad evaporator fan motor, defrost problem, or damper motor.
Sep 30, 2007 | Freezers
Zanussi ZEBF277W Bottom Freezer Refrigerator Logo
1,522 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
