Question about Mitsubishi VS-50603 50" Rear Projection Television
TV NO POWER
SCREEN WAS PINK WITH AUDIO THEN NO VIDEO THEN NO AUDIO AND NOW NO POWER
  • 927 Answers
Good Day, HOGBOYLE;
I would highly suspect that the TV's signal board has CRT Coolant (fluid) on it. Check closely and remove/clean with acetone. Good Luck, big IRISH.
Posted on Aug 31, 2008
Dvd showing pink screen
Sounds like a bad cable or port. Use component if you have it to test the connection. Anti Piracy blacks out the video (from what I have seen) whereas video signal losses with change the color. On the Pink screen, wiggle the connections until you find the culprit.
Oct 31, 2013 | Panasonic Audio Players & Recorders
Nes pink screen no blinking power light
Try cleaning the game packs out with autopsy and rubbing alcohol to see if it helps
Apr 04, 2013 | Nintendo NES Console
47regza has a pink screen says no video signal
Try changing the input device to something you are sure, works such as a DVD player. Look for loose contacts of jacks, sockets and cables.
Switch off TV manually, switch off power, remove plug and retry after 48 hours.
If problem persists, please refer it to a qualified service technician.
Aug 02, 2012 | Toshiba REGZA 52RV530U LCD TV
Tv screen shows green/pink
Ur video board that connected to the CRT long neck(tv tube).Have burn,capacitors?Or cold solder socket pins connected to the crt tube,must resolder,might solved prob.
Oct 14, 2009 | Televison & Video
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
SCREEN PROBLEM
he same problem with my deawoo plasma
Sep 26, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
When sound & picture finally comes on the picture is pink and in the middle of the screen
This is a common problem with this model. The site www.magnavoxhelp.com has a chip kit to fix the no audio/video and video shrinking problem.
Sep 06, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips big screen tv
Does the power light light up when power is pressed? Does it blink? If so how many times does it blink? Have you checked the fuse?
May 19, 2008 | Philips 60P8341 60" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
